Old Feb 26, 2013, 06:47 AM
Graham 65 is offline
Find More Posts by Graham 65
Graham 65's Avatar
Chipping Norton, UK
Joined Jul 2006
How do you store your sailplanes?
How do you store all those valuable, fragile, large sailplanes?
Things are getting out of hand in my workshop, I need to get organised!
Assistance and ideas required.
Graham 65 is offline Find More Posts by Graham 65
Old Feb 26, 2013, 07:42 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Sell some? (Not the answer you were looking for, huh?)
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Feb 26, 2013, 07:56 AM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
In bags, hung from the wall.
tkallev is offline Find More Posts by tkallev
Old Feb 26, 2013, 08:38 AM
Graham 65's Avatar
Chipping Norton, UK
Joined Jul 2006
You are right Woodstock, selling is not an option!
tkallev, any pictures of the bags on wall approach? Sounds tidy.
Old Feb 26, 2013, 09:09 AM
kzimmerm is offline
Find More Posts by kzimmerm
Kurt Zimmerman ≡LSF 4461≡
kzimmerm's Avatar
Montrose, NY
Joined May 2003
I hang the fuses on a 1in x 2in strip along the wall. I simply use large nails spaced apart using an insulated wire as a strap to suspend the fuse. I store my wings on a rack, laying flat. Years ago when i had floor joists overhead in my basement I'd suspend the planes from the joists using a rope to hold them in place. One end of the rope would be nailed in place using a heavy duty staple. The other end I'd tie a loop which would slip over a nail on the other joist. Worked great.
Best of luck.
Kurt
kzimmerm is offline Find More Posts by kzimmerm
Old Feb 26, 2013, 09:57 PM
Bob from MD is offline
Find More Posts by Bob from MD
I fly wood.
Bob from MD's Avatar
United States, MD, Columbia
Joined Jun 2009
I use peg board and 10 inch hooks. I put foam pipe insulation on the hooks. The lighter fuses I hang vertically from the stab. Heavier fuses I hang horizontally. The wings are set on top of a pair of hooks set an appropriate distance apart. I am in the process of storing/transporting wings in sleeves sewn from old sheets.
Bob from MD is offline Find More Posts by Bob from MD
Old Feb 27, 2013, 03:52 AM
Graham 65's Avatar
Chipping Norton, UK
Joined Jul 2006
Bob that looks very tidy indeed, sleeves are good for keeping thinks clean and reducing hanger rash.
Kurt, I like the ceiling idea as I have a high ceiling to work with. Maybe attach some battons and hang wings from straps?
Old Feb 27, 2013, 08:22 AM
LudwigB is offline
Find More Posts by LudwigB
LudwigB's Avatar
South Africa, GP, Pretoria
Joined Jan 2012
Mine is similar, but I bag as many as possible due to dust in an old house. Keep them high up and off the ground - away from kids, dogs and vacuum cleaners!
LudwigB is offline Find More Posts by LudwigB
Old Feb 27, 2013, 10:13 AM
scaflock is offline
Find More Posts by scaflock
I need some building time in t
scaflock's Avatar
United States, AZ, Douglas
Joined Nov 2007
LOL You know Bob.... If the old saying that "A clean shop is a sure sign of a sick mind" is true, then we really need to get you some help! That thing is spotless! Even with a dust recovery system mine is NEVER THAT clean!
scaflock is offline Find More Posts by scaflock
Old Feb 27, 2013, 07:02 PM
kzimmerm is offline
kzimmerm's Avatar
Montrose, NY
Joined May 2003
You have the right idea... The rafter space works great because it keeps things out of the way.
Best of luck....
Kurt
ps.. post pictures.
Old Feb 27, 2013, 11:15 PM
I fly wood.
Joined Jun 2009
Not to worry, I'm fine. This is the normal state of my shop. The camera doesn't have enough resolution to show the layer of dust nor the paint and glue spills on the floor. The previous pictures were taken just after I finished setting up the shop. I took them knowing it would never again be so clean.
Old Feb 28, 2013, 01:51 PM
whacker is offline
Find More Posts by whacker
whacker's Avatar
Canada, NS, Tatamagouche
Joined May 2005
Hang them from the ceiling, some of the hangers are held up with rope run thru a couple pulleys and cleated at the wall, that way I can get them up a little higher
1 hanger style for all types
whacker is offline Find More Posts by whacker
Old Feb 28, 2013, 06:33 PM
Lbuff1 is offline
Find More Posts by Lbuff1
TEAM HORIZON
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
Gliders or sailplanes?
Here's how I store the large sailplanes.
Lbuff1 is offline Find More Posts by Lbuff1
Old Mar 02, 2013, 06:44 PM
CoolCanuck is offline
Find More Posts by CoolCanuck
CoolCanuck's Avatar
Canada, BC, Kelowna
Joined Jun 2006
I hang most fuselages and wings on straps using hooks and some cheap fabric straps.
Wings are hung L.E. down.
The heavy scale fuselages are kept in cradles. Most stuff in bubble wrap "bags".
Some are kept in storage "bags" attached to a broom-stick handle for easier transport to the field.
Everything neatly stores on shelves in my "storage room".
yea, I've got too many, but then again...
CoolCanuck is offline Find More Posts by CoolCanuck
Old Mar 05, 2013, 02:30 PM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Storage method
Hi,
I have been known to occasionally store one in a multicolored plastic bag in a tree. Sorry Just had to go there!
I just bought a cheap furniture dolly at harbor freight. I'm making a rolling airplane rack ,fuses on one side wings on the other, charging eqip between. I will expand the width and length of the small dolly to approx 30" x 24".
ozmo01 is offline Find More Posts by ozmo01
Discussion What do you store your lipo's in?? two-stroke Batteries and Chargers 83 Jun 21, 2015 02:46 PM
Discussion How do you store/display your copters ? mskeyspirate Electric Heli Talk 23 Mar 03, 2013 04:15 PM
Discussion how do you store your foamies? swampflyer 3D Foamies 16 Feb 09, 2013 12:24 PM
Discussion do you store your lipos ? fastfwd Electric Plane Talk 27 Jan 19, 2013 06:09 PM
How do you store your sailplanes? gasbag floater Thermal 24 May 27, 2005 05:57 PM
