| Thread Tools |
| This thread is privately moderated by GLieberman1989, who may elect to delete unwanted replies. |
Skywalker 1680mm ardupilot-UAV
I started this project back in September with FPV flying in mind but have step-by-step working into making it a full UAV.
My build covers photos from the construction process and components I decided to include. As of this point in time my Skywalker platform contains the following UAV-FPV components:
Ground station components:
The electronics package includes:
Background To start the project I purchased a v5 Skywalker airframe and used the HXT 9 grams and hobbyking 30 ESC i had from another plane. The pan/tilt mechanism I purchased from readymadeRC.com which has a great selection of parts for common FPV platforms (skywalker, bixler, etc.)I bought the 5.8 Ghz transmitter and FatShark predator video goggles from Hobby King along with the motor for the plane. I have not yet flown the air frame, and I know it's not a good idea to start out complex on any system (KISS). I have, however, had some experience with FPV. I used the same goggles, GoPro, and video transmitter on a friends plane, and ANX clouds fly, with great results. Range of the video system seemed to far exceed that of the Spektrum dx6i I used from my few testing flights around my local field. I must say that flying FPV for the first time was an amazing experience! My first FPV flight was from hand launch all the way to landing. I had originally thought that I'd lose my sense of depth making landings a challenge but from my experience that wasn't at all a problem.I know this project will be a very long process with a steep learning curve, but I do not intend on rushing anything. Hopefully my previous experience with FPV and remote control aircraft in general will help me along in this adventure. --------------------------------------------------------------- 2/26/2013 Update The airframe has been upgraded w/ landing gear and a new paint job as well as a new wing mount method and a GPS hard point mount. Ardupilot, telemetry, OSD, and current senors have all been connected and configured and ardupilot loaded with the skywalker parameters. I am currently working on connecting the Turnigy 9X witht the EzUHF system which requires the 9X to be updated to a higher PPM frame rate. The default framerate of the 9X is 20.5 I believe, but dont quote me on that. The EzUHF requires at least 22, or maybe it's 22.5. In any case, the er9X firmware has an adjustable PPM. The firmware upgrade uses er9X open source. I will document my firmware upgrade when the hardware components of the 9X build arrive in the mail!
Turnigy firmware update
I'm now in the middle of the soldering for the firmware upgrade. It's a pretty straight forward deal thanks to this video i found while surfing the web.
Extremely helpful! --------------------------------------------------------------- 3/5/2913 Update I finally got the 9X flashed w/ the er9X firmware! The update was pretty straight forward but i did run into a few minor problems along the way, starting with the USBasp board. While attempting to flash the firmware to the 9X i was prompted with an error saying that AVRDUDE reported a connection fault with the TX. A quick search on the web revealed that a resistor pack (R8) on the USBasp board was to blame. Apparently some USBasp boards come with 100 ohm resistor packs and can work, but mine came with a 200 ohm pack and thus reported this error. The fix involved simply removing the resistor pack and putting jumper wires between the connection points. My only note on this was that some VERY precise soldering was needed. After the soldering was finished the firmware update went flawlessly. My second minor problem I encountered was getting channels 5-8 to work on the er9X. I didn't realize that they were not activated on the transmitter but soon found the mixing menu and the rest was pretty straight forward. So as of now, I've got my ground station communicating via 3DR telemetry to APM, have the fail safes set for APM (both GCS and RX fail safes), Skywalker parameters loaded, level set, control surfaces and ESC calibrated and have the 3 position switch on the transmitter set to "manual", "stabilize", and "RTL", and finally i have my OSD functioning (but it still need minor adjustments as some data overlaps the data the GoPro sends out). I did encouter one thing that needs to be looked at a bit further; my elevator servo seems to be glitching/chattering even under no load. I'm not sure if its the UHF/APM system (which is strange because the other servos seem fine) or if the servo simply needs to be replaced due to a bad pot. in any case, I will be running a "diagnostic" to see what the problem is. I am rapidly approaching first test flight of the APM system but will be double, and triple checking all components and reading as much material on the APM as I can beforehand.
More UAV testing
Update 5/5/2013 On my friend's request I took the UAV out again today to give a little demonstration. It was pretty overcast today and the GPS signal was intermittent at best. the mavlink also thought the plane was about 1/2 mile away from it's actual location (again, GPS problem). The plane flew great, and even w/ the GPS acting up RTL still worked great! (although the plane flew to the home location but continued heading south without going into loiter) I let my friend use the goggles and pan/tilt around a bit. Video of the few flights today is compiled in the video.
--------------------------------------------------------------- Update 5/6/2013 The GPS was again causing problems today and deciding to not lock with any satellites while indoors. I've not had a problem with this before, but for some reason I had to take my entire setup onto my front patio in order to get a satellite lock. Even then, the lock was to 6 satellites and it was off by about 50 meters. Hopefully i can figure out how to avoid this problem for future flights. It could be entirely possible that my Vtx or UHFrx are interfering w/ the GPS unit. |
| Thread Tools | |
| For Sale ArduPilot OSD MinimOSD and other items for ArduPilot Mega | Ecibob | Aircraft - Electric - Multirotor (FS/W) | 5 | Jan 17, 2013 10:59 AM |
| Yippee! Skywalker+ArduPilot+TLRS+EpiOSD = :) | nyc863 | Video Piloting (FPV/RPV) | 5 | Oct 24, 2012 12:57 AM |
| Discussion ArduPilot - Arduino Compatible UAV Controller w/ ATMega328 | DeadTom | Multirotor Talk | 5 | May 18, 2012 09:23 PM |
| Discussion Servo and Motor for Skywalker FPV 1680mm? | garik111 | Video Piloting (FPV/RPV) | 0 | Dec 03, 2011 04:11 PM |
| Cool Complete Ardupilot + UAV platform for sale. | Hooks | UAV - Unmanned Aerial Vehicles | 0 | Feb 17, 2010 03:54 AM |
