Old Feb 26, 2013, 12:28 AM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
Build thread for V-22-esque Bicopter with full transition capabilities
I've actually started building my next bicopter. I'll admit, it has temporarily distracted me from some of my other endeavors, such as my cube. I need at least a couple projects going at the same time so that I don't get burned out on a single one.
Anyway, this build will will be able to rotate the nacels a full 90 degrees, which each have their own tilt mechanism. I splurged and bought a couple of the prebuilt pivots from hobbyking.
Parts list will be kept here, on pinterest
I actually busted out the frame a lot quicker than I thought I would be able. My goals for this build are also to make it more modular, and less hot glue. I want to be able to fix things a lot simpler.
ilektron is offline Find More Posts by ilektron
Old Feb 26, 2013, 12:29 AM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
reserved
Old Feb 26, 2013, 01:22 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
Subscribed...
nadine is offline Find More Posts by nadine
Old Feb 26, 2013, 03:16 PM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
nice!
foam and tape is offline Find More Posts by foam and tape
Old Feb 26, 2013, 04:29 PM
v22chap is online now
Find More Posts by v22chap
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
keep the pictures coming and good luck
v22chap is online now Find More Posts by v22chap
Old Feb 26, 2013, 04:34 PM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
Will do and thanks!
My goal would be to have this in the air by the multirotor event in North County San Diego in the end of March. (Even though it is not eligible for the pylon racing event )
Old Feb 27, 2013, 07:53 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Do tell more about this Multirotor event? Hmmm
rimshotcopter is online now Find More Posts by rimshotcopter
Old Feb 27, 2013, 09:10 PM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
http://www.rcgroups.com/forums/showthread.php?t=1700292
March 23-24 in Fallbrook. Although I won't be able to compete in some of the competitions, I was hoping to at least get a working bicopter to take and show off (and show all those octos out there that they have too many motors )
Old Feb 27, 2013, 09:26 PM
Joined Aug 2009
Awesome, and thank you.
Old Mar 02, 2013, 12:04 PM
VTOLkarthik is offline
Find More Posts by VTOLkarthik
Joined Feb 2013
wow nice.... i have done the same kind too but mine was tilt wing and now am confused whether to do tiltrotor or tiltwing...i too had the same linkage for tilting mechanism....so tell me are u using gyros or wii board for stabilizing??
VTOLkarthik is offline Find More Posts by VTOLkarthik
Old Mar 02, 2013, 12:39 PM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
I actually built my own flight controller that uses an L3G4200 gyro and an NXP LPC1343. The firmware is all custom, too. It uses FreeRTOS. One of these days i'll post it somewhere.
Old Mar 05, 2013, 04:30 AM
nadine is offline
vtol fan
nadine's Avatar
Joined Jul 2009
Ilektron,how do you intend to use kk board,in this project!?
Hovering and transition!?
Old Mar 05, 2013, 09:27 AM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
I'm actually torn. I have a KK and will either put it in this or my cube. The problem is, I don't have an AVR programmer to modify the firmware. I need to pick one up before I decide which FC I put in it, otherwise I'll default to my own.
Old Mar 05, 2013, 10:15 AM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
Slowly piecing this thing together. Unfortunately my day job is currently occupying a large portion of my time which means I have less time to work on this.
Old Mar 09, 2013, 11:37 AM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
A little more progress. Hopefully this weekend I'll get the motors and landing gear mounted. I expect the AUW to be around 500g. A little heavier than I had hoped, but should still have around 1200g of thrust. Should be good.
Help! Need help with bicopter build! vgorkum Scratchbuilt Multirotors 33 Feb 19, 2013 03:54 AM
Full Ultrafly Hawk build review with scale mods thread. bipeflyer Pusher Prop Jet Models 99 Sep 20, 2012 02:47 PM
Discussion V-22 Ideas for Smooth Transitions Haden VTOLs 10 Jan 18, 2008 09:06 AM
Build Thread for the new Topaz-e (full house version): ORANATOR Electric Sailplanes 23 Apr 28, 2005 01:20 PM
22.5 inch Sirocco With CD ROM build thread power 3D Flying 119 Feb 13, 2005 02:56 PM
