Old Feb 25, 2013, 11:46 PM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Need help with Life
HI Guys, I need help with a life battery set up. I have chosen the Redwing 2100mah 2s (seen here > http://www.redwingrc.com/index.php?m...products_id=42 )
It has 3 leads. A Deans plug. A JR type plug with just 2 leads in it. and a balance port lead.
It charges up on my 4 station shop charger using the balance lead and Deans lead. However I want to mount it in the plane and use an external charge port with JR type lug.
This will mean charging without the balance lead connected. I have read conflicting reports.
Will this battery be okay just charging and drawing off of the JR plug?
The battery is way over sized and the plane has only 5 Futaba S3004 servos and glow motor.
Thanks in advance for your input on the Life batteries, this is my first.
scootrb4 is offline Find More Posts by scootrb4
Old Feb 26, 2013, 05:38 AM
AA5BY is offline
Find More Posts by AA5BY
AA5BY's Avatar
East Texas
Joined Aug 2007
It will be fine using the JR plug in your installation but the jury is still out on how often a balance charge should be performed. You might wish to obtain some 2S balance extensions and add one to the installation to make the balance port accessible for a monthly balance charge.
AA5BY is offline Find More Posts by AA5BY
Old Feb 26, 2013, 06:01 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I balance charge all the time. I simply use an extension for the balance plug. The RX servo JR plug works fine with a On/Off switch. So I can charge externally no problem.
earlwb is offline Find More Posts by earlwb
Old Feb 26, 2013, 07:34 AM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
I have used 2 cell LiIon for a few years now and don't balance no problems...I maybe wrong but balance seems like a bit over kill on a 2 cell pack
jetmech05 is offline Find More Posts by jetmech05
Old Feb 26, 2013, 07:58 AM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
While I religiously balance charge my lipos (3-5s) I cannot balance the Nicad or NiMH in my other gas planes and they seem okay.......
I have read that 2 cells can't get that far apart given the relatively low discharge rates involved. 3.3 full to 2.5v max discharge ever.
I suppose I could do a maintenance balance charge with the wing off once a month? I tend to leave these 50 size planes assembled.
What about the battery break-in question? I read the first 20 cycles should not discharge the cells below 3.2v or the cells may not reach their full potential.
6.6 to 6.4v discharge?
What is a the suggested discharge limit after break-in?
Old Feb 26, 2013, 08:03 AM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
Do you just leave a pigtail hanging out or is there a receptacle for the balance plug? Thank you for your input. I know a balanced charge may be a safer bet but, I'm not sure it is needed.
Old Feb 26, 2013, 01:15 PM
FloridaFlyBob is online now
Find More Posts by FloridaFlyBob
FloridaFlyBob's Avatar
United States, FL, Fort Myers
Joined Nov 2011
I'm glad you had a ? on batteries and not the Facts of Life. lol I got 2 lion batteries from troybuilt models and they say its ok to charge without the balance but suggested doing a balance charge once in a while. I put a hatch on the bottom and the battery slides out the bottom
FloridaFlyBob is online now Find More Posts by FloridaFlyBob
Old Feb 26, 2013, 08:09 PM
whitewolf is offline
Find More Posts by whitewolf
Dana, Indiana
Joined Jan 2007
This is a charge lead that will balance charge through a JR charge port, you would have to do a little wiring to get it set up and would not be able to use the JR bind function when modifications are done to the port. http://www.electrodynam.com/store/product295.html
The signal wire is used as the third balance connection at the JR plug and if the switch has thee wire to the Rx the signal wire to Rx has to be cut to prevent sending voltage to the signal side. When making up the charge lead the power wires are connected to the plug in normal configuration and the balance leads is tied to the signal pin at the charge plug, the charge cord is made up from a two lead banana plug set and a 2S extension and wire spliced to matching leads.
I use this set up to balance charge my on-board LiFe/A123 packs every time, it does give you the opportunity to monitor cell performance to prevent a failed pack.
whitewolf is offline Find More Posts by whitewolf
Old Feb 27, 2013, 12:03 PM
600Bob is offline
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
I bookmarked this hull penetration charging jack, never used one and it's not cheap but something for you to look at.
http://www.rcaircraftcomponents.com/...asp?ProdID=713
600Bob is offline Find More Posts by 600Bob
Old Feb 27, 2013, 03:30 PM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
I built a Sig Hog Bipe that I never take apart. (to much trouble). I have a 2cell 2650 mah A123 life battery in it.
I always balance charge my batteries. SO, I just added a balance lead extension to the batteries balance lead and mounted the balance jack just below my charge jack in the side of the fuse. I used a extra switch plate I had laying around and epoxied the balance plug into it. Then just mounted the plate/jack to the fuse. Now I can balance charge without taking the plane apart. Works great
It is the white thing just below my switch. I keep a rubber rod protector over it.
tacx is offline Find More Posts by tacx
Old Feb 27, 2013, 07:08 PM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
Sweet looking little Hog tacx, Both good solutions there. I went ahead with a conventional switch /charge port but I may add the balance plug as shown. Thank you
Old Feb 27, 2013, 08:14 PM
AA5BY is offline
AA5BY's Avatar
East Texas
Joined Aug 2007
As two cell packs gain popularity we may see Dubro or someone offer a port to plug the inside extension to.
Old Feb 27, 2013, 08:35 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
+1 Hope they read this thought. Bet it will sell well.
Fokker DII is offline Find More Posts by Fokker DII
Old Feb 27, 2013, 08:39 PM
AA5BY is offline
AA5BY's Avatar
East Texas
Joined Aug 2007
I just emailed the suggestion to Du-Bro.
Help! Need help with my FPV uav project. Soren64able Engines 9 Feb 02, 2013 04:00 PM
Help! Need Help with Soldering Electronics Neil Morse Life, The Universe, and Politics 41 Jan 11, 2013 03:51 AM
Question Need Help with a Spektrum Radio Buddy Box Question gabrielisrael Electric Plane Talk 15 Jan 07, 2013 08:45 AM
Discussion I need help with Camera project briwhittle FPV Talk 8 Jan 06, 2013 01:32 PM
Discussion Need help with batt esc and motor combo muhkaydenz Power Systems 5 Jan 06, 2013 08:46 AM
