Old Feb 25, 2013, 09:46 PM
magno_grail is offline
Find More Posts by magno_grail
Joined Nov 2012
Question
Tail Rotor Shaft size
Hi All,
I am looking into building a multi-rotor using 450 main rotors but since I do not need cyclic I wanted to substitute a tail rotor pitch control for the swashplate. The 450 main shaft is 5mm, does anyone know which helicopters use a 5mm tail rotor shaft?
I tried posting this on the VTOL forum but is seems they all use propellers, not rotors.
Thanks.
magno_grail is offline Find More Posts by magno_grail
Old Feb 26, 2013, 04:54 PM
flyalan is offline
Find More Posts by flyalan
flyalan's Avatar
United States, TN, Nashville
Joined Aug 2003
I do know that the original Synergy N5 used a 5mm tail shaft. They were later upgraded to 6mm but the 5mm hardware is still available.
Alan
flyalan is offline Find More Posts by flyalan
Old Feb 28, 2013, 01:12 AM
Joined Nov 2012
Thanks, I will check into it. I found the Trex 600 manual lists part sizes and it uses a 5mm tail rotor shaft also.
Discussion 250 tail rotor shaft size and speed Ken59 Electric Heli Talk 11 Feb 10, 2013 11:33 PM
Discussion Hobbyking tail rotor shaft 42.8mm - cheap extended tail rotor shaft Atomic Skull Mini Helis 2 Sep 29, 2012 02:01 PM
Discussion Question: T-Rex V2 - Tail : Tail Rotor Shaft/hub/Set Screw Santini Mini Helis 4 Apr 09, 2008 11:03 AM
Tail rotors - shaft driven versus seperate tail motor driven prop JohnM Micro Helis 2 Jun 10, 2004 12:15 PM
Tail shaft size on the Zoom? Final output ratio for it as well vs main shaft? Admiral_Red Mini Helis 1 Jun 08, 2004 04:40 PM
