Old Feb 25, 2013, 09:33 PM
Dmerino is offline
Find More Posts by Dmerino
Pollock Pines, CA
Joined Aug 2002
FJ1 Fury Collaboration
I'm starting a new build thread. I"ve asked Corsair Nut to collaborate on this model since I am really a neophyte when it comes to EDF's. Besides, who could pass up an opportunity to work with the "Nut". I'm hoping she turns out good. I;m going to be using the same technique as the Skynight I just finished.
I'm attaching some layouts and pics.
Peace, guys.
Dennis
Dmerino is offline Find More Posts by Dmerino
Old Feb 25, 2013, 09:38 PM
Dmerino is offline
Pollock Pines, CA
Joined Aug 2002
Some PDF layouts of the Fury.
Old Feb 25, 2013, 09:53 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Cool subject, I like the first generation of jets.
Look forward to seeing your model come alive.
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Old Feb 25, 2013, 10:32 PM
Dmerino is offline
Pollock Pines, CA
Joined Aug 2002
Thanks, Eric.
We'll keep you posted.
Dennis
Cheers,
Eric B.
Old Feb 25, 2013, 11:08 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Cool..looks like a fiddlersgreen kit! see my avitar
Old Feb 25, 2013, 11:29 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
how big ? 70 or 90mm fan ? i could help with ducts
AIR SALLY is online now Find More Posts by AIR SALLY
Old Feb 26, 2013, 12:50 AM
p901P901 is offline
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Duct interference problem
Just contour the top of the wing between the saddles to fit the duct. Have you done weight and balance on this? The fan may be set to far back for CG
p901P901 is offline Find More Posts by p901P901
Old Feb 26, 2013, 01:15 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
On the PDF he has it as a 4" fan. To me, way to big a fan for that scale. Even at 1/9th its not that big, but big enough for a JF90!
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Feb 26, 2013, 01:21 AM
Dmerino is offline
Pollock Pines, CA
Joined Aug 2002
Hi, turbonut.
It is a "Fiddlersgreen" model. It will have some refinement from the canopy forward. The model is not one of their bests and doesn't fit together very well, but I hope to fix that.
Dennis
Old Feb 26, 2013, 01:23 AM
Dmerino is offline
Pollock Pines, CA
Joined Aug 2002
The duct-work would be great, AIR SALLY. I put a 4" fan in the plane (Mainly due to inexperience) and am hoping Nut or someone will suggest an appropriate size, if this is wrong.
Dennis
Old Feb 26, 2013, 01:26 AM
Dmerino is offline
Pollock Pines, CA
Joined Aug 2002
Great suggestion, p901P901. I think the fan unit can be moved forward and miss the wing. Also, it may wind up with a smaller fan than 4". Some feel this size is too big for this bird. I'm just too inexperienced to know better. After saying that, the thought struck me that turned lose I could be dangerous.
Peace, Guys.
Dennis
Old Feb 26, 2013, 01:27 AM
Dmerino is offline
Pollock Pines, CA
Joined Aug 2002
Thanks for the input, CoolerByTheLake. I would be happy with a 90mm in there to pick up some room.
Dennis
Old Feb 26, 2013, 02:06 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
heck a 80mm might do .what are you making it out of ? foam?
Old Feb 26, 2013, 04:27 PM
Dmerino is offline
Pollock Pines, CA
Joined Aug 2002
Thanks, AIR SALLY.
I will be making it in the standard format I use, like the Skynight build. I four color print onto a large bond paper format (13" X 44"). Once the fuse., wings, stabs, etc. are all printed. I laminate down to 1 mm extruded foam on the fuse parts and either 3 mm or 5 mm foam on the wings, stabs, etc. I cut out the foam and roll form it into the needed shapes for the fuse. Usually, for the wings and stabs I cut out the shape and roll form an airfoil into the part. I use 3M spray adhesive to glue the paper down. It makes for a very fast build, but you must be careful with the exterior since it is already in its finished state. I glass the insides of the fuse, sections of the wing, etc. where strength is needed. This will pretty much be the way this Fury will be built. I'm going to ship it to your boy (You must bust buttons over him. You did a great job raising him.) in sub-assemblies for the the EDF portion, your duct work, etc. I'm going to attach a couple of photos of my Kiwi A-4 showing a portion of how it works.
Thank you for all the encouragement you give to all of us.
This is truly a great bunch of guys.
Peace,
Dennis
Old Feb 26, 2013, 06:03 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yeah he does tend to make me proud .... i'll go and ck out when it gets there . this is a simple plane ,i bet we could just roll a pice of sheet fiberglass to make a duct.too bad they dont make flexable paper ,it would make your building easier.wonder if you could print on some kind of palstic
Help! Robotics/UAV collaboration- Vermont savagejay Robotics 2 Aug 05, 2013 03:57 PM
Sold Aerotech International Hawker Sea fury kit pilotorc4 Aircraft - Fuel - Airplanes (FS/W) 3 Jan 19, 2013 04:33 PM
Sold KMP Hawker Sea Fury 71" Upsibackward Aircraft - Fuel - Airplanes (FS/W) 5 Jan 07, 2013 07:58 PM
Sold xcell fury 90 helicopterdr Aircraft - Fuel - Helis (FS/W) 1 Jan 04, 2013 11:55 AM
Crash Video Collaboration... So Far. LI-Audio 1 Parkflyers 3 Mar 07, 2003 07:30 PM
