Old Feb 25, 2013, 08:11 PM
clive_fox is online now
Find More Posts by clive_fox
Australia, NSW, Sydney
Joined Jul 2002
Help 1st setting up Phoenix with Cockpit SX
Got my Phoenix today but will not be getting my radio and adapter till tomorrow.
What needs to be done to the radio, a Multiplex Cockpit SX, to make it all work. After it is plugged in do I need to do anything like select and setup a new model or anything else or is it all just plug and play.
clive_fox is online now Find More Posts by clive_fox
Old Feb 27, 2013, 03:09 PM
mattcro is offline
Find More Posts by mattcro
KK Tri Flyer
mattcro's Avatar
United Kingdom, Scotland, Glasgow
Joined Feb 2012
Phoenix has presets for common Spektrum, Futaba, JR, Hitec radios but no Multiplex AFAIK, so you'll probably have to set up a new "profile" for your TX. . This basically involves selecting which channels/switches perform which functions. You also calibrate Phoenix to set the range of each channel. Pretty straightforward.
NB you need to set you radio to acro/plane mode, or disable any swash mixing CCPM so that all output channels are independent. All the mixing is done by Phoenix.
mattcro is offline Find More Posts by mattcro
Old Feb 27, 2013, 04:31 PM
Joined Jul 2002
Interestingly Phoenix says to set up as a Heli. But when I get it working will try both
Old Feb 28, 2013, 03:26 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
. Crosspost Answered (Thread has 2 pages.)
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Mar 02, 2013, 03:32 PM
mattcro is offline
KK Tri Flyer
mattcro's Avatar
Joined Feb 2012
You can use heli or plane/acro mode. I use my DX6i in heli mode with Phoenix, which lets me use the heli type functions of the TX such as idle-up and throttle hold.
However, you can also Set phoenix up to handle these functions itself, and use your TX in acro/plane mode.
Old Mar 02, 2013, 06:14 PM
Joined Jul 2002
Thanks got it working with a friend's DX6i but not my Multiplex - subject of another thread.
Discussion need help with twin motor thrust set up Rhondas Electric Plane Talk 9 Jan 27, 2013 06:48 AM
Discussion Help with this tx/ fpv set up soccer du25 FPV Talk 52 Jan 14, 2013 11:16 AM
Discussion Help with led set up. rkenosha Night Flying 3 Jan 10, 2013 06:03 AM
Discussion Cockpit sx set up ( not 2.4 ) mrdoodah Hand Launch 14 Sep 20, 2010 03:35 PM
Question Please help with Flash 5 SX set-up darrell_f Hitec/Multiplex USA 1 Feb 04, 2004 11:47 AM
