Old Feb 25, 2013, 07:44 PM
viper1 is online now
Find More Posts by viper1
viper1's Avatar
Melbourne, Australia
Joined May 2006
Build Log
Hornet Formula-1 Tunnel Hull, The perfect Upgrades ??
Big call....Is there such thing as the perfect upgrade? I think not, and you probably won’t hear it from me.
When it comes to FE boats I’m just a rookie but given my background in scale aircraft modeling I don’t mind modifying my new ‘not-so-perfect’ toys straight out of the box. Actually I enjoy it as much as playing with them.
That’s one of the reasons I got his boat, a challenge to make it better.
I always wanted a F1 tunnel hull. There are way better hulls and kits out there with higher price tags. And arguably in the long run could even be cheaper then modding a boat straight out the box. But hey, where’s the fun in that?
I will cover the hull modifications and drive upgrade(s), and keep useful changes and updates in the first pages in this thread if possible for easy reference.
Hopefully this will become a good info source, centralized in one place, to save prospective owners from browsing all over the net for hours.
There is enough info spread among different forums of the shortcomings and flaws of the standard equipment this boat comes with out-of-the-box but I will cover these as the build comes along.
EDIT: here is the before and after (tricked photo),
for more pics of the end result skip straight to this post:
http://www.rcgroups.com/forums/showt...5#post25175659
viper1 is online now Find More Posts by viper1
Old Feb 25, 2013, 07:45 PM
viper1's Avatar
Joined May 2006
Goals;
1) Reliability: covering hull reinforcement, installed equipment and outboard upgrade.
2) Speed: for now 45-50 Mph -70 Km/Hr would be nice….. we’ll see
3) Looks: Have you ‘read’ the stickers on this boat ??
Plans so far in my wicked mind to achieve that;
A) Carbon fiber on the hull bottom in center section (radio box)
B) Transom reinforcement, Aluminium Edit: Carbon sheet used
C) Make a proper radio box with good seal, easy accessible.
D) Make a scale looking outboard cover for the motor that’s also water-proof, I don’t like the idea of a motor submerged in water after a flip.
EDIT: A lot less complicated in the end was to make the motor waterproof and just let the outboard flood with a mishap, As the motor is a inrunner this was easier. A large drain hole in the outboard cover, and servicing is a lot easier now than sealing everything up.
Installation in the planning so far:
ESC : Turnigy Marine/Seaking-120A
Motor: Turnigy SK3 Fandrive - 3659-1900kv (This was the initial installation in my Genesis Offshore, good for 100Km/hr on 6s. Great motor but not tested on lower cell-count.
Outboard: Either O.S. Lower leg, or Hyper Performance 3.5 Bullet Outboard. Both are on order (don’t ask…) will decide what suits better when they are here.
EDIT: After having both units on my desk, the decision leaned towards the O.S. unit, better quality and with potential future changes of hulls in mind, I find this to be the overall better unit.
viper1's Avatar
Joined May 2006
Take off !
Box contents:
Removed the R–clips studs > support the Fiberglass and a slight tap with a hammer they pop right out.
Also removed the battery tray (lifted right out putting my pinky under it…so much for gluing)
The light-ply at the transom is also removed, used a dremel to clean up.
Now we have something to work with, so to speak.
Note that glue is not removed yet in the photo.
Old Feb 25, 2013, 07:46 PM
viper1's Avatar
Joined May 2006
Don't Split....
Although the fiberglass doesn’t look bad, keeping the price in mind, close inspection of the seam between hull and deck showed some gaps on inside.
I poured some laminating epoxy resin in and let it run along the seam, one side at a time (let it harden in between)
Hard to photograph using a mirror, but you’ll get the idea.
As the sponsons won’t be accessible later it’s a good time to do it now. Maybe not necessary but better for my piece o’ mind
Old Feb 25, 2013, 07:47 PM
viper1's Avatar
Joined May 2006
New Carpet ....
Added some carbon fibre on hull bottom about 4” / 10cm wide, not worried about the edges, next step will be closing off the sponsons so this will not be visible. In hindsight I could have used a finer weave CF cloth, this is not the neatest job I’ve ever done.
Also put a layer against the transom.
Old Feb 25, 2013, 07:50 PM
viper1's Avatar
Joined May 2006
Reserved for more pics...
Old Feb 27, 2013, 08:57 AM
Simoc is offline
Find More Posts by Simoc
Simoc's Avatar
Australia, QLD, Redcliffe
Joined Feb 2013
Hi Viper 1. I'm having great fun with mine but using the heli motor with 6s. I've been told 4s will give you 80kph with the Fandrive and controlling it is fun at that speed. You need to keep the front down somehow.
Simoc is offline Find More Posts by Simoc
Old Feb 27, 2013, 11:48 AM
viper1's Avatar
Joined May 2006
'The' heli motor ? is that an outrunner?
Been told ? or seen it?
If they run 80 k's with 1900kv on 4s, they must be running a 47 mm prop or more, I would like to see that first on this hull before I would spread the gospel....
The speed estimate tool on OSE is a good tool to get a rough idea for speeds and setup.
Old Feb 27, 2013, 05:04 PM
viper1's Avatar
Joined May 2006
Make-A-Box
From light plywood I cut the following shapes, they function as side walls for the radio box, closing off the sponsons at the same time.
Before gluing them in, I waterproofed them with epoxy resin on both sides.
Old Feb 27, 2013, 08:10 PM
Amp Abuser is offline
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
Hornet F1 Tunnel hull mods and test runs (9 min 22 sec)
Here is a 1,600W upgrade info with running footage for idea's
Amp Abuser is offline Find More Posts by Amp Abuser
Old Feb 28, 2013, 10:51 AM
paultbg is online now
Find More Posts by paultbg
paultbg's Avatar
United Kingdom, England, Birmingham
Joined Jul 2012
As always with that particular guy, he put a lot of power and no brain at all...I will be ashamed to show that kind of trimming / driving.Even worst, the beginners are following his advices....
paultbg is online now Find More Posts by paultbg
Old Mar 01, 2013, 01:57 AM
viper1's Avatar
Joined May 2006
Nobody's perfect Paul,
I took -some- advice from him and I don't regret it. True, anybody with a brain should be selective on what you take for advice and what not. Specially on the net.
I'm not following anyone blindly, but in the few things I did ask Frank he was quickly and helpfull with his reply. And yes he shows his 'misses' as well. And shows in follow-ups what he did wrong and how to fix it.
Unlike some self acclaimed specialists, that are hiding their mistakes, for me that makes him just human.
Just like your (Genesis) on-board videos, I'm always thankfull for anyone who makes the effort to make a clip.
Just my 2 cts
PS:
I'm just jealous because I lost my gopro in a genesis tumble months ago, and I'm still not over it...
Old Mar 01, 2013, 04:42 AM
Simoc is offline
Simoc's Avatar
Joined Feb 2013
Well since you follow him Viper you should know that he is the one who used the Fandrive on the Apparition and followed up with advice on the Hornet. And what does Paulbg bring to the table. Absolutely nothing. Critism is so easy for vacant humans.
Old Mar 01, 2013, 04:45 AM
Simoc is offline
Simoc's Avatar
Joined Feb 2013
And I'll follow that up Paulbg. Show us what you can do since you reckon you know. Otherwise it is apparent you're an imposter. Reckon you are not a beginner. Well you sound like one.
Old Mar 01, 2013, 05:35 AM
viper1's Avatar
Joined May 2006
OK, this is a build log, BACK TO TOPIC !
Discussion Hobby King tunnel hull boat bmwbob Racing Boats - Electric 20 Apr 24, 2013 04:08 AM
Discussion Steve Mucks Lil Lightning Tunnel Hull Hd rider Dock Talk 8 Feb 12, 2013 07:26 AM
Discussion Graupner Rhode Island Formula 1 Tunnel Chinewalker Racing Boats - Electric 2 Feb 06, 2013 08:51 AM
Sold Pro Boat 1/12 Scale Red Nitro Formula Hydro 2.4Ghz RTR Upgraded! PRB3200 $350 stretch1100 Boats (FS/W) 0 Jan 16, 2013 03:27 PM
