Can Multicopters Scale Up?
RCGroups user EddieWeeks wanted to find out if a tri-copter could scale up. This 13 lb. tri-copter has just over 5000 watts of brute power and seems to handle everything Eddie is throwing at it!
RCGroups.com user, EddieWeeks, tries out the "bigger is better theory."
"Starting with small 14 x 8 wood props, it almost lifted 16 lbs. (7.3 kg) on the first night of flying. It's very noisy and does not vibrate much at all. As time goes on I will be testing the efficiency of the whole system by measuring grams/watt in the hover. Once I know g/w, I will be able to calculate the proper number of batteries…all at 8S."
Join the discussion
There are no posts
Discussion HVSK-40A Multicopter Brushless ESC 40A (OPTO) can't be programmed? psindrup Multirotor Talk 6 May 09, 2013 05:37 PM
Discussion FPV on a budget? Hook me up if you can! Endlesslag FPV Talk 6 Jan 13, 2013 10:25 PM
Discussion Other places to pick up scale jets lardo5150 Electric Ducted Fan Jet Talk 12 Jan 11, 2013 08:48 AM
Discussion You can't make up stuff this good. seanpcola Life, The Universe, and Politics 45 Jan 06, 2013 03:02 PM
Can the "Micro-Racer" be scaled up to speed 400? Raytracer Foamies (Kits) 4 Jun 03, 2002 11:18 AM
