Old Feb 25, 2013, 02:02 PM
flysohigh is offline
Find More Posts by flysohigh
flysohigh's Avatar
Miami Fl
Joined Feb 2011
gearing question??
I have the losi scte truck and was wondering if switching from a plastic spur gear to a metal one will make any difference? Is this recommended? Also im currently running a 15/40 setup and see they also have 48t spur gear hiw will the 48t differ from the 40t? Will the motor temps rise or drop as opposed to the stock 40t?
flysohigh is offline Find More Posts by flysohigh
Old Feb 25, 2013, 02:10 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Metal spur should be more durable, but also a bit more noisy than metal pinion/plastic spur combination.
Usually increasing the teeth count on the spur gear will reduce motor load, and temps.
SoloProFan is online now Find More Posts by SoloProFan
Old Feb 25, 2013, 02:20 PM
flysohigh's Avatar
Miami Fl
Joined Feb 2011
So increasing spur gear tooth count will help lower temperature but how will it affect speed using same pinion gear?
Old Feb 25, 2013, 05:19 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
If you increase the spur gear teeth count but keep the pinion the same, the wheels will turn at lower rpm, so you will lose top speed, but gain on acceleration. Same applies when you lower the pinion gear teeth count and keep the spur the same.
Old Feb 25, 2013, 06:23 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Metal gears are stronger, but will wear more over time since it is metal on metal contact.
wparsons is offline Find More Posts by wparsons
Old Feb 26, 2013, 12:55 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Would lubrication help to prevent the faster wear? Assuming spur and pinion are shielded from dust etc, as grease and sand are no friends....
Old Feb 26, 2013, 01:08 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Possibly, but it'll likely just fly off with the speeds the gears are turning.
Old Feb 26, 2013, 02:20 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
A good grease should leave a small film on the gears, after the excess flies off. Recently I put some grease on the spur and pinion on my Lazer ZX Sport, and it made the transmission more quiet, and the car slightly faster. I had the same good experience 25 years ago, with the Optima Mid, never had to replace a spur on that car so far. But that is metal pinion on plastic spur, so different combination, but the gears spin at the same RPM.
Discussion short course racing/mamba max pro gearing question flysohigh Off-road Cars 6 Feb 14, 2013 11:50 AM
Discussion Gear or not to Gear, That's the question AMPLESS Power Systems 5 Mar 01, 2006 05:17 PM
Zoom Upgrade Questions: Blades, Landing Gear, and Tail Gears K.C. Mini Helis 4 Oct 05, 2004 12:03 AM
Hitech servo gear question will the hs81 metal gears fit into the hs81 Sloop Radios 3 Feb 02, 2004 03:58 PM
To gear or not to gear. That is the question 747drvr Power Systems 9 Mar 22, 2002 01:06 PM
