I like cables too. They tend to flex a little and thus have some give to them.
You may have had some bad luck in that the servo decided to die on you. It may have been a defect inside the servo. Maybe a little bit of loose solder moved around and got into something. Of course now that it smoked, it likely would be hard to tell for sure. But the little tiny motors have been known to fail every now and then. |
Latest blog entry: My Low Wing plane
If we reject everythng we have doubts about it can get out of hand. We should have a way of checking reliability with all items we use. I can imagine a fellow having difficulty tuning his engine and discarding it to buy another one and having the same problem . How about a singing servo (buzzing when not activated) due to a binding linkage? Throw out the servo and buy a new one that will also buzz. I would not replace a servo connected to a control surface that flutters. I would eliminate the slop on that surface. The way receivers are built these days I would trust it if it functions well as I said "on a properly done range test". Note that I am not the fellow that blames all crashes on the electronics Of course you are free to do whatever makes you comfortable. Zor |
new Taylorcraft throttle servo burnt up two min before maiden
Last week was going to be the maiden when the throttle servo burnt up ,, thought it was a reciever.. ar8000 spektrum comes installed from factory hanger 9 new 26cc taylor craft. when buy the BNF version. i was kinda surprised you know,, but glad it happened before i took off the ground.. HELLO! ..lol
installed new servo warranty from my LHS.. no issues have 3 flights in so far . |
One thought is if the engine still has the throttle return spring on it or not. Some carbs have a more stiff or strong spring and it can really strain a servo. A stiff spring causes the servo to have to push against the spring the entire time and that can cause a servo to burn out. it is almost like the servo is stalled against the stops while it is pushing against a stiff spring.
I have disabled the throttle return springs on my engines. I usually leave the spring on as a spacer so that the throttle doesn't jiggle around a lot. But usually you can flip the spring end off the throttle arm so it doesn't work as a spring return then. |
If the tests are successful, then mount it in a .40 size sport plane, and if that works out, move up in size until you'll confident there will be no issues with it. Another option would be to send it in to Hobby Services and have them inspect and test it. Hogflyer |
United States, NM, Holloman AFB
Joined Oct 2007
I didn't have a return spring, it was a stiff cable.
I don't have a "cheap" or "knock around" airframe. So by the time I buy a cheap airframe, build it, install everything, range check it, and see if it fails; I might as well of just bought a new receiver. If it were to fail on said "knock around" airframe and crash, then I would not only be out a receiver but also an airframe and whatever else gets destroyed. AR6210's aren't that expensive, I didn't need a 8ch I just had one laying around from a TX purchase. But back on topic; I was just trying to find out if an internally failed servo could in fact brown out a receiver even with it being on a LiFe pack rated for a 20A constant drain, and with it having 3/4 charge still in it. |
Jacksonville Fla.
Joined Mar 2007
I answered your question but you can always check with your squadrons avionics gurus good luck....by the way I didn't mean to sound like the blacks and red wires are all bussed together in the receiver....I meant that all the reds are bussed together then all the blacks are bussed together .... That's all the powers to the servos... And all the returns
| Thread Tools | |
| Discussion Throttle servos frying - cause unknown | grosbeak | Fuel Plane Talk | 48 | Jan 26, 2013 11:23 AM |
| Discussion How small can we get / deans marine | rondean1 | Scale Boats | 5 | Jan 06, 2013 09:36 AM |
| Discussion can bl motor be fried by 2 of the 3 motor wires touching | stingeragents | Power Systems | 7 | Jan 30, 2012 07:28 AM |
| Discussion mCX 5-in-1 board fried through short, where can i get the burned FET? | Bowerz | Coaxial Helicopters | 3 | Feb 10, 2010 01:38 AM |
| Question OT: Deep Fried Turkey- where can I get one? | Doubletap | Slope | 21 | Dec 18, 2007 11:35 PM |
