Old Mar 04, 2013, 02:52 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
These are 8" props. 9" props do not fit, I've tried.
WiseDuck is offline Find More Posts by WiseDuck
Old Mar 04, 2013, 03:01 PM
ecks is offline
Find More Posts by ecks
Knowledge prevents flyaways
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
I only left a few mm in between the 8 inch. I wanted this to be as small as possible for 8 inch props.
ecks is offline Find More Posts by ecks
Old Mar 04, 2013, 03:05 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Yep, I noticed that! I think the size is just right.
I just tested it inside my room, it hovers at roughly 60% or so with a 2200mah 3S lipo and no FPV gear. So it seems like 4S is what you want on this thing. Well, with these motors anyway. (DJI 2212 920kv motors)
Old Mar 04, 2013, 03:12 PM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
Strange, mine hovers around 50% with fpv on 3s, but I just ordered another 2650 4s as it screams on those!
The other thing I noticed is on high stick scaling it flips almost on the spot, I couldnt do that with the bigger frame.
Old Mar 04, 2013, 03:21 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Nah, it's not strange, you simply have more powerful motors!
I could put the Sunnysky 2216 1400kv motors on this one and it would take off like a rocket. But they can't be used on 4S and I have like 7 4S lipos here that I want to put to good use!
The 1800mah 4S Nanotech lipo I have here should be a good match for this one.
Old Mar 04, 2013, 06:45 PM
Breezemont is offline
Find More Posts by Breezemont
Joined Feb 2009
Originally Posted by Esevilaa View Post
wow that was quick!
Im changing the CNC program now. top left and bottom right rotate 90 degrees! headslap
Just cut slots and then all motors will fit any way they want.
edit: guess I need to read the whole thread.
Breezemont is offline Find More Posts by Breezemont
Old Mar 05, 2013, 03:08 AM
cruiser73 is offline
Find More Posts by cruiser73
cruiser73's Avatar
Singapore, Singapore
Joined Apr 2012
Cheers mate.
cruiser73 is offline Find More Posts by cruiser73
Old Mar 05, 2013, 05:20 AM
hoggdoc is offline
Find More Posts by hoggdoc
United States, CA, Huntington Beach
Joined Jan 2013
Originally Posted by symon View Post
Can you make these in carbon?!
Now there you go, but much more costly.
hoggdoc is offline Find More Posts by hoggdoc
Old Mar 05, 2013, 05:23 AM
hoggdoc is offline
Joined Jan 2013
Originally Posted by WiseDuck View Post
Bit of a progress report. Not quite as clean as your build. But I really can't be arsed to hide all the ESC wires. I'm going to ziptie the motor wires to the frame soon then hover in my room for a bit to see that everything is OK.
Wow nice clean build.... I like the raised board above the FC that looks like it would take a DJI GPS.
Old Mar 05, 2013, 05:54 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Thanks! It's even cleaner now. It's a polycarbonate cover that came with one of my Bambucopter frames. I use it to protect the FC. I'll go for an FPV flight later this week.
Old Mar 05, 2013, 06:07 AM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
It is clean. Is everything in place on that picture? I've still got a hobbyking pcb so hang that underneath with the transmitter inbetween (took the plastic casing of the tx). It's much neater than mine! Good job Wiseduck.
Where's your transmitter?
Old Mar 05, 2013, 06:38 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Everything is in a sandwich on top of the quad.
Bottom: power distribution board.
Next: FrSky 4ch receiver outputting PPM on top of the power distribution or board.
Next: Flight controller.
Top: polycarbonate cover.
Old Mar 05, 2013, 06:41 AM
achiii is offline
Find More Posts by achiii
United States, PA, Philadelphia
Joined May 2012
That looks nice wise duck. Certainly cleaner than mine will be.
Its soooo beautiful out today. Ive been taking breaks all morning to fly my hex in the backyard.
achiii is offline Find More Posts by achiii
Old Mar 05, 2013, 11:24 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
So an 850mah 4S lipo gives me about 5 mins of just hovering. The battery is quite warm after this and the Cellmeter says I have 7% left when I land at 3.5v or so. :P So yeah, definitely going to use a bigger battery on this one. Or just two of these, we'll see.
Old Mar 05, 2013, 04:06 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Alright, HoryzonHD and video transmitter have been mounted. It now looks like a proper rats nest. I doubt I can make this look pretty without a lot of work.
Because of the limited amount of motors I have this will most likely be turned into an acrobatic basher later on, my Bambucopter Y6 is still my preferred sub-300 sized rig for filming stuff and for flying in cramped places.
So expect a flight video within the next few days, since I'm also limited to the stock DJI props because of the stupid 8mm shaft on their motors you might see a crash too. The 8" props are supposedly far more sturdy than the 10" ones, but I've never put a big load on them. I will simply fly for as long as the battery will let me or I will fly until something breaks, I won't hold back.
Also, expect lots of jello... I have to use the floppy stock props, so the video might be complete shite. We'll find out soon.
For Sale MK ESCs (x8) V2.0 + MK FltCtl 2.1 ME + Droidworx octo frame V2 + Axi 2217 (x8) DanWalker.AK Aircraft - Electric - Multirotor (FS/W) 3 Aug 13, 2014 05:23 AM
Discussion HBFP Mk.I (v1) Frame and Boom Upgrade - V2 frame or King 2/3 Frame? rawfuls Micro Helis 1 Feb 21, 2011 06:07 PM
Discussion Trex 450 SE V2 frame vs. HDX 450 SE V3 G10 frame (super frame) richord Mini Helis 1 Apr 02, 2009 11:11 PM
