Old Mar 04, 2013, 06:01 AM
ecks is offline
Find More Posts by ecks
Knowledge prevents flyaways
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
talking about broken arms, I had my plaster taken off on Friday so I can start to fly better again, its hard to fly when you cant bend your wrist
Im ecksited () to see the picks of your build!!!
cam
ecks is offline Find More Posts by ecks
Old Mar 04, 2013, 06:40 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
The frame was definitely larger than expected. Feels very solid. Can be bent slightly, but it will not twist. One thing I didn't like.. Maybe the motor holes should be re-arranged to that you can get a quad on which the motor wires will always point towards the middle.
So it won't look as clean as it can be. Not a big issue though.
WiseDuck is offline Find More Posts by WiseDuck
Old Mar 04, 2013, 06:55 AM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
wow that was quick!
Im changing the CNC program now. top left and bottom right rotate 90 degrees! headslap
Old Mar 04, 2013, 07:00 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
It's all I can do for now though! I'm stuck at work but I took the motors with me for a quick test mount. As soon as I get home I'll slap on the ESCs and FC. Then the FPV gear.
I think I'll use my 20A SimonK ESCs on this one to get a much quieter and more responsive quad.
I'm going to use the HoryzonHD on this thing too, because it runs off receiver power and I need to keep the weight down. I'm limited to the stock DJI props and they do not like high loads, but the improved V2 props should work well on this one. I'll stick to 4S for now, so the flights will be short but intense!
Old Mar 04, 2013, 07:05 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Now, about the motor holes... I don't know if the wires come out of the same place on every motor out there. This is not a standardized thing, so even if you rotate the holes, they might not work for some other users out there. One solution is to use ONLY 19 mm holes, on such a small quad two screws should be enough to keep the motor in place. But that's up to you.
Old Mar 04, 2013, 08:40 AM
cruiser73 is offline
Find More Posts by cruiser73
cruiser73's Avatar
Singapore, Singapore
Joined Apr 2012
Hello Esevilaa, nice frame mate. Where did you get the headlights that you've used (saw the pic in another thread) from? HK?
cruiser73 is offline Find More Posts by cruiser73
Old Mar 04, 2013, 09:07 AM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
Thanks mate!
I got them from a chain we have here in Sweden that sells cheap random stuff clas ohlsen, just normal 12v lights, I'm pretty sure hobby king have them, or just check out your local light store, same with the one on the back, good thing was it was too long so I just cut it.
Those headlights light up a whole room but amazing for orientation.
Old Mar 04, 2013, 09:09 AM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
http://www.hobbyking.com/hobbyking/s...with_Lead.html
Old Mar 04, 2013, 11:05 AM
achiii is offline
Find More Posts by achiii
United States, PA, Philadelphia
Joined May 2012
Mine arrived in Lund. Thanks Cam! Apparently it looks "very handsome". Cant wait to actually get my hands on it, but it will take a while.
achiii is offline Find More Posts by achiii
Old Mar 04, 2013, 11:10 AM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
I'm looking forward to seeing your builds and getting your comments.
Old Mar 04, 2013, 11:13 AM
deno6031 is offline
Find More Posts by deno6031
deno6031's Avatar
Turkey, Izmir
Joined Oct 2011
I hope to get mine tomorrow, our post is slow in turkey, I'm gonna build it on the day I get it...
deno6031 is offline Find More Posts by deno6031
Old Mar 04, 2013, 02:38 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Bit of a progress report. Not quite as clean as your build. But I really can't be arsed to hide all the ESC wires. I'm going to ziptie the motor wires to the frame soon then hover in my room for a bit to see that everything is OK.
Old Mar 04, 2013, 02:41 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
I have found it is better to cut slots in place of holes that way any motor can fit
tech69x is offline Find More Posts by tech69x
Old Mar 04, 2013, 02:42 PM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
glad to see it, what size props are you using? thay look small but maybe not
Old Mar 04, 2013, 02:51 PM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
you think mine is neater, you should see the underside!
3mm slots sounds better thanks tech
For Sale MK ESCs (x8) V2.0 + MK FltCtl 2.1 ME + Droidworx octo frame V2 + Axi 2217 (x8) DanWalker.AK Aircraft - Electric - Multirotor (FS/W) 3 Aug 13, 2014 05:23 AM
Discussion HBFP Mk.I (v1) Frame and Boom Upgrade - V2 frame or King 2/3 Frame? rawfuls Micro Helis 1 Feb 21, 2011 06:07 PM
Discussion Trex 450 SE V2 frame vs. HDX 450 SE V3 G10 frame (super frame) richord Mini Helis 1 Apr 02, 2009 11:11 PM
