Old Feb 25, 2013, 09:22 AM
ecks is offline
Find More Posts by ecks
Knowledge prevents flyaways
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
New Product
Extremely fast acrobatic quad
Carbon ecks head view (5 min 24 sec)
Designed for 8 inch props, this machine weighs in at 384gwithout battery.
built to the lightest sepecification, all soldered connections, and a new extremely lightweight carbon composite frame. This machine is amaziingly fast with a 3S battery. Stick a 4S battery on for some unbelievable fun.
To purchase please visit www.ecksstore.se
Have you ever wanted to know what its like to fly a jet fighter?
Strap some FPV equipment onto your ecks
DonnyV's hardcore crash onto concrete (crash at 2 mins)
ecks hard crash (3 min 5 sec)
Recommended setups:
Ecks:
Tiger MT2208 1100kv
SimonK 12a ESC's
8 inch CF reinforced props
1600 4cell battery,
DonnyV's super fast and light setup:
keda 2730's 1300 kv-1500 kv
Simon K 10a esc's or 10 amp turnigy plush
8045 props
1500-1800 3cell 25c-45c lipo's
Note: If you use the 10 amp turnigy plush..I would stick with the 1300kv
if you use these motors you need the firewall mounts.
ecks frame
varnished wood $89 shipped. Plain wood $59 including shipping
PM me or leave a message on the thread to purchase
warthox
mwc quad // ecks frame (2 min 41 sec)
Bobepine
ecks (10 min 33 sec)
win the varnished version here:
http://www.rcgroups.com/forums/showthread.php?t=1871819
310mm strong aerobatic frame
Photo from warthox
This strong plywood frame has been cnc cut, to provide the strongest shape for this size of frame. Then sanded down to give the best finish and bring it down to a weight of around 150g. I then stain and varnish the frame.
Motor holes are 19/19mm, this gives you the option of 4 different angles for the motors. Only 2 screws are needed and they are supplied..
This frame is designed for 8 inch propellers, 9 inch will not fit.
ecks is offline Find More Posts by ecks
Old Feb 25, 2013, 03:02 PM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
Old Feb 25, 2013, 03:23 PM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
Why give up so fast? It is a nice simple frame.
NaterPin is offline Find More Posts by NaterPin
Old Feb 25, 2013, 03:25 PM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
I just meant give up bumping, I dont like it when people bump
Thanks for your comment.
Old Feb 26, 2013, 06:24 AM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
Quick frame strength test
Ecks frame crash test (0 min 30 sec)
Old Feb 26, 2013, 06:46 AM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
I have changed my mind a little.
To allow more people to purchase the frame. I will sell the plain version (no coat) with motor screws for $59 including shipping
the design has changes slightly since the picture. Motor mounts have been corrected, and hole for the nanowii have been added. Also the design has been strenghtened
Old Feb 26, 2013, 07:02 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Me!
Oh, wait, no. Not me. :P
Actually, I would like to try it. So I won't disappoint you again with an über-late flight test, let me purchase one of these right away! If the hole spacing can be changed to 16/19 that is. Using cross-mounts will only add lots of weight, especially when you can just use regular M3 screws to attach the motors directly to the frame. ALSO, why not add a 45x45 hole spacing in the middle so we can easily put a KK2 board on it using nylon standoffs?
WiseDuck is offline Find More Posts by WiseDuck
Old Feb 26, 2013, 07:20 AM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
A ha! There just regular m3 screws. Good to know as I hate the cross mounts, must be easy to buy, 12-15mm m3 screws is it?
I was thinking of the holes for a kk2 but so many different flight controllers, ill add them anyway.
Ditch that last frame, as ive gone through 2 of them now. When its made ill send you a paypal request for 100kr.
Maybe ill get to see you review it when theres ice on the lake again next year!
Old Feb 26, 2013, 07:21 AM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
Ps double check your kk2 holes, mine are 43 43
Old Feb 26, 2013, 07:48 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
I wasn't sure about the KK hole spacing, good thing you could measure them. But yeah, I have a ton of M3 screws at home with various lengths. If you could make a frame with 16/19 hole spacing that would be brilliant. This is one I can finish in one evening, and that's a promise. I have a whole set of banged up DJI motors here including a bag of unopened DJI 18A ESCs just begging to be used on something.
Alright, I'll donate the other frame to someone in need and use this one instead. I've been meaning to repair my F330 frame for a while now. I have 3st 850mah 4S lipos on the table here which I havent been able to use in a long long time, grrrr! Your frame with DJI motors on 4S would be insane!
Old Feb 26, 2013, 08:35 AM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
I would check the kk2 board holes anyway as I read somewhere that there is 2 different sizes of the kk2. Easy to fix the motor hole placement. I don't know why I didn't even think of that!
Old Feb 26, 2013, 08:48 AM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
850mah battery??? What motors do you have? I get 8 mins acrobatic on my 370 frame with 2650 4s
Old Feb 26, 2013, 09:17 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
On my F330 (Back when it wasn't in pieces..) I used the 2212 920kv DJI motors on it and 20A SImonK ESCs. 8" props and 850mah 4S lipos. Because of the low weight the performance was pretty darn awesome! Flights were somewhat short, but that's why I have many batteries instead.
I hope to do the same with this frame.
Old Feb 26, 2013, 09:41 AM
deno6031 is offline
Find More Posts by deno6031
deno6031's Avatar
Turkey, Izmir
Joined Oct 2011
I really would wanna try and review that frame, but i'm no where near to be respected in this forum
deno6031 is offline Find More Posts by deno6031
Old Feb 26, 2013, 10:20 AM
Granted is online now
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Ditto.
Mind you, if 100kr is all you're asking for that frame I foresee you having a lot less free time. Don't price yourself too cheap.
Granted is online now Find More Posts by Granted
For Sale MK ESCs (x8) V2.0 + MK FltCtl 2.1 ME + Droidworx octo frame V2 + Axi 2217 (x8) DanWalker.AK Aircraft - Electric - Multirotor (FS/W) 3 Aug 13, 2014 05:23 AM
Discussion HBFP Mk.I (v1) Frame and Boom Upgrade - V2 frame or King 2/3 Frame? rawfuls Micro Helis 1 Feb 21, 2011 06:07 PM
Discussion Trex 450 SE V2 frame vs. HDX 450 SE V3 G10 frame (super frame) richord Mini Helis 1 Apr 02, 2009 11:11 PM
