Old Feb 25, 2013, 09:19 AM
ryanbe15 is offline
Find More Posts by ryanbe15
ryanbe15's Avatar
United States, MD, Bethesda
Joined Sep 2012
Zenoah G20 - Buy or NOT Buy
Looking for feedback on the Zenoah G20 engines. How are they? May purchase a seagull yak 54 with this engine.
ryanbe15 is offline Find More Posts by ryanbe15
Old Feb 25, 2013, 10:06 AM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
Zenoahs have been long known for their reliability and high quality. Only negative I'd say is to the magneto ignition system, as it's heavier than the electronic ignition equipped competition.
Hemikiller is offline Find More Posts by Hemikiller
Old Feb 25, 2013, 10:12 AM
ryanbe15 is offline
ryanbe15's Avatar
Joined Sep 2012
A local guy is looking to sell a seagull Yak 54 with a Zenoah G20 for 300. WIll the zenoah G20 be powerful enough for this plane?
Old Feb 25, 2013, 11:18 AM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
In some cases a magneto ignition eliminates a second ignition battery and spark module so the weight is offset. Of course. many RC pilots fly with a one battery system now...
scootrb4 is offline Find More Posts by scootrb4
Old Feb 25, 2013, 11:56 AM
rjstrickjr is offline
Find More Posts by rjstrickjr
rjstrickjr's Avatar
United States, NC, Faison
Joined Jan 2011
The G-20CC should be electronic. The G23 and G26 have a magneto. Zen makes one of the most reliable engines on the market. The only problem is if they ever hit the ground prop first even in soft dirt or grass, your bending the crank shaft. The shaft sticks out there and prop strikes and crashes are very hard on them.
rjstrickjr is offline Find More Posts by rjstrickjr
Old Feb 25, 2013, 12:14 PM
ryanbe15 is offline
ryanbe15's Avatar
Joined Sep 2012
Anyone know how much thrust this engine gives. The model itself will weigh roughly 8-9.5lbs.
Old Feb 26, 2013, 06:00 AM
AA5BY is offline
Find More Posts by AA5BY
AA5BY's Avatar
East Texas
Joined Aug 2007
A G-20 will produce about 10.5 lbs thrust.
In my opinion, they are generally a better choice than a G-23 or G-26 because of a better power to weight ratio and I base that on observations of owning three G-20s, one G-23 and two G-26s. The G-26 is the better choice if additional nose weight is needed.
A drawback of a G-20 has been the ignition is power hungry. That can be rectified by converting to an RCexl ignition or somewhat by limiting the voltage to the ignition by using a diode voltage drop on a 4.8 volt pack.
AA5BY is offline Find More Posts by AA5BY
Old Feb 26, 2013, 07:39 AM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
Look for 300 bucks you can't go too wrong...I have never had a Zenoah I hear they are heavy compaired to other engines...But it's 300 bucks, get it see how she flies if you like it, you're golden, if you don't change to another brand and swap or sell the Zenoah.
Let us know what you come up with
jetmech05 is offline Find More Posts by jetmech05
Old Feb 26, 2013, 08:25 AM
ryanbe15 is offline
ryanbe15's Avatar
Joined Sep 2012
Prob not gonna do it. 300 doesn't include any servo's/receiver. For Servo's/batts/regulator/opto he wants 500 (granted the plane would come with an extra set of wings and a wing bag).
The plane is around 9.5 so i'd probably get bored of it as it's just too heavy and probably not very easy to fly. Engine will put out around 11lbs of thrust. So all in, i'd be looking at around 650 (i'd have to buy an AR8000). Rather save that money for a Pilot RC with all new stuff and a bigger engine (DLE 35cc).
Old Feb 26, 2013, 05:12 PM
AA5BY is offline
AA5BY's Avatar
East Texas
Joined Aug 2007
A 35 cc is quite a jump power wise from about 10.5 lbs thrust to about 18 lbs. so the airframe can certainly be larger. Sounds like your looking for performance and Zenoah engines are generally not thought to be in that category because of their weight. The Zenoah line is reliable and last forever but not the best available performance wise.
Old Feb 26, 2013, 05:50 PM
Rubbernecker is offline
Find More Posts by Rubbernecker
United States, VA, Forest
Joined Nov 2009
Plane and engine new is $500 and that doesn't include another 20 - 30 for shipping. If they are in good shape, it still looks like a good deal. At the extra cost for servos, battery and receiver, looks like they are digital. Go analog and you can save mega bucks.
John
Rubbernecker is offline Find More Posts by Rubbernecker
Sold Zenoah G20 EI Dseif Aircraft - Fuel - Engines and Accessories (FS/W) 1 Feb 21, 2013 07:24 PM
Wanted Zenoah G26 and G20 raw Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 02, 2007 06:10 PM
Discussion ASP FX91 vs Zenoah G20, can I compare kW? HugoW Engines 1 Nov 27, 2007 11:16 AM
Wanted Zenoah G20 EI slvmnr Aircraft - Fuel - Engines and Accessories (FS/W) 1 Aug 29, 2007 05:04 PM
Discussion zenoah g20 w/ extra 300 rotccapt Engines 2 Mar 22, 2007 08:32 AM
