The 5 Volt ARM look-out post.
The problem with the Atmel 8-bit AVR's on most Arduinos, is that eventually you want the extra Flash memory and RAM that an ARM can bring, with the increased clock speed also being welcome.
The problem being that the Arduino Due, CHIPKIT 32, Rasp. Pi etc, are 3.3v boards, making them incompatible with many Arduino Shields. 5 Volt ARM's do exist: http://www.edn-europe.com/5varmcorte...85+Europe.html So if anyone has, or does come across a 5V ARM-based Arduino compatible or similar, post it here
Jargon watch: FRAM chip; EEPROM Chip etc.
Ferroelectric RAM (FeRAM, F-RAM or FRAM) is non-volatile random-access memory technology that will not lose its mind or data when the power is turned off. Similar to flash memory.
EEPROM (also written E2PROM and pronounced "e-e-prom," "double-e prom," "e-squared," or simply "e-prom") stands for Electrically Erasable Programmable Read-Only Memory and is a type of non-volatile memory used in computers and other electronic devices to store small amounts of data that must be saved when power is removed, e.g., calibration tables or device configuration. (Wikipedia) PROM (Permanent Read Only Memory), allows users to program its contents exactly once by physically altering its structure with the application of high-voltage pulses, setting of each bit is like blowing by a microscopic fuse ('burning' memory). ROM (Read Only Memory) |
| Thread Tools | |
| For Sale Dimension Engineering High Voltage BEC 9-60 volts down to 5/6 volts! | SpeedVision | Aircraft - Electric - Power Systems (FS/W) | 0 | Feb 03, 2013 12:47 PM |
| Wanted Looking for KK LCD Flight Control Board and x4 DJI 450 Arms. | vacahtu | Aircraft - Electric - Multirotor (FS/W) | 6 | Jan 15, 2013 04:24 PM |
| For Sale RC-2K 12 volt Driver for 5' - 15' of GLOWIRE NIP | bah7566 | Aircraft - Electric - Miscellaneous (FS/W) | 0 | Jan 13, 2013 08:27 AM |
| Sold koolflight ubec 5-45 volt / 5 volt output | gruntdog | Aircraft - Electric - Power Systems (FS/W) | 2 | Jun 04, 2006 07:53 PM |
| Question When you got your Qualcom 830's did some of them read < .5 volts out? | The Other Dave | Parkflyers | 5 | Jan 29, 2002 02:49 PM |
