Binary sketch size: 5,492 bytes (of a 32,256 byte maximum) avrdude: stk500_getsync(): not in sync: resp=0x00 Once I get this figured out I will hunt those down. |
United Kingdom
Joined Aug 2008
So can work ![]() Well i tried this afternoon and damit if attiny45 wasn't dead and couldn't recover. Even with my super Duper Fuse fixer thingy http://www.pe0fko.nl/Fuse-restore/ mines bottom middle . AVR fuses really can spoil your fun.Well found my stash and set too and does work well but no attiny13 support. Don't do the no resister thing. |
Well I got it figured out. I was not hooking up the Tiny to the solderless board the proper way. I have had the experimenter board from like 20 years ago and it has been so long since I used it that I forgot how the rails were configured. once I realized that the whole X and Y rails were all one, not 4 separate blocks of five each, I got it hooked up and successfully loaded one of the example sketches. I can now set it up with my flasher routine and have extremely small and cheap flasher chips for my airplanes.
WOO HOO!! ![]() ![]()
United Kingdom
Joined Aug 2008
Excellent
Thought of this when you said you had none working attiny http://www.rickety.us/2010/03/arduin...al-programmer/ Using your pro mini you maybe able to recover it and handy when you get your fuses wrong. They can still break but trust me it bites when you get it wrong and its your last one. Oh and you can use Reset as an IO so 6 leds
| Thread Tools | |
| Question Program/configure ESC with Arduino | bogophan | Multirotor Talk | 12 | Jun 28, 2012 06:28 PM |
| Discussion Multiwii Arduino Programming | dyarrow | Multirotor Talk | 3 | Mar 07, 2012 10:50 AM |
| Discussion Arduino RC Programs/routines library | Tifani | Multirotor Talk | 0 | Nov 07, 2010 03:26 PM |
| Discussion Engine Run In program using Arduino board | cadzilla | DIY Electronics | 4 | Aug 16, 2010 08:21 PM |
