Old Feb 24, 2013, 06:52 PM
Screw is offline
Find More Posts by Screw
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
Place cap strip over leading edge and top of Fin and sand both the fin and rudder.
Sand Aileron stock as shown to create your Elevons.
Screw-Out
Screw is offline Find More Posts by Screw
Old Feb 24, 2013, 06:55 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
Prior to covering, go ahead and mark and cut your fin slots.
Screw-Out
Old Feb 24, 2013, 07:07 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
Covering still.
Screw-Out
Old Feb 24, 2013, 07:11 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
Covering the rest of it and hinging.
Screw-Out
Old Feb 27, 2013, 06:59 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
I have obtained a 90 EDF motor, 6S Lipo, and 80amp ESC. I'm gonna see if I can make this Angel pop!
These are two videos shot at the same time of the sport version using a 2820-50 on our prototype. http://www.youtube.com/user/teamstevensusa
Whatcha think?
Screw-Out
Old Feb 27, 2013, 07:29 PM
Svede is online now
Find More Posts by Svede
Svede's Avatar
United States, CA, Redlands
Joined Nov 2008
Slick wing is what I think.
Svede is online now Find More Posts by Svede
Old Feb 27, 2013, 08:17 PM
dangeranger is offline
Find More Posts by dangeranger
Joined Dec 2012
Awesome!
Great job! What sort of thrust to weight ratio do you get on 3s and 4s? In other words, how's the straight-up vertical performance on the setups you've tried? Were these setups with the Grayson motor? A couple of kits are going to be headed my way, but not 'till the chickens are thriving and the veggie beds planted. This Angel is testing my self-control, alright. Well, yes, Lucifer...
dangeranger is offline Find More Posts by dangeranger
Old Feb 28, 2013, 08:58 AM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
1. I don't have anything to measure Thrust to wieght ratios.
2. We've tried a few combos, and each of us like something different, but all of them climb str8 up.
3. Yes, we've used combos from Grayson Hobbies. They have a 2820-05 1250kv motor that is what we recommend as a good overall sport combo. That motor with a 60amp esc can run iether 3S or 4S with a simple matter of a prop and battery change. They also have a Monster Jet 2200kv motor that works well on 4S with a 70 amp ESC.
Screw-Out
Old Mar 03, 2013, 06:44 AM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
I have cast Lucifer out to it's new owner. It is ready to fly and look very forward to it's maiden.
Screw-Out
Old Mar 05, 2013, 07:07 AM
m.kennedy is offline
Find More Posts by m.kennedy
Learning More Every Day...
Cincinnati, Ohio
Joined Aug 2007
SCREW - So, have you decided to market this plane? Any idea of a price range (for just supplies to build the plane / no covering)?
I think it flew very well and ate-up alot of sky!! If it's priced right I might be interested.
Keep up the good work!!
Cincinnati, Ohio
m.kennedy is offline Find More Posts by m.kennedy
Old Mar 05, 2013, 04:27 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
I'm kinda marketing it here and on RCU a little. The response has been great and I've sold a few. Thanks everyone.
We are just a 3 man show working out of a small shop. We are still working on a set of instructions, but if you can follow this build thread, I've got kits ready to ship for $79 plus shipping.
The kits come with all laser cut ply, all balsa, carbon, and hardware needed to complete. It even comes with 2 Team Stevens logos
Send me a PM if you are interested.
Screw-Out
Old Mar 08, 2013, 11:23 AM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
The Kits will come with:
All laser cut ply, balsa, carbon/fiberglass rods, and hardware needed to complete.
4 pre cut FWET Tubes
6 laser cut ply ribs
7 assorted laser cut ply formers and trays
2 large laser cut ply gussets
2 small laser cut ply gussets
1 1/8 laser cut balsa trailing edge
8 1/16x1/2x36 cap strip balsa
9 1/16x3x4 balsa sheet
1 1/4x1/4x36 balsa (tip material)(fin cap strip)
5 piece 3/16 laser cut balsa fin assembly
1 3/16x1 1/2x36 Aileron Stock
1 1/4x1/4x36 Triangle Stock
3 2-56 threaded Rods
3 2-56 clevis
3 2-56 EZ links
8 CA hinges
10ft Kevlar string
Screw-out
Sold NEW ARC 28-47-1 Inrunner Motor (lightflightrc) $55.00 shipped flyinhigh025 Aircraft - Electric - Power Systems (FS/W) 2 Jan 14, 2013 01:57 PM
Sold Arcs 28/37/2 FlyBillyFly Aircraft - Electric - Power Systems (FS/W) 3 Jan 10, 2013 07:55 AM
Wanted Wanted: ARC 36-75-1.5 F7X Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2013 07:46 PM
For Sale Arc 28/37/2 FlyBillyFly Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2013 01:41 PM
Wanted Sky Angel A-4 airframe wyldkrd Aircraft - Electric - Jets (FS/W) 0 Jan 02, 2013 12:26 PM
