Old Feb 24, 2013, 05:33 PM
Screw is offline
Find More Posts by Screw
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Arc Angel
Screw-In
Well, I think we ready to roll out the ARC Angels.
My Brothers and I (Team Stevens) wanted to bring back the simplicity of an open airframe delta like the Diamond Dust in an all new laser cut platform for electric RC only.
After a few prototypes ( http://www.rcgroups.com/forums/showthread.php?t=1775338 ), we have our first set of 20 deltas called the Arc Angel. Specs are as follows:
Arc Angel Specs:
Length: 27 1/2 inches
Wing Span: 33 inches
Wing Area: 525 Square inches (Including Elevons)
Weight: 1.9lbs (3S 2200mAh) - 2.5lbs (4S 3400 mAh) as tested.
Motor: 28mm Outrunner 3S-4S as tested.
We were consistantly getting over 90mph on 3s and 119mph on 4s. Once popped a 124mph! I'm sure there are other combos out there that will get faster speeds (challange) if anyone is interested in that sort of thing.
The Arc Angel is a sport delta with a rudder for spins and snaps.
If anyone is interested, please send me a PM. I am prepared to offer kits, ARCs, and ARFs.
Screw-Out
Screw is offline Find More Posts by Screw
Old Feb 24, 2013, 05:41 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
Building the kit requires no plans or jigs of any sort. Follow the pics. Keep in mind, this is very brief.
Screw-Out
Old Feb 24, 2013, 05:50 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
Attach Gussets to the fuse and tip ribs.
Screw-Out
Old Feb 24, 2013, 06:10 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
At this point, your ribs should be glued in to place howerever the rods should NOT be glued to the fuse. They should be moving free.
Time to add the Leading edge rods.
Screw-Out
Old Feb 24, 2013, 06:19 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
Using Kevlar string, wrap your leading edges and soak with thin CA.
Screw-Out
Old Feb 24, 2013, 06:20 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
Fill in your trailing edge. Your trailing Edge started as a 1/8 balsa. Using the provided 1/16 balsa, we are going to fill it in.
Screw-Out
Old Feb 24, 2013, 06:27 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
Tips and Cap strips.
Screw-Out
Old Feb 24, 2013, 06:42 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
Cap Strip the rest of the top of the fuse. Lightly Sand your sheeting.
Screw-Out
Old Feb 24, 2013, 06:45 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw-In
Assemble the Fin and the Elevons.
Screw-Out
Sold NEW ARC 28-47-1 Inrunner Motor (lightflightrc) $55.00 shipped flyinhigh025 Aircraft - Electric - Power Systems (FS/W) 2 Jan 14, 2013 01:57 PM
Sold Arcs 28/37/2 FlyBillyFly Aircraft - Electric - Power Systems (FS/W) 3 Jan 10, 2013 07:55 AM
Wanted Wanted: ARC 36-75-1.5 F7X Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2013 07:46 PM
For Sale Arc 28/37/2 FlyBillyFly Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2013 01:41 PM
Wanted Sky Angel A-4 airframe wyldkrd Aircraft - Electric - Jets (FS/W) 0 Jan 02, 2013 12:26 PM
