Old Feb 24, 2013, 02:30 PM
magikman18 is offline
Find More Posts by magikman18
Joined Feb 2013
Wing Structure
Hey everyone, so just a little background information: I'm working on a senior design project at my school and I am in charge of designing the wing of our airplane. I have a nifty code for calculating the lift distribution along the wing, which will in turn help me to determine the deflection I can expect for the wingtip.
I was thinking about a structure with 2 sparsne at the leading edge and one midspar. I was hoping that I could get some thoughts and opinions from experienced builders on what they thought of this idea for the structure. I would really appreciate any advice I could get. Thanks everybody!
magikman18 is offline Find More Posts by magikman18
Old Feb 24, 2013, 02:40 PM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
We need a lot more info.
Wing span, material, weight, purpose.
A very light plane needs only a leading and trailing edge to support it.
As the weight increases it needs more. The main spar is normally
at the CoG of the wing load. The leading and trailing edge are
not load bearing to much extent.
Kimber is offline Find More Posts by Kimber
Old Feb 24, 2013, 02:51 PM
Joined Feb 2013
Its has to carry some golf balls. The total weight of the aircraft will be somehwere in the vacinity of 3 lbs. It will weigh a maximum of 4 lbs with cargo. I figured that the leading edge spar would be a good idea since my team members and I do not have much experience flying. It needs to be durable enough to withstand a little abuse. I'll be running some materials testing tonight. The likely candidates are some sturdier types of balsa wood. Also, there will be no ailerons on the wing. Span of 6 feet. Does that help?
Old Feb 24, 2013, 03:24 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
A 72" wing at three pounds will have to be lightly build and not too
tough.
You might think about a foam wing with CF spars.
And you need someone with RC experience.
Old Feb 24, 2013, 03:33 PM
Joined Feb 2013
I thought about foam, but the teacher wants us to build an actual structure. because of our lack of experience, it will have to be fairly durable. Able to withstand a crash or two before it busts. We are competing against numerous teams, none of which has any prior experience either, so we are looking into software to simulate flying an R/C plane.
Old Feb 24, 2013, 06:12 PM
madbomber is offline
Find More Posts by madbomber
Hatters gonna hat.
madbomber's Avatar
United States, CO, Denver
Joined Apr 2011
If you are able to purchase a copy of the RealFlight simulator, I am fairly certain you can model your airplane in some type of cad program and import it into the simulator. That way you can get some practice on the sticks AND you could have a decent idea of how your design will work. There may be other, less expensive simulators that offer this feature, but I dont know of any off the top of my head.
madbomber is offline Find More Posts by madbomber
Old Feb 24, 2013, 07:40 PM
viva_peru is offline
Find More Posts by viva_peru
Oakland township, Michigan
Joined Jun 2005
Hi,
It sounds like you are building a glider given the weight and wingspan. It has been done before, so it can be done. Given the wingspan you are hoping to achieve, the best structure will probably be one where the first 1/3 or so of the cord is sheeted using thin balsa. In essence, the balsa skin covers the top and bottom surfaces of the wing between the LE and the main spar. This creates a box structure which is quite strong in bending as well as in torsion. An open structure using two spars will be relatively weak in torsion unless you use some diagonal bracing in between the ribs or you provide supporting struts. It would probably also be heavier.
The main spar can be a simple I-beam where the spar caps are made from spruce. The shear web between the spar caps can be balsa with the grain oriented vertically. At 4lb total weight, the spar caps can probably be made from 1/4x1/8 spruce. If need be, you could increase the depth of the spar cap near the wing root to 1/4x1/4 to provide additional strength.
Finally, I would try to enlist the help of someone who has RC experience. After the plane is built, you will have too much time and effort invested on it to use to teach yourself how to fly. It will probably not end well.
If you are looking for technical assitance, take a look at www.homebuiltairplanes.com. The have a very good techincal forum. Also see if you can get ahold of a copy of ANC-18, the bible for wood aircraft structures. The file is a little too big to post here.
Good luck,
Teo
viva_peru is offline Find More Posts by viva_peru
Old Feb 24, 2013, 08:08 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
Originally Posted by Kimber View Post
A 72" wing at three pounds will have to be lightly build and not too tough.
I've got a 84" Quaker that's a bit over 4 lbs. all-up. It's a 1937 design, and was originally designed for free flight.
The fuselage is made almost entirely of 3/8" balsa sticks. The wings have a pair of 3/8" hardwood spars. I could have made it lighter using film covering, but I used SIG Koverall and dope for ruggedness. It can be flown for several minutes on a 3S/2200 battery, but I usually fly it with 4S/2600.
It is not a fast plane by any means, and won't tolerate much wind. But I'd say it's quite robust for its intended flight envelope.
rafe_b is offline Find More Posts by rafe_b
Old Feb 25, 2013, 08:24 AM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
IMO you MUST get some help when it comes time to fly the plane. Some people can pick up the transmitter and fly but they are far and few between. The flight simulators help a lot, but they are not like the real thing.
If you Google "model airplane plans" you will find many examples to give you and idea of what you need to do to building a strong wing. No use reinventing the wheel here. You may and I would expect you would find examples of the very plane type you are attempting to model.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: A letter from my Senator.....
Old Feb 25, 2013, 08:14 PM
Joined Feb 2013
I flew a kit today that I was provided for practice. My flying skills aren't too shabby, except for a couple hard landings. At this point, I've done some material testing to get the modulii of different materials. Based on the material properties, I just need to design a midspar that will only deflect a certain amount based on the lift being generated.
Does anyone have any ideas what my max deflection should be? And thank you to everyone who has already given me advice so far! It has been really helpful!
Old Feb 26, 2013, 06:44 AM
Joined Jun 2005
I have read somewhere that for full scale light aircraft, the rule of thumb is about 1" per G. If we assume a 26 ft wing span, the 1" deflection happens over 13 ft or so. To make the math easy, assume 12 ft. Your plane will be 6 ft, so 3 ft per panel, or about 1/4 of full scale. With that in mind, I would say 0.25" per G. If you design it to take 4 G's. then 1".
Are you in engineering school or is it high school. You never really said. As for getting data on wood properties, take a look here:
http://www.fpl.fs.fed.us/products/pu...00&header_id=p
and here,
http://www.homebuiltairplanes.com/fo...es-wood-2.html
Good luck,
Teo
Old Feb 27, 2013, 08:15 PM
Joined Feb 2013
I've determined a deflection through some tests. I need to pick material for the wing spars. The main load carrying beam can't have dimensions larger than 1 inch (I am going with a rectangular shaped beam). Any thoughts on some popular woods used that I could look into?
Old Feb 27, 2013, 08:53 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
For the weight you are dealing with balsa is fine. A boxed
spar is the strongest. A top and bottom spar with a plate
between them, called a shear. It is important that the
shears grain in 90` to the spar.
Like this:
Old Feb 28, 2013, 06:34 AM
Joined Feb 2013
Wow, thank you for that, Kimber! I see that there is balsa sheet on the leading edge and trailing edge. Its placed there more for keeping the aerodynamic shape, right? It must help support the structure to some extent, or is that typically too minimal and I'm just over thinking?
Old Feb 28, 2013, 07:16 AM
Joined Jun 2005
Hi,
The built up trailing edge provide the area needed to adhere the covering, but since it is in the shape of a C-channel it also provides some torsional stiffness to the wing. Since most joints on an R/C plane are butt joints, adding the sheeting over the trailing edge piece adds quite a bit of stregth. If you are not going to have ailerons on the wing, the trailing edge could come to a point and this could be done by having the TE top and botton sheeting meet at the tip of the rib.
Teo
Discussion Composite skinned wing structure acesimmer Composites Fabrication 34 Feb 21, 2013 08:05 PM
Question DLG structural question: bias Kevlar at wing joint chlee Hand Launch 1 Aug 07, 2003 05:31 PM
Idea Questions on wing structure astroboy Modeling Science 5 Jul 22, 2003 01:48 AM
Wing sections and structures Dereck Modeling Science 5 Aug 28, 2002 04:13 PM
"D-tube wing structure" - what does it mean ? oded mazor Electric Sailplanes 2 Mar 05, 2002 09:56 AM
