Old Feb 24, 2013, 04:14 AM
TheSwing is offline
Find More Posts by TheSwing
Joined Jan 2013
How much -% pitch is needed to slowly get down?
There is probably a discussion section on this but what is enough pitch to get you back to the ground ?
I have 3 modes - I was thinking about setting
Mode 0 - Just allows you to spool the helicopter up on the ground (tested this and it worked well) Had Throttle Curve 0 to 80% and the pitch curve at -15% all the way to the high point.
Mode - Easy not too much movement mode - Had Throttle Curve from 0 to 75% and the pitch curve at -2% - mid stick 0% high point 30% ?
Normal Mode (stunt mode 3) - A little more movement - Throttle Curve 0% to 100% pitch curve at -10% to +55%
I want my stunt mode 1 (or in my case easy mode) to just have enough to go up and down (practice hovering) so my question is - How much is just enough but not a huge amount of negative pitch .. I don't want to make the helicopter act like a magnet to the earth
Also is positive 30% too aggressive for just practicing hovering?
Thanks in advance!
PS: What is EXP on the Devo 7 mean ? This is on both the throttle curve and the pitch curve?
TheSwing is offline Find More Posts by TheSwing
Old Feb 24, 2013, 05:33 AM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
First off, you don't really need to set all flight modes for normal flight. Set throttle curve to 0-100, and pitch -15 to +60, and you're done. ST1 and ST2 are recommended for idle up, anytime you fly outdoors, you'll need the heli to fly on idle up. Sometimes you'd want ST2 to be the full idle up with full positive and negative pitch range, and use ST1 as a transition point when switching to full idle so your heli doesn't suddenly fall to the ground.
The difficulty is set in DREXP. As you probably know Rate is how far the servos go. Exponential flattens out the middle of the pitch curve. Set it to +30 and assign it to POS0, and set 0 to POS1. That way with the D/R switch up, the helicopter will be more docile, and then pull the switch down when you want it to be more agile.
Hajile is online now Find More Posts by Hajile
Old Feb 24, 2013, 06:24 AM
TheSwing is offline
Joined Jan 2013
Ok I get you thanks... that makes sense.. I set the DREXP to 30% on setting 0 and 95% on setting 1
So what is MIXTH? I have a ELEV/AILE/RUDDER and on each of them I have a % left and a % right.. is that like a trim setting?
Old Feb 24, 2013, 06:39 AM
Joined Jul 2012
That one i don't really mess around with. But i believe that's related to helicopters flying while in rate mode (i.e. Gyro Gain less than 50%), the higher the throttle, the more rudder gets added for example. We normally don't need it since the 3 axis gyros we have does it automatically, but some helicopters still get tail drift and we use this to adjust the rudder as we throttle up. Leave it alone.
Question How much is too much? CarPainter Composites Fabrication 9 Feb 03, 2013 12:33 PM
Discussion How much thrust / power do you need per pound? mikes68charger Electric Ducted Fan Jet Talk 6 Feb 03, 2013 11:05 AM
Discussion How much coverage will this get? FrankC Life, The Universe, and Politics 42 Jan 29, 2013 09:29 PM
Help! How much does the feathering shaft need to be bent to necessitate replacement? B450guy Electric Heli Talk 5 Jan 05, 2013 10:25 AM
How much pitch do you need? Richard! Micro Helis 6 Oct 08, 2005 01:47 PM
