United States, UT, Logan
Joined Jun 2011
I haven't used Textreme. I've only used 5.7oz plain weave and 5.7oz ST and both fall apart very easily. You say samurai is easier than Textreme? It's not so much the small pieces I'm most worried about. It's the 1.5"x30" Dbox pieces that I'm afraid will distort horribly when I try to pick them up.
United States, MD, Lusby
Joined Nov 2003
Ummm, my experience is the opposite of Kristof's, at least with this material here: http://shop.r-g.de/4DCGI/ezshop?acti...COUNT=27151673
I use the 3m77+wax paper transfer method on my Samurai d-boxes. |
My experience is similar to Krikkens' - if you are careful, you can cut/move/apply Samurai fabric without any stabilization. I regularly cut and apply 3-tow by ~11 inch strips for tail surface spars without any stabilization and they stay perfect. I can't do this with 1oz Kevlar or other lightweight, non-stabilized CF. Having said all that, wax paper transfer is so easy that I can't see why not to use it, particularly with larger pieces where you risk messing up an expensive piece of fabric. Paper transfer also ensures that all the tiny little bias tow pieces that are usually present around the edges of curves stay perfectly in place, so it can help ensure the perimeter cosmetics. Have fun, it's very satisfying fabric to use.
-John |
Joined Aug 2009
i never made a d-box with the samurai but i cannot imagine it being hard to do , for the bottom of the vertical i cut small strips and it handles perfectly , i never distorted this fabric when wetting out .
the binder textreme spread-tow binder sticks to paper towel when blottingh out and this doesn't happen with the samurai , that's why it's my #1 when it comes to easy handling . i never have used any transfer medium when working with fabrics -kristof- |
Joined Jun 2011
I gotta say I think Kristoff is right. I used wax paper xfer for it, but I think it could have been done without it. That fabric is so tightly woven and so stable I probably could have pulled the wet fabric off the mylar and replaced it without much trouble if I needed to. I am officially in love with Samurai carbon!
This 1k carbon gets very difficult to handle when the cuts are narrow, especially around the wingtips of the D-box wings etc. With that being said, it can be handled without a binder if you're careful, just make sure that you don't shear it accidentally. It's one of those things that is really easy to screw up once and then pretty easy to NOT screw up after you know what NOT to do with it. My bigger problem with the stuff than handling is the failure mode. It likes to "zip" open when impacted. I had a minor impact damage on the LE of a wing that tore along the fiber lines all the way back to the spar lamination. I don't typically see that kind of issue with Textreme or regular 1k carbon 20x20 or 24x24 weaves. It's cool stuff but I'm not sure if I'll use it again.
The other annoying thing about being binderless is that if you have a tiny offcut at the end of a tow (like from a roller cutter) this offcut will find its way onto another piece of fabric on the bench and it's almost impossible to remove without surgical tools. I have several wings with tiny carbon bits in them from Samurai cloth that are not an issue structurally, but cosmetically it can be frustrating. |
Joined Jun 2011
I know what you mean about the little pieces coming off of ends and getting into other fabrics. I had several that I picked off of my Dbox fabric before laying it onto the mylar. Out of curiosity, do you ever use a wax paper xfer for Textreme? Or is it stable enough with the binder that it isn't necessary?
| Thread Tools | |
| Sold 61g "Samurai" ST 1K carbon fabric 100cm wide - $50/foot | jbarnhardt | Aircraft - Sailplanes (FS/W) | 15 | Sep 12, 2012 07:28 AM |
| For Sale 1.8oz (61g) "Samurai" Spread Tow 1K carbon fabric - by the foot | jbarnhardt | Aircraft - Sailplanes (FS/W) | 3 | Apr 20, 2012 03:59 PM |
| For Sale Superlight 1.8oz (61g) "Samurai" Spread Tow 1K carbon fabric 100cm wide - by the foot | jbarnhardt | Aircraft - Electric - Miscellaneous (FS/W) | 1 | Feb 18, 2012 07:55 AM |
| For Sale Superlight 1.8oz (61g) "Samurai" Spread Tow 1K carbon fabric 100cm wide | jbarnhardt | Aircraft - General - Miscellaneous (FS/W) | 0 | Feb 13, 2012 07:20 PM |
| For Sale FS/TRADE--COMPLETELY Ready-To-Fly, Carbon-bagged Samurai | target | Aircraft - Sailplanes (FS/W) | 8 | Mar 15, 2008 12:51 PM |
