Old Oct 08, 2013, 11:48 PM
jbarchuk is offline
Find More Posts by jbarchuk
DeBary, FL
Joined Nov 2010
Originally Posted by Ospreyman View Post
Sorry, I misunderstood. From what you are saying, that could work. It has to be worth a try
No problem I didn't really explain in detail what I was thinking.
About the pitch problem with forward swept arms. I'm adding a CC3D stabiliser to a fairly unstable pizza box style plane. The only experience I have with stabiliser is AS3X in the microfoamies. Other more advanced stabilisers such as CC3D, KK2 (mush less expensive,) and Revolution (much more expensive) have *tons* more adjustability/tuneability. It's likely that one of these can 'add more stabilisation as arms move forward where it gets less stable.' When the arms are back it's more stable and wants less stabilisation so it doesn't get to feeling mushy. As arms move forward it can correct the pitch-up habit by adding elevator-down.
jbarchuk is offline Find More Posts by jbarchuk
Old Oct 09, 2013, 08:48 AM
Ospreyman is offline
Find More Posts by Ospreyman
Cheshunt, Hertfordshire
Joined Aug 2009
I have no experience of CC3d or KK2 but I shall look into it . Sounds promising
Ospreyman is offline Find More Posts by Ospreyman
Old Oct 09, 2013, 11:31 AM
jbarchuk is offline
DeBary, FL
Joined Nov 2010
Also Ardupilot comes to mind.
For a -micro- flyguy, with 4.7g servos in the arms, I'll bet an AS3X scavenged from a brushless UM foamie could do it. OK now that one's really got me thinking. LOL!! I didn't like the idea of microflyguy because they're already so inherently unstable, but stabiliser would help tons and might make it doable, swing arms or not. I have too many potatoes on my plate though to do anything soon.
Old Oct 10, 2013, 01:37 PM
Petefoss is online now
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
My 23" flyguy (Mr. Incredible) is not unstable at all.
Petefoss is online now Find More Posts by Petefoss
Old Oct 10, 2013, 03:40 PM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
The short, inglorious maiden of my tiny FlyGuy...
31" RC Flyguy - A short, flawed maiden flight (1 min 8 sec)
mclarkson is offline Find More Posts by mclarkson
Old Oct 11, 2013, 12:07 AM
Otto Dieffenbach is online now
Find More Posts by Otto Dieffenbach
United States, CA, San Diego
Joined Aug 2011
http://youtu.be/bjcpoNmAlO8
You aren't the first to lose your head........ Rub some glue on it and get back in the air. He looked great.
Otto Dieffenbach is online now Find More Posts by Otto Dieffenbach
Old Oct 11, 2013, 06:50 AM
Joined Aug 2009
You are dead right Otto, Head plants are all too common in the early stages. But Glue 'em back together and fly 'em again.
Just thought I would update you guys on what I have been doing lately with Flyguys.
First I built the Flyguy 62" v1 from plans. Then I redrew the 31" and came up with Wonder-woman followed swiftly by Batman, Rocketeer and Spidey.
You will notice I have taken a bit of a liberty with the 31" models . I have given them all all-moving legs. I must admit they are are far more maneuverable than the 62, able to do vertical twinkle rolls, tight loops and almost hovering. There is a lot more control surface in the prop wash with this adaptation and they are ROCKING. Batman had the servos mounted on top of the body plate just behind the prop. The others have the servos mounted below the body plate.
No vid yet as I fly alone quite a lot but soon hopefully
Old Oct 11, 2013, 09:29 AM
Joined Aug 2009
Are you swinging wings though? I find all the flyguys very stable once the cg and throws are set correctly
Old Oct 11, 2013, 10:05 AM
Joined Aug 2011
Wow... Nice paint jobs! Thank you for the leg info. Your house must look a lot like mine. Do you have any video to share? Would love to see them in the air.
Old Oct 11, 2013, 11:45 AM
Joined Aug 2009
no video yet Otto but i'm working on it. By the way the paint is all artist's acrylic brushed on . Spidey's webs are water based silver pentel
Old Oct 11, 2013, 12:26 PM
jbarchuk is offline
DeBary, FL
Joined Nov 2010
Yep I definitely should not have said what I did that way, and I apologise for the implied insult to the aircraft and the designer. With correct balance, throws, expos and finesse it flies fine.
It's adding surface area in front of the CG/CL area with the swingwing that adds a ton of pitch sensitivity. (Not so bad at slower speeds though so that helps.) I found that out recently with a scratch designed PBF.
A further goal would be to swing the arms to a full forward 'Superman style' position. More like Superpitch sensitive. LOL!! A stabiliser would help with that for sure.
Old Oct 11, 2013, 12:30 PM
jbarchuk is offline
DeBary, FL
Joined Nov 2010
Are you -sure- don't don't need a hobby?
Old Oct 11, 2013, 12:47 PM
Joined Aug 2009
Whaddya mean Hobby?it's an OBSESSION
Old Oct 11, 2013, 01:53 PM
jbarchuk is offline
DeBary, FL
Joined Nov 2010
Certainly. Thank you for making my point.
Rephrased, are you sure you *don't* need a hobby? Never mind, same answer anyway.
Old Oct 12, 2013, 05:15 AM
Petefoss's Avatar
Joined Aug 1999
Have you seen the german variant (Flyman?) with legs that bed at the knee? He has some overlaps so you don't see a gap when the legs bend. Think it's the one with the prop on the top of the head too if that helps.
Build Log Flyguy 46 Version 2 Otto Dieffenbach Foamies (Scratchbuilt) 131 Nov 06, 2015 02:02 PM
Build Log Flyguy 62 Version 2 Otto Dieffenbach Foamies (Scratchbuilt) 305 Sep 22, 2015 07:14 PM
Discussion Foamie Flyguy in 4 sizes Otto Dieffenbach Foamies (Scratchbuilt) 1665 Aug 14, 2015 06:14 PM
