Old Feb 28, 2014, 07:41 PM
Otto Dieffenbach is offline
Find More Posts by Otto Dieffenbach
United States, CA, San Diego
Joined Aug 2011
Originally Posted by magik30 View Post
ok now my flyguy 62 to flying.
but no video .. soon ..
otto you have mounted the two engines like me?
Similar. Mine are on the shoulders with counter rotating propellers. I use differential thrust for yaw control. I really like it.
Otto Dieffenbach is offline Find More Posts by Otto Dieffenbach
Old Mar 01, 2014, 02:43 AM
magik30 is offline
Find More Posts by magik30
France, Languedoc-Roussillon, Nimes
Joined Mar 2012
how can I do for?
magik30 is offline Find More Posts by magik30
Old Mar 01, 2014, 01:23 PM
Joined Aug 2011
how can I do for?
I use a 6 ch receiver with my DX8. I plug one esc into the throttle and one into my aux channel. I have one mix that ties the aux to the throttle at 100% that is always on.
I switch the remaining 2 mixes with my landing gear switch. This lets me turn the differential throttle on and off. These two mixes are rudder to throttle and rudder to aux. I mix both at 50%, one negative and one positive. When activated the mixes advance the throttles to 25%. So at idle on the throttle stick you have 25% thrust on both motors with a differential thrust range on both motors of 0 to 50 percent using the rudder stick. At full throttle both motors advance to 75% with a differential range of 50 to 100 percent. This way both ESCs stay between 0 and 100 percent. Mine recalibrate the zero point if I go below the 0 percent point.
This setup generates plenty of yaw. I generally launch with differential off then switch on in the air. I have a transmitter warning to remind me to have the gear switch in the right position when I turn on the transmitter.
Old Mar 01, 2014, 02:31 PM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
That's where controllers with fixed endpoints are better. You can easily mix to only subtract with rudder. That way even at full rudder you need throttle too. Safer when you do it for ground handling on a twin.
Petefoss is offline Find More Posts by Petefoss
Old Mar 01, 2014, 02:55 PM
Joined Aug 2011
You're right. I'm too cheap for my experiments.
Old Mar 03, 2014, 02:23 PM
magik30 is offline
Joined Mar 2012
otto thank you for your commentary of the differential motor.
I also do another small RC FLYING DIVER
SKYMAN RC Plongeur (0 min 34 sec)
Old Mar 03, 2014, 04:53 PM
Joined Aug 2011
http://www.youtube.com/watch?v=OCqpm...sYafhZsF8eY-Cg
Looks like a Skyman; should be fun.
I did this with my Flyguy about 3 yrs ago.
RC Green Lantern with Floats flown by Otto Dieffenbach at a local lake (1 min 59 sec)
Old Mar 03, 2014, 10:41 PM
magik30 is offline
Joined Mar 2012
otto beautiful work.
Old Mar 03, 2014, 11:41 PM
magik30 is offline
Joined Mar 2012
otto is for you.
in my opinion it is possible.
you already flyguy woman, just change the low fish-shaped
Old Mar 04, 2014, 12:09 AM
Joined Aug 2011
otto is for you.
Anything is possible......
Old Mar 04, 2014, 05:23 AM
ttersu is offline
Find More Posts by ttersu
All can fly...Launch stronger!
ttersu's Avatar
France, Centre, Romorantin-Lanthenay
Joined Oct 2013
A Mermaid, You can make a mix of your FlyGuy and my Shark tail
ttersu is offline Find More Posts by ttersu
Old Mar 04, 2014, 01:35 PM
magik30 is offline
Joined Mar 2012
how the shark tail of your work?
you can see a video.
tu peu mous faire une vidéo du fonctionnement de la queue du requin stp ?
Old Mar 04, 2014, 02:29 PM
ttersu is offline
ttersu's Avatar
Joined Oct 2013
There is one on Post1 In Jaws thread
http://www.rcgroups.com/forums/showthread.php?t=2078272
Old Mar 05, 2014, 02:59 AM
magik30 is offline
Joined Mar 2012
hello.
a small sketch to give you an idea of ​​my future projet.voici some pictures.
can be put servo ELEV above (between the breasts)
I found it as the second idea for the movement of the tail.
Premier RC - Vector Kite Gimbal.mpg (1 min 30 sec)
Old Mar 05, 2014, 09:44 AM
Joined Aug 2011
That would be fun. I always resisted this design because of tail weight. All my calculations indicated I'd have to put a lot of lead in the head.
Build Log Flyguy 46 Version 2 Otto Dieffenbach Foamies (Scratchbuilt) 131 Nov 06, 2015 02:02 PM
Build Log Flyguy 62 Version 2 Otto Dieffenbach Foamies (Scratchbuilt) 305 Sep 22, 2015 07:14 PM
Discussion Foamie Flyguy in 4 sizes Otto Dieffenbach Foamies (Scratchbuilt) 1665 Aug 14, 2015 06:14 PM
