Old Jan 26, 2014, 04:04 PM
ttersu is offline
Find More Posts by ttersu
All can fly...Launch stronger!
ttersu's Avatar
France, Centre, Romorantin-Lanthenay
Joined Oct 2013
wé, tu as des débattement étranges...
tu en a plus à piqué qu'à cabré...Pour corriger ton soucis de cabrage?
Sinon, tu as mis un peu d'angles à ton moteur? (anticouple et piqueur)
as-tu le même phénomène en plané pur?
Yup, you have strange rates...
More down than Up...
Did you give angles to your motor (Down + right thrust line)
Is it the same powerless?
ttersu is offline Find More Posts by ttersu
Old Jan 26, 2014, 06:51 PM
Otto Dieffenbach is offline
Find More Posts by Otto Dieffenbach
United States, CA, San Diego
Joined Aug 2011
Originally Posted by magik30 View Post
as_tu regarder la vidéo ?
http://youtu.be/NQ6KeuNHtC4
watch?v=NQ6KeuNHtC4&feature=youtu.be
One thing I see is that the angle of the feet are not 15 degrees. He will not turn unless they are at least 15 degrees off horizontal. Yours appear to be less than 10, probably around 7 degrees. Also check your CG.
Otto Dieffenbach is offline Find More Posts by Otto Dieffenbach
Old Jan 27, 2014, 03:12 AM
magik30 is offline
Find More Posts by magik30
France, Languedoc-Roussillon, Nimes
Joined Mar 2012
I show you tilt motors.
je vous montre l'inclinaison des moteurs
flyguy62 motor (0 min 27 sec)
magik30 is offline Find More Posts by magik30
Old Jan 27, 2014, 06:14 AM
ttersu is offline
ttersu's Avatar
Joined Oct 2013
Old Jan 27, 2014, 11:03 AM
magik30 is offline
Joined Mar 2012
you put anything like lipo 2200 or 3000?
Old Jan 27, 2014, 12:17 PM
Joined Aug 2011
I have included on of my early Flyguy drawings. Note in the lower left, the cant of the sides and the feet; 15 degrees. You need this to turn. I have also found that differential thrust will make him turn with two motors.
Old Jan 27, 2014, 02:19 PM
magik30 is offline
Joined Mar 2012
la suite
fyguy62-1 (0 min 28 sec)
Flyguy62 (0 min 28 sec)
Old Jan 29, 2014, 02:49 PM
magik30 is offline
Joined Mar 2012
hi
ok now the CG is good, with 3000 mah battery.
44 oz is heavy? yes/no
1255 gramme c'est lourd ou pas ?
Old Jan 29, 2014, 04:50 PM
ttersu is offline
ttersu's Avatar
Joined Oct 2013
Hi Magic, Otto's flyguy62 is 33oz...
I can't say if your is to heavy or not...Otto will answer better than me
Old Jan 29, 2014, 04:51 PM
Joined Aug 2011
hi
44 oz is a little on the heavy side but he should fly well. I've had up to 50 oz. The heavier they are the more susceptible they are to landing damage.
Old Jan 30, 2014, 05:41 AM
magik30 is offline
Joined Mar 2012
ok thank you, I will soon be tested in the field.
ok merci, je vais bientot le tester au terrain.
Old Feb 26, 2014, 03:45 PM
Joined Aug 2011
Flyguy62 Version 3 Prototype
Hi all. I've been playing with different features on Flyguy and exploring hover capability. Out of these efforts I have found a configuration that really gets Flyguy to perform the full compliment of aerobatic maneuvers.
This is a platform for an advanced flyer and is more complicated to build and fly. Beginners and intermediate flyers should still stay with the Flyguy Version 2.
What I don't like are the two exposed props of the two motors. I have always liked the added safety of the prop enclosed in the body, especially because Flyguy is such a kid magnet.
The two motors have differential thrust tied to the rudder stick which can generate significant yaw allowing hammerheads, 4 pt and slow rolls.
There are only two horizontal plates; the chest plate and main body plate. The main body plate is a combination of the old arm plate and the center body plate.
The body is 16 inches wide at the main body plate and 12 inches wide at the chest plate. The feet are hinged at 18.5 inches from the tip and not canted as on other Flyguys. The sides are still angled at about 15 degrees. A foam mannequin head is used up front and houses the batteries.
The two motors are HK 2200 kv with 45amp ESCs and two 3s2200mah batteries. Servos are Hitec HS-225MG.
Flyguy 62 Version 3 Fully Aerobatic with Twin Motors by Otto Dieffenbach (1 min 11 sec)
Old Feb 26, 2014, 05:35 PM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Cool, time to build a miniature version!
Petefoss is offline Find More Posts by Petefoss
Old Feb 27, 2014, 12:39 AM
Joined Aug 2011
You won't regret it. Great performer.
Old Feb 28, 2014, 03:39 PM
magik30 is offline
Joined Mar 2012
ok now my flyguy 62 to flying.
but no video .. soon ..
otto you have mounted the two engines like me?
Build Log Flyguy 46 Version 2 Otto Dieffenbach Foamies (Scratchbuilt) 131 Nov 06, 2015 03:02 PM
Build Log Flyguy 62 Version 2 Otto Dieffenbach Foamies (Scratchbuilt) 305 Sep 22, 2015 08:14 PM
Discussion Foamie Flyguy in 4 sizes Otto Dieffenbach Foamies (Scratchbuilt) 1665 Aug 14, 2015 07:14 PM
