Old Jan 25, 2014, 04:48 PM
magik30 is offline
Find More Posts by magik30
France, Languedoc-Roussillon, Nimes
Joined Mar 2012
first difficult test, I have to put the battery well before (2200 3s)
but just a little.
Tomorrow I'll try with a 3000 3s battery, to heavier front.
pour la vidéo demain...
for the video tomorrow ...
magik30 is offline Find More Posts by magik30
Old Jan 25, 2014, 05:00 PM
ttersu is offline
Find More Posts by ttersu
All can fly...Launch stronger!
ttersu's Avatar
France, Centre, Romorantin-Lanthenay
Joined Oct 2013
Oki
ttersu is offline Find More Posts by ttersu
Old Jan 26, 2014, 12:50 AM
magik30 is offline
Joined Mar 2012
hi
OTTO I have a CRIUS AIOP V2 MultiWii, you think I can do the same as you?
I see your flygui has changed a bit.
Please share you want.
how to fly horizontal,
Old Jan 26, 2014, 10:10 AM
Otto Dieffenbach is offline
Find More Posts by Otto Dieffenbach
United States, CA, San Diego
Joined Aug 2011
Originally Posted by magik30 View Post
hi
I am new to multirotor so do not know much about the MultiWii. If it preforms like the KK2.1 then you should be able to do it.
On the Flyguy I have the feet canted at 15 degrees to generate yaw in turns. I wanted to see what variable thrust would do to turn him. Embedding the quad let me test this and try to hover. He turns fine with differential thrust and hover is easy with a good FC board.
Hoverflyguy has canted sides for looks but the feet are level. He is also wider to accommodate the quad. The motors in the chest are close together and those on the top are spread. The top plate and center plate are combined into one center plate that passes through the center of the quad at the CG, about an inch behind the traditional CG.
Otto Dieffenbach is offline Find More Posts by Otto Dieffenbach
Old Jan 26, 2014, 10:18 AM
ttersu is offline
ttersu's Avatar
Joined Oct 2013
Otto, will you share this FlyGuy plans? He is quite different from other ones...
Old Jan 26, 2014, 10:53 AM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
If Otto has some dimensions or drawings I can REWORK the current plans
to achieve the proper HoverFlyGuy plans.
I figured that I'd wait for all the dust to settle re FC adjustments and configuration.
But I suppose a Heads p would be prudent at this time.
I'm Liking the Hover ability feature.
BTW I HAVE several different FC's.
So I'll be able to test when I get a chance to build.
( It's heading down to ~ -15 deg F in the next couple of days ! )
What Global Warming ?
Billions could be spent reducing MY carbon foot print and then
one Volcano could wipe out the gains and the $$ spent.
Sorry for rant - but it's seriously cold here just now ! :-(
Bob
birdofplay is offline Find More Posts by birdofplay
Old Jan 26, 2014, 10:57 AM
Joined Aug 2011
No problem. I am still working on him and learning. Basically, he is a standard V1 Flyguy62 widened 7 inches. The top plate and center plate are integrated into one top plate that runs the length. The breast plate is 13.5 x 7 inches. The feet are similar to Skyman's.
I started with 7 inch props but cut them down to 6 inches because I had too much thrust. Prop diameter controls all the measurements. I'd probably make him a couple inches thinner if I was starting again.
I am happy to provide all I know to this point but I feel there is still a lot to learn.
Do you think a separate thread should be started?
Old Jan 26, 2014, 11:02 AM
ttersu is offline
ttersu's Avatar
Joined Oct 2013
I think that a new thread for Hover(Fly)Guy would be nice and easier to find that lost posts in a full thread...
@Bob: A hot chocolate for your mind and a full tin box of Beans for Gas heating
Old Jan 26, 2014, 11:37 AM
magik30 is offline
Joined Mar 2012
the same opinion as ttersu
my good flyguy62 has trouble turning right and left, and when he started to turn it possitione the vertical.
Old Jan 26, 2014, 11:47 AM
ttersu is offline
ttersu's Avatar
Joined Oct 2013
We are demain
On est Tomorrow
Do you have enough rates?
Old Jan 26, 2014, 12:16 PM
magik30 is offline
Joined Mar 2012
We are demain
On est Tomorrow
no friend filmed
aucun ami a filmé
Yes for rates much movement on the flaps
oui beaucoup débattement sur les volets
Old Jan 26, 2014, 12:45 PM
ttersu is offline
ttersu's Avatar
Joined Oct 2013
still tail heavy...Try to mix elevator down when ailerons are working...
Old Jan 26, 2014, 01:01 PM
magik30 is offline
Joined Mar 2012
wait a minute, I'll put a video with deflections
Old Jan 26, 2014, 01:36 PM
ttersu is offline
ttersu's Avatar
Joined Oct 2013
oki
Old Jan 26, 2014, 02:57 PM
magik30 is offline
Joined Mar 2012
oki
as_tu regarder la vidéo ?
flyguy62 (0 min 42 sec)
watch?v=NQ6KeuNHtC4&feature=youtu.be
Build Log Flyguy 46 Version 2 Otto Dieffenbach Foamies (Scratchbuilt) 131 Nov 06, 2015 02:02 PM
Build Log Flyguy 62 Version 2 Otto Dieffenbach Foamies (Scratchbuilt) 305 Sep 22, 2015 07:14 PM
Discussion Foamie Flyguy in 4 sizes Otto Dieffenbach Foamies (Scratchbuilt) 1665 Aug 14, 2015 06:14 PM
