Old Feb 23, 2013, 08:19 PM
Alcuy is offline
Find More Posts by Alcuy
Flying is Living!
Savage, MT
Joined Mar 2008
Question
DLE 20 comparison to Glow 1.20 two stroke or 1.5 FS
I have a Seagull Gee Bee Super Sportster 71" wingspan ARF I am starting to assemble. I am trying to determine if a DLE 20 will be enough power. It fits 1.20 mounts and would work in the plane but I do not want to be too underpowered. The specs call for a 1.2 two stroke (glow I assume) or a 1.5 cubic inch four stroke. Since I have never run those sizes in glow engines, I am at a loss for the difference in thrust developed. The plane is supposed to weigh in around 11 pounds.
I think the DLE 20 would work but would rather not do the trial and error thing.
Alcuy is offline Find More Posts by Alcuy
Old Feb 23, 2013, 10:00 PM
johnfly1234 is offline
Find More Posts by johnfly1234
United States, KS, Arkansas City
Joined Oct 2012
I have a dle 20 on a nitro models ultimate weight is right at 10 lbs. and allot of drag from the 2 wings but the 20 really hauls it around nicely ! I would compare the power closer to a 150 f/s. Have settled on the 17x6 xoar. can't remember what it turns...... Thinking low 8s. you should be fine.........hmmmm just had a thought........ Unless you come out tailheavy!!!!!!!!!! The 20 will put out around 14 lbs of thrust so you will be able to go straight up !! As long as the all up weight is 11 lbs. I was raised in montana !!!!!! "Big Sandy" small world !
johnfly1234 is offline Find More Posts by johnfly1234
Old Feb 23, 2013, 10:03 PM
Joined Oct 2012
http://www.nitroplanes.com/ul12055nigas.html
Old Feb 23, 2013, 10:28 PM
Alcuy is offline
Flying is Living!
Savage, MT
Joined Mar 2008
Thanks for the info! I was thinking the DLE 20 might be OK but I what little comparative information I have been able to find so far was not much help. It may come light on the nose, but I think that can be dealt with; prefer to add useable weight if it is needed though. Move everything forward first if possible.
Montana is a great State; if a little cold in the Winter. Lots of good people are from here. Thanks again!
Old Feb 24, 2013, 11:31 AM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
That DLE will eat up any 120 glow. It has as much power as alot of 26 cc gassers
kerwin50 is offline Find More Posts by kerwin50
Old Feb 24, 2013, 12:46 PM
Alcuy is offline
Flying is Living!
Savage, MT
Joined Mar 2008
This info helps a lot! I appreciate the response.
I am moving ahead with the DLE 20 and am now optimistic that the performance will be what the plane needs.
Old Feb 25, 2013, 07:54 AM
ahicks is online now
Find More Posts by ahicks
United States, MI, Waterford Charter Township
Joined Aug 2008
If you're too concerned put a 30 or 35 in it? You're only talking about another 8oz or so? That move would let you up into the 19 and 20" prop sizes vs. the 20's limit of about 17"?
ahicks is online now Find More Posts by ahicks
Old Feb 26, 2013, 03:01 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Yes I agree with that. The DLE 30 would pull that plane around like a rag doll
Old Feb 28, 2013, 09:26 PM
Alcuy is offline
Flying is Living!
Savage, MT
Joined Mar 2008
I'll take a look at the 30 and see if mounting will fit without too much modification. But the Gee Bee is a racer and I guess a guy can always throttle back a little more to save the frame if the 30 does pull it around like a rag doll.
It sounds like the 20 is probably enough, so I'll have to think some more. Decisions, decisions...
Thanks for your input!
Old Mar 06, 2013, 05:44 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
How did it fit? I just bought a DLE 30 and have an AT-6 by Seagull and was thinking of putting it on that plane....My Seagull Gee Bee Z has a Saito 180 and has a lot of power for that plane!
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ Ki-61
Old Mar 24, 2013, 04:40 PM
dogshome is offline
Find More Posts by dogshome
dogshome's Avatar
Joined Dec 2006
More than a SPE26, CRRC 26 red barrel and CRRC 26 rear carb. Similar to a 180FS on glow, bit more than a 180FS on petrol - from personal experience!
A little Gem of a powerhouse which will fly a 71" monoplane no problemo.
Only thing is the huge cowl on the Gee Bee! 18" prop is maximum (too big really) for a 20. Also I doubt that weight at the front will be a problem, so a bigger lump should be an easy fit.
EDIT:- I just watched a review with a Saito 180 and 16*8 prop - plenty of power. Dle20 should be fine.
dogshome is offline Find More Posts by dogshome
Old Mar 27, 2013, 04:37 PM
takEon is online now
Find More Posts by takEon
United States, TX, Wichita Falls
Joined Mar 2013
So would the DLE 20cc work on a CGM Bucker Jungmann? I'm leaning, but still cautious.
takEon is online now Find More Posts by takEon
Old Mar 29, 2013, 05:23 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
On youtube I seen a video of a 150 4 stroke powering it.So the dle 20 will pull it around very nice, but if you want unlimited vertical and lot's of power get the DLE 30.
Old Mar 29, 2013, 11:43 PM
findhobby is offline
Find More Posts by findhobby
Joined Jan 2013
I agree
we have dle 20cc ,so we know the detail ,you can use Dle 20cc.
findhobby is offline Find More Posts by findhobby
Old Mar 30, 2013, 08:49 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
My DLE 20 should be here any day. I got a frank bowman ring coming for it as well.
I put a frank bowman ring in my DLE 30 and it gives me 20 lbs of thrust.
I'm going to also do the reed block mod as well.
Discussion DLE 20 mental block - WOT or idle? grosbeak Engines 9 Oct 08, 2014 08:05 AM
Wanted os .20 or .26 four stroke engineguy63 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Apr 19, 2013 09:45 AM
Wanted Inverted pitts muffler for OS fs 1.20 xcz5785 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 04, 2013 11:12 AM
Discussion 20cc DLE vs 1.20 Glow Dale 813 Engines 2 Oct 25, 2011 06:43 AM
Wanted Looking for a .90 to 1.20 2 stroke glow engine Buzz Bomb Aircraft - Fuel - Engines and Accessories (FS/W) 1 Nov 01, 2008 03:31 AM
