Old Dec 30, 2003, 11:14 PM
Gerhard is offline
Find More Posts by Gerhard
Los Gatos, CA, USA
Joined Nov 2003
Question
wes tek 2.4 servo modification
Hi,
Has anyone modified a Wes Tek servo by removing the 6mm pager motor and substituting a 4mm pager motor? I figure this could save about 0.6 grams for each servo. I am very tempted to do this, but I don't want to ruin an expensive servo.
If anyone has done this, please share your problems and successes (or not so successful, as the case may be).
Thanks in advance for your help.
Gerhard
Gerhard is offline Find More Posts by Gerhard
Old Dec 31, 2003, 12:12 AM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
i've heard it has been done but the motor overheats (needs different gear ratio).
forget it, buy some falcons!
opualuan is offline Find More Posts by opualuan
Old Dec 31, 2003, 02:53 AM
nachman is offline
Find More Posts by nachman
Tel Aviv-Yafo Sde Dov, Israel
Joined Nov 2002
The friction in the linear potentiometer is way to much for the 4mm motor. The motor doesnt have enough power to get to the desired position where current thrue the motor is 0. Motor is alway under current and therfore gets hot. Position is always some what off the desired position. I have both LS2.4 and LS3.0. I like them both, but I like the LS3.0 more because of it higher motor power. Wouldn't recomend you to try replacing the motor, but if you decide to do it you can always switch back as long as you don't let the motor drivers get to hot and burned them out.
Nachman
nachman is offline Find More Posts by nachman
Old Jan 01, 2004, 11:39 AM
Gerhard is offline
Los Gatos, CA, USA
Joined Nov 2003
Thanks, Nachman,
for your opinion. I'll probably leave it alone. it's a lot of fiddling and I would not want to have to reverse it if I tried it unsuccessfully.
regards,
Gerhard
Old Jan 01, 2004, 02:33 PM
IceDancer is offline
Find More Posts by IceDancer
IceDancer's Avatar
San Francisco
Joined Feb 2003
In this same vane, would it work to change the 3.0 motor with the 2.4 motor and save some weight. I have 2ea 3.0 and don't want to pay the cost of new 2.4's.
Thanks!
Sam.
IceDancer is offline Find More Posts by IceDancer
Old Jan 01, 2004, 07:19 PM
nachman is offline
Joined Nov 2002
The motors on the LS2.4 are 6 x 12mm and I measured about 11 ohms. You should be ok doing that switch with any compatible motor.
If you like, I would trade with you. I'll give the 2.4 motors (original Wes) and if it works for you, you'll send me the bigger motors. I should have three of them.
Westek 2.4 Servo's strouse Scratchbuilt Indoor and Micro Models 0 Aug 04, 2002 12:39 PM
Which airframe best for wes-teknic 2.4? Bleriot Scratchbuilt Indoor and Micro Models 6 Jan 25, 2002 03:57 AM
WES Technik DC5-2.4 geared coreless motor Neil Stainton Aircraft - Electric - Airplanes (FS/W) 1 Nov 23, 2001 12:13 PM
model recommecfation for Wes DC5-2.4 8:1 9x4.7 opualuan Parkflyers 8 Oct 12, 2001 08:21 AM
wes 2.4 servo conversion fw190a Parkflyers 0 Jul 13, 2001 02:34 PM
