Old Feb 23, 2013, 05:05 PM
Bartb is offline
Find More Posts by Bartb
United States, MI, Grand Rapids
Joined Feb 2013
Coating the inside of a hull
I've been reading the build logs and have a question regarding the resin. Should I be using a two part resin, is there anything but a two parter and should it be thinned. And finally what's the best way to thin it. What should the consistency look like.
Bartb is offline Find More Posts by Bartb
Old Feb 23, 2013, 05:14 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Ask a simple question, get lots of answers!
http://www.rcgroups.com/forums/showthread.php?t=1824411
http://www.rcgroups.com/forums/showthread.php?t=1825636
patmat2350 is offline Find More Posts by patmat2350
Old Feb 23, 2013, 07:03 PM
redlined_b16a is offline
Find More Posts by redlined_b16a
Joined Jun 2008
I like the pacer z-poxy
Really thin
No Oder and dries hard and smooth
West would problly be the most highly recommended
redlined_b16a is offline Find More Posts by redlined_b16a
Old Feb 23, 2013, 09:27 PM
tinknocker is offline
Find More Posts by tinknocker
tinknocker's Avatar
New Jersey
I use pacer z-poxy finishing resin also Thinned with denatured alcohol. Keep it on the thin side.
Doug
tinknocker is offline Find More Posts by tinknocker
Old Feb 24, 2013, 09:31 AM
Tollytime is offline
Find More Posts by Tollytime
Tollytime's Avatar
United States, MI, Macomb
Joined Nov 2006
I've been telling everybody for years about Smith & Co. Penetrating Epoxy Sealer. It's thin like water and soaks in deep. It's so thin, you actually have to look twice on a treated piece of wood after it dries.
http://www.smithandcompany.org/CPES/index.html
Here's a clip for rotting wood treatment. This is only one of the many uses for CPES. I love to use it as sealer on new wood.
Buy the pint kit at http://www.jamestowndistributors.com...etrating_epoxy
Smith & Co. CPES (3 min 7 sec)
Tollytime is offline Find More Posts by Tollytime
Old Feb 24, 2013, 02:26 PM
wshores is offline
Find More Posts by wshores
United States, NY, Lockport
Joined Mar 2012
Z- poxy help suggestion to try
In the past couple days I have tried warming up the Z- Poxy before mixing. I placed the bottles in hot water to warm them before mixing. With doing this I found that the resin was thinner, mixed and went on much smother with a lot less orange peel look. I feel the reason for this is the resin was too cold and wisent able to flow as it should.
I keep the Z- Poxy in the basement workshop and there is little heat overnight so the Z-Poxy was too cold to use and needs to be warmed up before use This has worked for me so give it a try and see if this helps for you , check out the pictures
WShores
wshores is offline Find More Posts by wshores
Discussion Coat the inside of the plane with thinned epoxy? grosbeak The Builders Workshop 19 Jan 07, 2012 09:19 AM
Discussion Hull coatings to improve speed bob93447 Racing Boats - Electric 7 Apr 12, 2011 02:33 AM
Discussion Delta Force Fiberglass hull.....question on clear coat thomaslambo Racing Boats - Electric 2 Nov 26, 2010 06:45 PM
Mini-HowTo Clear Coating Mahogany Hulls With Spar Varnish P. Tritle Scale Boats 36 Jun 30, 2008 12:06 PM
Discussion Coating the inside? Royster Fuel Plane Talk 7 Jul 01, 2007 05:10 PM
