Old Feb 23, 2013, 05:05 PM
lx2008 is offline
Find More Posts by lx2008
United States, PA, Schellsburg
Joined Jan 2013
Question
120 blade grip adj.?
hi, got a nube question.
just finished reading a tutorial on the 120sr. in this reading it is said to tighten the blade grips just enough to keep the blades from flopping when the heli is turned on its side. can still be easily moved by a finger but gravity can`t pull them down. this is said to make the blades from lagging behind each other and in turn, make the heli more stable.
but i have read in this forum or maybe it was another, that doing this it may cause the toilet bowl effect. the 120 manual says to keep them a little loose. being a nube i don`t know who is right.
what do you guys have to say to this?
thanks.
lx2008 is offline Find More Posts by lx2008
Old Feb 23, 2013, 06:10 PM
JChoosier is offline
Find More Posts by JChoosier
J.C.
JChoosier's Avatar
United States, IN, Goshen
Joined Feb 2013
I'm a nooB with a 120sr also. I tightened my blades up like so many recommend and it seems to make the heli fly even more stable than it already was. I haven't noticed any ill effects so far. Hope this helps
JChoosier is offline Find More Posts by JChoosier
Old Feb 23, 2013, 06:11 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
The blades can be a lot looser than you think. If they track clean, you won't have any problems. But, follow the recommendations, anyway.
Balr14 is offline Find More Posts by Balr14
Old Feb 23, 2013, 09:55 PM
arbilab is offline
Find More Posts by arbilab
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
My 120 wants to run looser than my coaxes in the same size class. I have quoted the "gravity flop" rule but I have come to recognize that it is not golden. If you do that to submicros they will almost always toiletbowl or vibrate violently.
arbilab is offline Find More Posts by arbilab
Question Syma S113G Main Blade Grip Removal? Spirittoo Coaxial Helicopters 5 Feb 02, 2013 03:41 AM
Help! Screw sheared off in CB100 blade grip eyemdee Micro Helis 6 Jan 22, 2013 12:30 PM
Sold New Corona 120 canopy, drive-wire, #3 grips & #6 grips, and parts Rondog Aircraft - Electric - Helis (FS/W) 0 Mar 27, 2011 05:29 PM
Wanted looking for corona 120 blades and grips 007 Aircraft - Electric - Helis (FS/W) 0 Nov 24, 2007 07:32 PM
Question changing degrees on blade grips for corona 120 2hotrotts Mini Helis 2 Sep 24, 2007 05:31 PM
