Old Feb 23, 2013, 03:08 PM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Hot Epoxy
It's a good thing....Right !
Warm epoxy will flow nicely where cold epoxy is just too sticky and thick to fully wet out the glass. Even more useful when using a device like a tow wetter. But warm does not mean hot.
This morning I was trying out a new tow wetter and recognized that things would be easier if the cold epoxy was a little thinner. Sooooooo, I mixed up a cup of epoxy and put the heat gun to it and stirred until it was runny like maple syrup. Only took a minute on the low setting. Certainly not hot enough to melt or even deform the plastic cup. About 1/2" of epoxy in the bottom of the cup.
Then I got to drawing out the wetted CF tow and draping it on the model. Maybe 5 minutes later the epoxy started foaming and hissing and went off like volcano. It was "insta-cure" epoxy. This is what you don't want. Sound familiar?
2nd batch was with cold epoxy and the wetter worked just as well.
Tow Wetter 2 (0 min 0 sec)
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Feb 23, 2013, 04:31 PM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Kent,
I think at one time or another, we've all been introduced to Mr X. O'Therm.... Most annoying when he comes to visit, eh?
Hope you're well and regards from snowy Derbyshire
Shedofdread is offline Find More Posts by Shedofdread
Old Feb 23, 2013, 05:00 PM
Lawrence B is offline
Find More Posts by Lawrence B
Live and let Fly !
Lawrence B's Avatar
Mill Hill - London
Joined Aug 2009
A long time ago, making boat hulls with polyestor resin i managed to have a small bucket of the stuff smoking thru excess exotherm ... without any external heat !!
LB
Lawrence B is offline Find More Posts by Lawrence B
Old Feb 23, 2013, 10:13 PM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
Heat gun is to hot, a hot box at 40deg works wonders. I know a guy that used to put resin in the microwave for a couple seconds just to 'kick it off a bit'
Till this day, I am yet to try it. I think its something you do after a couple of beers
SB7 is offline Find More Posts by SB7
Old Feb 24, 2013, 06:48 AM
chetosmachine is offline
Find More Posts by chetosmachine
chetosmachine's Avatar
Madrid, Spain
Joined Sep 2004
Use slower hardener and you can heat the epoxy.
You can also heat only the resin, not the mix. This prevents a bit the exothermic, but it's not magic, it will increase temperature and exo will happen.
chetosmachine is offline Find More Posts by chetosmachine
Old Feb 24, 2013, 09:04 AM
JIM CALDWELL A is offline
Find More Posts by JIM CALDWELL A
Cleveland Cuyahoga, Ohio, United States
Joined Dec 2000
Heat the resin and hardner bottles in a bucket with hot water from the tap.
15 mins from 55 F get to 80-85 degrees, then mix.
JIM CALDWELL A is offline Find More Posts by JIM CALDWELL A
Old Feb 24, 2013, 03:39 PM
T.D. is offline
Find More Posts by T.D.
T.D.'s Avatar
Canada, BC, Parksville
Yeah, use hot tap water.
Be very careful with a heat gun and epoxy, inhaling the vapour produced can have serious health effects.
T.D.
T.D. is offline Find More Posts by T.D.
Old Mar 04, 2013, 06:34 PM
sarmoby is offline
Find More Posts by sarmoby
Composites guy
North OC, Ca.
Joined Jun 2005
Also, heat the tow.
sarmoby is offline Find More Posts by sarmoby
Old Mar 04, 2013, 07:08 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Different resins behave differently to each other as well. Some of the better quality low viscosity resins don't need heating to start with, and when/if they are heated, don't exotherm as much and as readily as the cheaper inferior products.
Bit of a catch 22 actually!
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Mar 05, 2013, 11:40 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Mixing epoxy in larger batches confines the heat energy from the exotherm and amplifies things. Spreading it thinner or using larger, shallower containers helps slow it down if that's your goal.
I had a quart of West Systems heat up and solidify so fast one time that I dropped the container while I was still mixing it! Most of us have had a bad day due to "premature" exotherm.
Be careful warming stuff to make it flow more easily though. Obviously you shorten the cure time but you could also significantly reduce the physical properties of the finished product when you accelerate the initial cure with heat.
I like to heat up a scrap piece of marble countertop by running it under hot water while I'm mixing the epoxy. When the epoxy is mixed, I pour some of it on the marble and it gets more flowable but still has a large enough surface area to avoid the "flash" cure. The marble is a nice place to pick up epoxy for the roller as well.
tom43004 is offline Find More Posts by tom43004
Old Mar 05, 2013, 11:53 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
I did not know this. Curing concrete has similar problems when it is allowed to dry out too quickly especially right after initial set.
I'm thinking of warming the resin to 80F as a matter of standard practice. Do you have any data showing strength vs initial heating?
Kent
Old Mar 05, 2013, 12:02 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
It varies by epoxy Kent. Most of the manufacturers will post a datasheet online.
Here's an interesting full scale link:
http://www.cozybuilders.org/Oshkosh_...oxyDoDonts.pdf
and a datasheet on one particular brand:
http://www.mgs-online.com/en/techinfo/pdf/01mgs037.pdf
Old Mar 05, 2013, 12:27 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Thanks Tom. Just the tip of the iceberg for info. on epoxy, I'm sure.
Attached is possibly an easier to download version of the Do and Don'ts Tom just posted.
Old Mar 13, 2013, 12:53 AM
jason128 is offline
Find More Posts by jason128
New Zealand
Joined Jul 2009
+1 on the warm water bath - keeps the epoxy warm, but stops it overheating too.
standard practice in the boatbuilding industry.
jason128 is offline Find More Posts by jason128
Discussion Epoxy vs Hot Glue Gun cloud_9 Beginner Training Area (Aircraft-Electric) 24 Jan 16, 2013 05:50 AM
Discussion Epoxy problem, soft when hot... SilentHunter Composites Fabrication 10 Sep 05, 2008 09:22 PM
Discussion Epoxy getting hot and curing too quickly? buurin The Builders Workshop 17 Jul 30, 2007 01:21 AM
Help! Hot glue vrs. epoxy? met Beginner Training Area (Aircraft-Electric) 8 Jul 08, 2007 09:24 PM
Discussion Hot Box for Post Curing Epoxy jtprouty Composites Fabrication 13 Feb 15, 2006 03:52 AM
