Old Feb 23, 2013, 01:43 AM
T. van Vuuren is offline
Find More Posts by T. van Vuuren
Theuns
T. van Vuuren's Avatar
Joined Sep 2011
450 Tail rotor hub failure
Hi all.
I was given a T-rex 450 with almost all the "bling" upgrades there is, full metal head ect.
Here is my hassle though, I have now had 2 failures of the pivot bolt shearing of that holds on the tail rotor grip. Luckely both times no damage to the heli.
One was a full metal unit the other was the plastic one, same failure on both - the 2mm bolt lost it's head and the grip departed the hub.
Is this a common thing with 450 T-rex?? Could the rotor speed be to high for the hub assembly?
I can easly get a replacement of the whole unit fro HK, just wondering what would cause the repeat failures.
Any ideas or advice please.
Thanx
Theuns
T. van Vuuren is offline Find More Posts by T. van Vuuren
Old Feb 24, 2013, 05:54 AM
rcnewbieoz is offline
Find More Posts by rcnewbieoz
Fan of experimetalairlines
Australia, NSW, Sydney
Joined Jan 2012
Originally Posted by T. van Vuuren View Post
Hi all.
Thanx
Theuns
Are you getting alot of vibration in the tail? It could be causing the bolt to fatigue and break.
rcnewbieoz is offline Find More Posts by rcnewbieoz
Old Feb 25, 2013, 11:05 AM
Theuns
Joined Sep 2011
No not realy allot more than I would expect. I didn't build this heli, maybe someone before me somehow damaged the bolts by over tightning them....
I will buy a new complete unit from HK, was just wondering if there are any particular brands I should rather avoid?
Theuns
Discussion trex 450 v2 pro tail rotor siandhell Beginner Training Area (Heli-Electric) 3 Sep 13, 2013 02:30 PM
Discussion screw in tail rotor hub snapped..is this common? its a copterx 450 spor1322 Mini Helis 6 May 27, 2009 11:51 AM
Discussion Question: T-Rex V2 - Tail : Tail Rotor Shaft/hub/Set Screw Santini Mini Helis 4 Apr 09, 2008 11:03 AM
Sold Align cnc tail rotor & Steel Tail rotor hub Orion_V Aircraft - Electric - Helis (FS/W) 1 Jan 03, 2006 03:30 PM
ECO 8 Tail Rotor Hub and Tail Blade Holders question Xfaega Electric Heli Talk 3 Sep 28, 2004 11:55 PM
