Old Dec 30, 2003, 07:27 PM
Blackhawk3D is offline
Find More Posts by Blackhawk3D
Dreamin' in 3D
Blackhawk3D's Avatar
Lodi/San Luis Obispo
Joined Oct 2003
HD3D construction thread (Help me build my new plane!)
I just got home a few hours ago from RC Country in Sacramento CA, returning with a brand new HD3D. I have installed the motor (GWS EPS350C C gearbox, stock motor for now and a 11x4.7. Everything is looking great at this point. I am now starting to instal the wing, rudder, elevators, etc. I just need some tips on how to bevel stuff etc. Pics would be great. Thanks alot!
Blackhawk3D is offline Find More Posts by Blackhawk3D
Old Dec 30, 2003, 08:09 PM
GW is offline
GW
Find More Posts by GW
GW
Shula Who??
GW's Avatar
Guntersville, AL
Joined Aug 2003
Blackhawk
Download Tim Harts plans for the 3dx. in that plan set you will find the best beveling and hinging info anywhere.
GW
GW is offline Find More Posts by GW
Old Dec 31, 2003, 01:26 AM
tabbytabb is offline
Find More Posts by tabbytabb
tabbytabb's Avatar
Seattle, Washington, United States
Joined Mar 2003
I bevel my edges using a mach 3 razor cartridge. It works great and gives a nice clean bevel
Tabb
tabbytabb is offline Find More Posts by tabbytabb
Site Sponsor
Old Dec 31, 2003, 02:28 PM
Dreamin' in 3D
Joined Oct 2003
bump
bad news, I screwed up the stabilizer when I cut the bevel. I will have to wait for a new one to get here. . I have cut out the wingtip covers and the battery covers are on. I need the best way to bevel them with the least chance of screwing up.
Old Jan 01, 2004, 09:38 AM
david harris is offline
Find More Posts by david harris
3D Outlaw
david harris's Avatar
Spring Valley Lake CA.
Joined Aug 2003
I alwas use a 220 grit sanding block for beveling, depron sands
nicely...
david harris is offline Find More Posts by david harris
Old Jan 01, 2004, 03:29 PM
katana1211 is offline
Find More Posts by katana1211
san francisco, ca
Joined Feb 2002
hi tabb
i am interested in your method, can you post a pic how do use mach 3 razor to blevel the joints
thanks in advance
katana1211 is offline Find More Posts by katana1211
Old Jan 02, 2004, 08:27 PM
montu is offline
Find More Posts by montu
3D Pilot
montu's Avatar
Orlando, FL
Joined Dec 2002
Yea tabb send a pic on how to use the mach 3.
thanks
-jordan
montu is offline Find More Posts by montu
Old Jan 03, 2004, 04:08 PM
Dreamin' in 3D
Joined Oct 2003
Bump
What is the best way to join the elevator halves? I have the supplied wire but also have some .06 carbon rod which was suggested by Terry at RC Country to help stiffen up the wing. I bought about twice as much as I need.
Old Jan 03, 2004, 04:15 PM
3D Outlaw
Joined Aug 2003
I BUILT MY FIRST PLANE WITH CARBON ROD THIS WEEK, IT SEEMS TO WORK FINE, AS DID THE .032 WIRE JOINER.
Old Jan 05, 2004, 03:06 AM
heymanwatchis is offline
Find More Posts by heymanwatchis
Joined Nov 2003
Scotch tape
Low tech , but it has worked for me. Sticks to depron like....tape.....huh....oh well. That should work fine for the 350. If you upgrade your powerplant, you may try packing tape, inside and out of the hinge.
heymanwatchis is offline Find More Posts by heymanwatchis
Old Jan 05, 2004, 09:09 AM
Dreamin' in 3D
Joined Oct 2003
Not to hinge them, to join the two halves.
Old Jan 05, 2004, 09:17 AM
montu is offline
3D Pilot
montu's Avatar
Orlando, FL
Joined Dec 2002
Will the plane do all right w/o a carbon rod in the wings or am I gonna rip them off doing 3d? Do I need it that bad? If I do need it, could u post a pic of how you did it? thanks
-Jordan
Old Jan 05, 2004, 09:23 AM
Dreamin' in 3D
Joined Oct 2003
it isn't nessasary, I just thought that it was a good thing to do. You use a small diameter rod, mine is .06, but any small rod will do. You put 5 minute epoxy on the rod and set it in the inside leading edge. Hold the wing up vertical and let gravity pull the rod as far into the tip as it will go. wait 10 minutes or so and you are set.
Another Question. I have Probond PolyU glue and 5 Minute epoxy. Which would work best for putting the wing in? I want the strongest joint with the least fuss. Thanks.
Old Jan 05, 2004, 10:12 AM
3D Outlaw
Joined Aug 2003
The wing is one of the strongest parts on the plane, the carbon rod inside is really unnecessary, I cartwheeled one of my HD3D's yesterday due to a dumb thumb, wing was fine, cracked the body.
I have never damaged one of my planes in flight, because I keep the wing loading at a minimum. I have used razor and himax motors on 3 cells without any reinforcements (no issues!)
Its not the speed that kills, Its those unintensional landings,
Old Jan 05, 2004, 01:14 PM
Dreamin' in 3D
Joined Oct 2003
Any suggestions on the glue for the wing? Also what would be a better combo once I go brushless
HImaxx 2015 4100 D gearing 12x6 3S lipoly
Himaxx 2015 5400 C gearing 11x4.7 (or Whatever is suggested) 2S lipoly
Thanks.
Help Me Setup My New Workshop Steve McBride The Builders Workshop 40 Jul 19, 2003 09:59 PM
help me build my new superstar ep. i am having problems someone special Parkflyers 25 Jan 19, 2003 05:38 AM
Help Me With My New Hornet Please? Voltage Micro Helis 14 Nov 04, 2002 07:09 AM
Help me design my new workshop.... Steve McBride The Builders Workshop 0 Oct 03, 2002 10:22 AM
Help me choose my next plane. compuatic Parkflyers 15 Jun 29, 2002 07:52 PM
