Espritmodel.com Heli Air
Old Feb 22, 2013, 06:56 PM
Aviation Maintenance Manager
carrera mike's Avatar
Joined Dec 2012
what o you call this? 2 pushrod to 1
Help, what do you call this linkage connector that links 2 elevator pushrod to 1 pushrod and onto the servo? I want to order it but dont know the name
Thanks!
carrera mike is offline Find More Posts by carrera mike
Old Feb 22, 2013, 07:41 PM
I bail out, anywhere, anytime
Taurus Flyer's Avatar
The Netherlands, OV, Almelo
Joined Nov 2010
Thanks!
Mike, here is an aviation maintenance manager, asking the same, maybe he can give you the answer in the near future.
http://www.rcgroups.com/forums/showt...7#post24219975
Or, RCUniverse, ask there?
Taurus Flyer
Taurus Flyer is online now Find More Posts by Taurus Flyer
Old Feb 22, 2013, 07:58 PM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
nothing works as good as wiring & soldering the two pushrods together!
whiskykid is offline Find More Posts by whiskykid
Old Feb 22, 2013, 09:29 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I remember people just making them before. One way is to take a piece of aluminum and drill three holes in it for the pushrods. You can then either drill and tap holes for set screws, or even tap the holes and screw the pushrods into it, or both even.
The simplest method is to use a couple of wheel collars and one long pushrod and one slightly shorter pushrod and tighten up the set screw as needed. That locks them both together. Handy for routing pushrods through tubing to the back of the plane.
I have typically just used dental floss and wrapped it around the two pushrods (one longer and one slightly shorter) to join them together. I then super glue the floss and the two parts are bonded to each other really well then. In the past I used epoxy resin to do the same thing. But nowadays super glue works great on the dental floss.
Years ago the Y pushrod was commonly used. One long pushrod was coupled with a second one and a Y was formed. You would thread two lengths of string down into the fuselage from the elevators on both sides. Then tie the string to the Y ends and pull it through to the back of the plane as needed. You could bend the pushrod wires as needed for smooth operation. Coupling the second pushrod on was done using copper wire and solder. But dental floss and epoxy resin or nowadays using super glue does the trick too.
earlwb is offline Find More Posts by earlwb
Old Feb 22, 2013, 09:37 PM
Joined Dec 2012
Taurus Flyer
Thanks TF. Thats me asking in that different board
I've seen them but dont know what they're called(proper nomenclature) to order or search for the piece.
thanks for the tip to ask at RCUniverse. I just posted it there too.
Old Feb 22, 2013, 09:43 PM
Joined Dec 2012
The simplest method is ......
Thanks for this very good tip. Appreciate your time.
I was searching Towerhobbies for the piece with no luck. I swear its made by Dubro or Sullivan. Youre right its just an aliminum block with three set -allenscrews locking the pushrod wires in place.
Old Feb 23, 2013, 06:25 AM
Kansas City
Joined Apr 2010
I have seen such a device in a World Models AT-6 arf. I replaced it with copper wire wrap and silver solder as whiskykid suggested.
Lifer is offline Find More Posts by Lifer
Old Feb 23, 2013, 07:56 AM
AKA "Fingers"
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
When I put the three rods together and solder them I try to use rods with threads on them. I put the threaded ends together, wrap with copper wire and solder. The threads lock the rods to each other and the chance of them slipping is next to zero.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Feb 23, 2013, 09:33 AM
rjstrickjr's Avatar
United States, NC, Faison
Joined Jan 2011
A couple of wheel collars do the trick and you can adjust them if you need to.
The proper name I think is a V-Tail mixer and they have them all over the place but are rarly used anymore. I think I even have one NIP and never used it.
rjstrickjr is offline Find More Posts by rjstrickjr
Old Feb 23, 2013, 10:25 AM
Joined Dec 2012
Found it at the local hobby shop I guess it's called TRIPLE ROD CONNECTOR!!
Thanks to all who try to help. Appreciate it
Old Feb 25, 2013, 02:03 PM
Zor
Zor's Avatar
Ontario,Canada
Joined Feb 2007
Suggestion
Suggest you make your setup and tighten the three set scews.
Then take it apart and file a flat where the set screws made their mark.
Re-install and tighten the scews again on the flats.
If a screw becomes loose the rods will not get out of range.
Zor
Zor is offline Find More Posts by Zor
Old Mar 03, 2013, 08:58 AM
Joined Dec 2012
Thanks for all the help gents.
Here's what i did. BTW, the 1st reason I did this was i didnt like the factory /oem elevator configuration of my Zero aircraft. It was causing uneven elevator throws.
Old Mar 04, 2013, 05:31 AM
Illegitimi non carborundum
grosbeak's Avatar
Joined Mar 2011
The Sullivan product is the 2-56 Ball Type Elevator Splitter.
grosbeak is offline Find More Posts by grosbeak
Old Mar 04, 2013, 07:05 AM
Joined Dec 2012
Thats even a nicer setup. Looks like it absorbs initial shocks with its springs. :thumbup:
Old Mar 04, 2013, 09:16 AM
grosbeak's Avatar
Joined Mar 2011
So it would appear - but the spring is actually there to keep tension on the socket cover (the white part). I have the same type of connector on my DLE 20's throttle:
Pulling the socket cover back against the tension of the spring allows you to remove the socket from the ball.
Discussion 1/3 scale scratch SU-31 pushrods RJPIoW Giant Electric Planes 0 Jan 15, 2013 02:30 PM
Discussion The NRA called this evening AA5BY Life, The Universe, and Politics 72 Jan 11, 2013 10:49 AM
Got a bet going. What do you call this? Mike C Power Systems 21 Apr 28, 2002 01:36 PM
Now this is what i call Customer support kushal_22 Vendor Talk 5 Apr 21, 2002 02:16 PM
Who owns this? What is it called? nolasco Indoor and Micro Models 9 Nov 30, 2001 11:05 AM
