Old Feb 22, 2013, 06:45 PM
carrera mike is offline
Find More Posts by carrera mike
Aviation Maintenance Manager
carrera mike's Avatar
United States, VA, Chesapeake
Joined Dec 2012
2 Elevator Pushrods to 1 Pushrod ???
Help, what do you call this linkage connector that links 2 elevator pushrod to 1 pushrod and onto the servo? I want to order it but dont know the name
Thanks for the help!
carrera mike is offline Find More Posts by carrera mike
Old Feb 23, 2013, 06:47 AM
Al M is offline
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
I make mine.
Al M is offline Find More Posts by Al M
Old Feb 23, 2013, 10:22 AM
Joined Dec 2012
Found it at the local hobby shop I guess it's called triple rod connector!
Old Feb 23, 2013, 12:59 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Or you could use a single terminal block taken for a terminal strip.
Two wires in one end, one wire in the other, overlap in the middle so both screws grip.
eflightray is offline Find More Posts by eflightray
Old Feb 24, 2013, 05:39 PM
Joined Dec 2012
I thought about this but cant find one thats small enough for the foamy wire.
Old Feb 26, 2013, 09:09 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
I don't know if this idea is any good for your set up.I found apiece of alu tube which would just accept the two rods when slightly flattened,epoxy and crimped tight.At the single end I epoxied a carbon rod and crimped the tube either side.Heat shrink to tidy up.I've given it a few hard tugs,seems strong enough.
Stuart A is offline Find More Posts by Stuart A
Old Mar 01, 2013, 08:46 PM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I've used wheel collars in the past. Worked ok.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Mar 03, 2013, 08:54 AM
Joined Dec 2012
Thanks for all the help gents.
Here's what i did. i didnt like the factory /oem elevator configuration of my Zero aircraft. It was causing uneven elevator throws.
Old Mar 30, 2013, 08:55 PM
hyperknight is offline
Find More Posts by hyperknight
hyperknight's Avatar
Irvine, CA
Joined Apr 2003
Ah... Exactly what I was looking for as well. Any idea where I could get one of these triple rod connectors from the states? I've tried looking at Tower, Horizon and Hobby King. None of the major online retailers carry this type of rod connector.
hk
hyperknight is offline Find More Posts by hyperknight
Discussion 1/3 scale scratch SU-31 pushrods RJPIoW Giant Electric Planes 0 Jan 15, 2013 02:30 PM
Sold CST, etched/bondable pushrod sheathing - 1/2 price dhauch Aircraft - Sailplanes (FS/W) 4 Jan 24, 2012 09:06 AM
Help! larger of 2 pushrods for rudder or elevator? sellonoid The Builders Workshop 19 Jan 20, 2009 02:14 PM
Question Electra ARF - elevator pushrod help Ninjak2k Electric Sailplanes 19 Mar 26, 2004 04:09 PM
How do you attach your pushrods to your ailerons/elevator? Pritos High Performance 4 Aug 11, 2002 04:04 AM
