Old Feb 22, 2013, 04:50 PM
CapMike is offline
Find More Posts by CapMike
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Bifurcated inlet and outlet
I am looking at maybe doing a Convair Sea Dart should be a twin. I would think doing a single edf with bifurcated inlet and outlet would help to save weight.
My question here is I intend to use a 70mm unit and since the inlet ducts are rather small I would scale so that each is equal to half the size of the fan. With the outlet however I am slightly stumped. I know I need to work with the 5-10% FSA rule. The airframe the EDF came from had a 65mm outlet. This by the way came from one of the china F-16's. My question then is do I half the 65mm for the two outlets or maybe go a little larger? If I do that it would be some rather small outlets. Am I correct in my thinking about the inlets as well?
Any help and suggestions are greatly appreciated
CapMike is offline Find More Posts by CapMike
Old Feb 22, 2013, 07:40 PM
Chris Nicastro is offline
Find More Posts by Chris Nicastro
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
The inlet area has to be equal to or greater than the FSA of the fan. The area of the exhaust tube opening should be no less than 80% FSA for a single opening. On the bifurcated exhaust you can try dividing it in half but there will be a lot of losses so design the pipe smoothly to keep the flow efficiently moving through the pipe.
Start there and adjust the tail pipe diameter for effect.
Make sure you calculate FSA on that particular EDF unit well so you have a good starting point.
You may benefit from a higher blade count on one of those budget HK EDF units.
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Feb 22, 2013, 07:51 PM
CapMike is offline
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
The rotor on the unit is either a 10 or 12 blade already with an out runner motor. It has an 80a esc I believe it ran on a 5s battery
Old Feb 22, 2013, 08:58 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
False. Inlet area can be as low as 65% FSA if the shape is just right. 80% is a reasonable number to shoot for, especially with new fans having more than 4 or 5 blades.
For the exhaust, make sure you're looking at half the area, not diameter. As long as the total area is equal or less than 100% fsa, I think it will work ok.
Steve C is offline Find More Posts by Steve C
Old Feb 22, 2013, 09:06 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
a 2.250 exit dia would work ...if you split it do 1.250" on eaxh tail pipe,that will help make up for splitting it ,there will be some drag / turbulence .with a bi exhust
AIR SALLY is online now Find More Posts by AIR SALLY
Old Feb 22, 2013, 09:19 PM
CapMike is offline
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Steve if this is the case then it might be do-able in scale. The 2 inlets are rather small. I will have to run the area numbers again tomorrow to see if it is anywhere near the 65-80%. If scaled to meet the 100% inlet diameter the exhaust outlets would look way too small at the 1.25" suggested.
Should the inlets have a twist to them as well as the outlets? I think this could help to smooth the airflow coming into the rotor and may also help with the vortice of the outlet as the air takes on a swirl when forced by the rotor. I think this can also help to get past any high or low pressure areas in front of or behind the rotor.
Old Feb 23, 2013, 01:32 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
The stator straightens the air, so there is no twist after the fan.
have everything as smooth and straight at you can. Stu did a thread once for his F-5. Certainly worth looking into.
Odysis is offline Find More Posts by Odysis
Old Feb 23, 2013, 10:46 AM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
CapMike
I think you will learn a little by looking at my latest model the T -2 C buckeye in the scratch-build thread.
Fans are individuals. Some can handle long intakes, some not.
the exit for a WM 400 mk 2 can be as little as 48 mm diameter for a single duct.
that is 37mm dia for a bifurcated exit
clausxpf is offline Find More Posts by clausxpf
Old Feb 23, 2013, 07:15 PM
Joined Feb 2004
Im suggesting a larger intake simply because on the Sea Dart they are very small and located on top of the fuse.
The exhaust is more simple than an F-4 exhaust for example. On the Sea Dart the openings are tangent so the divergance of the two tubes is minimal unlike an F-4. When you make the exhaust tube you can make a minimal splitter between the pipes.
Old Feb 23, 2013, 09:19 PM
CapMike is offline
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Originally Posted by clausxpf View Post
CapMike
Looking at your plane it looks as though the intake inlets are almost as small as that on the Sea Dart.
Old Feb 23, 2013, 09:21 PM
CapMike is offline
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
I was thinking that as well, but if you look at the plane it aslo has cheater screens over the top. One concern is that it does not get spray up into the intakes
Old Feb 24, 2013, 10:33 AM
CapMike is offline
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Having Autocad is great. Using the calculator for area I have run some numbers to have a look at doing this scale. I still need to measure the rotor to get FSA but here is what I have come up with. If doing the Dart at say 1:20th scale the inlets combined would be 2.3994. The outlets if both are a 1.25 diam would give me a 2.4544 area. This does not take into account the inlet cheaters that could potentially give me an area of 5.3994. Off to look for my fan to measure the FSA for better information for those who have helped so far
Old Feb 24, 2013, 10:43 AM
Steve C is offline
Steve C's Avatar
Joined Feb 2001
Small intakes can work, but you may end up tinkering a lot if it's less than about 80%. I'm not trying to talk you in to using exact scale inlets, but I wanted to set the record straight about needing 100% or greater inlets. It simply is not true and some of the highest performance EDF's I've seen had smallish inlets.
I don't think we see much in the way of experimenting with bifurcated thrust tubes. These are always on scale airplanes and once it flies, that's tends to be good enough. I have not played with these, but It makes sense to do some things. Avoid sharp angle turns. Don't allow the total area to increase where it goes to two ducts. Where they split, the center should be rounded like the leading edge of a wing. BTW, the inlet is sharp there, like the trailing edge of a wing.
I have a small F-86 that was such a pain that I did in fact put a cheater hole in it. I know, I have never been a fan of the things, but the darn thing wouldn't climb and it was a long time ago. The cheater hole helped a bunch. It would fly, but it was slow and I wanted more. I kept at it (over a few years) and finally hit on a combo with the HK 7 blade 64mm rotor that far exceeded previous performance.
If you just want it to fly, go with either something larger or with cheater hole, but keep in mind that the cheater hole will never match the performance of a clean working inlet duct.
Old Feb 24, 2013, 10:56 AM
CapMike is offline
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Ok here is the spec on the EDF. It's an 8 blade unit motor kv unknown using a 40a Raiden ESC. The inlet diameter is 82.18mm or 3.2355 inch. The stator is 80mm or 3.1520 inch. This gives a FSA of 7.803. I think I need to scale the airframe up for larger intakes maybe.
Steve what do you think here? Would I have enough with the cheaters? Otherwise my outlets would really need to be pretty small, or I might need to go for a twin but the added weight might be a detriment to getting the plane to rise off the water
Old Feb 24, 2013, 11:20 AM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
I was going to stay out of this thread but decided to add a bit of (confusion? ) information.
Look at this post for a general idea of typical Fan Swept Area:
http://www.rcgroups.com/forums/showp...00&postcount=1
Typical 100% FSA for a 70mm fan would be approximately 29-30sq centimeters (4.5sq")
As well; a decent starting point for outlet diameter of a single exhaust 70mm fan is 55mm (or 2.16")
The AREA of this exhaust is 23.64^centimeters (3.66^")
Now for split/bifucated exhaust you can't just divide the single pipe DIAMETER in half.......you have to divide the AREA in half.
So: total area of 23.64^centimeters (3.66^") divided by 2 equals 11.82^ cm (1.52^")
Take that AREA and work the calculations backwards and you get a DIAMETER of 3.87centimeters (38.7mm) or 1.52" for each exhaust outlet.
And to reinforce what Steve C and Claus mentioned; you do not need 100% FSA with typical modern EDF power. Anywhere between 80% and 100% that suits you will be fine. Just make sure that you don't have a sharp inlet lip....
Mike Warren is offline Find More Posts by Mike Warren
Cooling inlets & outlets and airflow direction: need the fluid dynamics experts Protocooler Modeling Science 20 Aug 09, 2008 03:25 PM
Question DF Inlet & Outlets How Big ? RMD72377 Electric Ducted Fan Jet Talk 7 Apr 12, 2007 06:18 PM
Inlet/fan/outlet ratios P_J_Glor Electric Ducted Fan Jet Talk 1 Nov 27, 2002 03:36 PM
EDF inlets/outlets geeee Electric Ducted Fan Jet Talk 5 Jun 24, 2002 10:55 AM
Inlet / outlet ducts for EDF50 RookieOne Electric Ducted Fan Jet Talk 5 Jun 04, 2002 06:59 AM
