Joined Jun 2011
Hitec HS-7956SHR Rudder Tray Servo in stock!
BRAND NEW AND IN STOCK AT SERVOCITY!
HS-7956SHR Rudder Tray Servo CLICK HERE: http://www.servocity.com/html/hs-7956shr_servo.html Introductory Sale Price - Limited Time Offer! ![]() Features: - All-in-one Rudder Tray on Metal Top Case - Large size ball bearing for 3.5 inch Rudder horn - Metal turnbuckle pull-pull wire tensioner - 2 cell Li-Po compatibles (6 cell NiMH) - G2 Digital Amplifier w/ MOSFET drive - Durable steel gears with dual ball bearing - Ultra hardness gear shaft with 3 axial metal - Heat sink for motor - Water and dust resistant ![]() ![]() ![]() Control System: +Pulse Width Control 1500usec Neutral Required Pulse: 6.0-7.4 Volt Peak to Peak Square Wave Operating Voltage Range: 6.0-7.4 Volts Operating Temperature Range: -20° to +60° C (-4°F to +140°F) Operating Speed (6.0V): 0.15sec/60° at no load Operating Speed (7.4V): 0.12sec/60° at no load Stall Torque (6.0V): 277.74 oz/in. (20 kg.cm) Stall Torque (7.4V): 340.24 oz/in. (24.5 kg.cm) Operating Angle: 45 Deg. one side pulse traveling 400usec Direction: Clockwise/Pulse Traveling 1500 to 1900usec Dead Band Width: 2usec Motor Type: Coreless Bearing Type: Dual Ball Bearings Gear Type: Metal Gears Connector Wire Length: 11.8” (30mm) Dimensions: 1.57” x 0.79” x 1.45” (40 x 20 x 37mm) Weight: 2.40oz (68g) |
| Thread Tools | |
| New Product Hitec HS-83xxTH servos IN STOCK NOW! | ServoCity | ServoCity.com | 1 | Jan 27, 2013 12:36 PM |
| Wanted Wanted - Two Hitec HS-7956SHR Servos | clandestoy | Aircraft - General - Radio Equipment (FS/W) | 0 | Jan 23, 2013 07:26 AM |
| Sold New in box Hitec HS-82MG servo | sdstick | Aircraft - General - Radio Equipment (FS/W) | 2 | Jan 14, 2013 12:34 PM |
| Sold Hitec servos , HS-55 . HS-56 & HS-5245 | Dennis Everett | Aircraft - General - Radio Equipment (FS/W) | 2 | Jan 11, 2013 10:44 PM |
| Sold 2 Brand New In Box Hitec HS-5625MG Servos with Blue Servo Arms $75 Shipped | Mahu | Aircraft - General - Radio Equipment (FS/W) | 5 | Jan 09, 2013 07:59 PM |
