Old Feb 22, 2013, 11:31 AM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
Question about props
Hey guys, i have tried lookin around but have not found a decent answer. Question is apc thin electric vs sport profile. I fly thin e on all my stuff but my local guy only had supply in a 6x 4 sport. Any real flight characteristics that differ? Is pitch pitch no matter the profile, its on a small 1900 kv
elliott000 is offline Find More Posts by elliott000
Old Feb 22, 2013, 12:03 PM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
I'd bet you will not notice the difference. In theory a thinner blade has less aerodynamic drag and therefore needs less power to produce the same thrust as a thicker blade. You might like to check your amp draw just for the peace of mind. Thick prop is heavier and the increased inertial effects might be noticable during some exotic 3d manouvers - or not. Thin blades are mechanically weaker and would not survive the constant banging of an internal combustion engine, but with electric motor it will be just fine.
jkettu is offline Find More Posts by jkettu
Old Feb 22, 2013, 08:28 PM
Rhea is offline
Find More Posts by Rhea
Registered with FAA since 2016
Rhea's Avatar
United States, MN, Eden Prairie
Joined Oct 2008
I have wondered the same thing from time to time so this is my common practice now. Before I fly a new plane I will buy several different props both in size and pitch. Then I try the different ones and see how the plane flies with each one and check if the motor and/or battery are warm or cool after a flight. After a while you won’t have to buy an array of props because you will have a selection in your tool box already from the ones you culled out. You can also try different props for different conditions; windy or not, hot or cold etc.
It works for me.
Rhea is offline Find More Posts by Rhea
Old Feb 22, 2013, 08:37 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
I'd just stay away (far away) from Master Airscrew props with e-power. Nuff said.
rafe_b is offline Find More Posts by rafe_b
Old Feb 22, 2013, 08:58 PM
Rhea is offline
Rhea's Avatar
Joined Oct 2008
It doesn't seem like "Nuff" has been said. Can you elaborate?
Old Feb 22, 2013, 09:20 PM
Joined Feb 2012
Lol, i only use apc or graupner, just because my local hobby shop carries em.
Discussion Question about covering Carnifax Painting and Finishing Tips 6 Feb 14, 2013 09:16 AM
Discussion Question about the Brushless 2226/2300 KV Easysky motor question (dolphin/cessna) twincobra Micro Ready-to-Fly 0 Feb 11, 2013 12:49 AM
Question Noob question alert about telemetry !!!! ferincr DIY Electronics 17 Feb 03, 2013 11:32 AM
Discussion I know, I know stupid question about about World Tech Hercules Helo drtuvoc Coaxial Helicopters 1 Jan 26, 2013 08:40 PM
Discussion Question about AC Charger and Battery Replacement Spirittoo Coaxial Helicopters 3 Jan 09, 2013 03:56 PM
