Old Feb 22, 2013, 09:25 AM
Ivan2280 is offline
Find More Posts by Ivan2280
ITALY
Joined Sep 2004
Build Log
Nieuport 11 1/48 full fuse
This is my Nieuport 11 1/48 scale.The fuse is in depron thermoformed.Other parts are in eps foam,fiberglass and carbon.I have only to install my new tiny receiver plantraco compatible code and 10 mah lipo.The weight for now is 1.99 gram.The motor is 4mm coreless wirh 4.5:1 gear ratio and homemade prop with cnc and pvc material.It use only gas and rudder.In next version i install also elevator.
Ivan2280 is offline Find More Posts by Ivan2280
Old Feb 22, 2013, 09:37 AM
epicdoom is offline
Find More Posts by epicdoom
Micro Crazy Man
epicdoom's Avatar
Baltimore, Md.
Joined May 2004
Ivan nice build will you be posting plans for this is it durabatic foam?
epicdoom is offline Find More Posts by epicdoom
Old Feb 22, 2013, 09:40 AM
Ivan2280 is offline
ITALY
Joined Sep 2004
The fuse is in depron thermoformed in a former,so i have no plans,the other parts are in light eps sliced,for this i can make plans.
Old Feb 22, 2013, 10:03 AM
BRUTUS2238 is online now
Find More Posts by BRUTUS2238
Huge member!
BRUTUS2238's Avatar
Pawtucket R.I.
Joined May 2008
I would love to see a video of this in the air. Thats a nice build you have there. B
BRUTUS2238 is online now Find More Posts by BRUTUS2238
Old Feb 22, 2013, 11:32 AM
Ivan2280 is offline
ITALY
Joined Sep 2004
No problem for a video. :-)
Old Feb 22, 2013, 11:49 AM
epicdoom is offline
Micro Crazy Man
epicdoom's Avatar
Baltimore, Md.
Joined May 2004
For sure want to build this in 1/72 scale plans would be awesome Ivan Great looking little plane cant wait to see it in the air
Old Feb 22, 2013, 12:44 PM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Looks great Ivan! Love the Nieuports, I have several micro ones my smallest though is a 12"WS with Vapor e-gear. They all fly great.
Pete
mtflyr is offline Find More Posts by mtflyr
Old Feb 23, 2013, 08:47 AM
Ivan2280 is offline
ITALY
Joined Sep 2004
receiver ready
I have completed and tested the receiver.I have make it on flexible pcb.The weight is 0.32g enclose battery connector.It is 3ch but only 2ch used,gas and rudder,the output rudder pin are doubled so i can use low ohm and low weight actuator coil.
Old Feb 23, 2013, 09:24 AM
Ivan2280 is offline
ITALY
Joined Sep 2004
Receiver installed.
I have completed the little nieuport.The weight now is 2.32g.Now i design a lipo support so i can use 10-20 mah lipo and adjust the cg.
Old Feb 23, 2013, 10:24 AM
miatamama is offline
Find More Posts by miatamama
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
Ivan, I have built 10" WS se5's but had trouble with my fingers getting in the way of the build. How do You Guys assemble these small parts without breaking them before they are glued.
Great work.
JCS
miatamama is offline Find More Posts by miatamama
Old Feb 23, 2013, 08:02 PM
epicdoom is offline
Micro Crazy Man
epicdoom's Avatar
Baltimore, Md.
Joined May 2004
Great work.
JCS
My fingers are fairly thin and its sometimes a challange even for me you just have to be gentle use tweezers on very small stuff at 47 years old my hands shake now, so a good rest is also important to have. I like working in 1/72 scale 5-6" WS Most important plan assembly ahead so parts drop in place easier without having to fight other parts in the way.
The plane is looking good Ivan
Old Feb 23, 2013, 08:33 PM
Ivan2280 is offline
ITALY
Joined Sep 2004
I have make the first test and it is not stable.Need some change.
Old Feb 24, 2013, 01:37 PM
Ivan2280 is offline
ITALY
Joined Sep 2004
The problem is that eps foam is too flexible and the wing is unstable.So i redesign wings,elevator and rudder in depron so it not flex anymore.News in next days.
I have also to redesign the wheel,too fragile,need a support in fiberglass for axle.
Discussion BIG 48" Sbach 342 - Full Fuse, True Airfoil, 3D - Video Added!!! SNice Foamies (Scratchbuilt) 46 Jul 01, 2014 05:27 PM
Sold NIB Wattaplane Skywing 48 in Edge Full fuse - RED rc4u Aircraft - Electric - Airplanes (FS/W) 3 Feb 18, 2013 08:55 AM
Sold Proctor Nieuport 11 .. Ready to rig and cover .. SPF ec121connie Aircraft - Fuel - Airplanes (FS/W) 7 Jan 13, 2013 01:20 AM
Discussion Hacker Full Fuse EPP 48" Maverickk 3D Foamies 4 Jul 05, 2011 07:24 PM
Discussion nieuport 16 1/48 Ivan2280 Scratchbuilt Indoor and Micro Models 7 Nov 07, 2010 08:55 AM
