Old Feb 22, 2013, 09:22 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
Question
Esc
Hi guys,i wonder if,like quad's or tri copters that use reflashed esc's,is need it to use reflashed esc with our vtol projects!?
Lead,Rcvertt,F@T and others,what esc's you use it for vtol?!
regards
nadine is offline Find More Posts by nadine
Old Feb 22, 2013, 02:08 PM
Ran D. St. Clair is online now
Find More Posts by Ran D. St. Clair
Ran D. St. Clair's Avatar
United States, CA, Sunnyvale
Joined Dec 2006
What makes you think that quad or tri-copters use "reflashed" ESC's? As far as I have seen, they are standard ESC's the same as for airplanes. The only difference is that you don't want to use any sort of automatic endpoint calibration. One way or another, depending on the brand and make of the ESC, you need to set it in fixed endpoint mode. That doesn't require any sort of reflashing though. With the Castle Phoenix series it is a button click in the computer based setup application, or you can do it via TX stick programming as well. I belive the Turnigy and other similar ESC's effectively do the same thing with TX stick programming.
Ran D. St. Clair is online now Find More Posts by Ran D. St. Clair
Old Feb 22, 2013, 06:23 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
No need to reflash the ESC. I use regular HobbyKing super simple 10 amp or better yet Mystery 12 amp.
Our VTOLs have more surface area so they respond slower. I don't think reflashed ESCs will help. The faster speed will probably only put more stress on the prop and motor.
RCvertt is offline Find More Posts by RCvertt
Old Feb 23, 2013, 12:13 AM
nadine is offline
vtol fan
nadine's Avatar
Joined Jul 2009
Ok guys,
no flashing esc..
Cheers
Old Feb 23, 2013, 10:55 AM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
Yup, didint flash, I only use the mystery 12a ESC's.
foam and tape is offline Find More Posts by foam and tape
Old Feb 23, 2013, 11:06 AM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
If you are controlling any axis by differential motor control, you might want an ESC with a faster response.
ilektron is offline Find More Posts by ilektron
Old Feb 24, 2013, 07:20 AM
nadine is offline
vtol fan
nadine's Avatar
Joined Jul 2009
Yes,this it was the point,first of all.
But hey,if you guys,use it ,esc with stock firmware,then is ok....
Just a thot
Old Feb 24, 2013, 09:32 AM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
You know, hobbyking sells multirotor ESCs for dirt cheap. I bought some but have yet to use them and form an opinion.
Old Feb 24, 2013, 10:32 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
The mystery ESC has the option of operating at 8 or 16 hrz. I use 16 as some have told me that it works better for multirotors. I mainly use them because I think they are built better than the SS 10amp and have a 2 amp BEC if you need to use it. SS BEC is only one amp I think.
Alert Fake Hobbywing Skywalker 20A ESCs from TomTop - "SCUMWALKER ESCs" Soma Multirotor Electronics 78 Feb 16, 2016 12:39 AM
Wanted need x6 ESC's or a few Mystery 30A ESC's zestyzsauce Aircraft - Electric - Multirotor (FS/W) 1 Jan 23, 2013 12:26 PM
Sold HobbyWing Flyfun ESC 80A High Voltage ESC jgalexander Aircraft - Electric - Power Systems (FS/W) 1 Jan 19, 2013 12:19 PM
2 NIB Turnigy Plush 30 amp + 30 amp turnigy ESC for 60-80amp ESC Koo Non R/C Items (FS/W) 1 Jan 15, 2013 11:31 PM
Sold Trade 2 NIB Turnigy Plush 30 amp + 30 amp turnigy ESC for 60-80amp ESC Koo Aircraft - Electric - Power Systems (FS/W) 1 Jan 15, 2013 10:55 PM
