Old Feb 22, 2013, 07:00 AM
ShellFish31 is offline
Find More Posts by ShellFish31
Joined May 2012
Airfoil and Formfactor selection for small indoor Nurflügler
Heho,
first off, i'm not sure if i'm in the right section of rcgroups, as i don't quite understand the difference between a flying wing and a nurflügeler (beeing german i know this is the simple translation for "flying wing"). Please move topic and enlighten me ;-).
Anyways, i've recently cut my first flying wing with a hot wire from "el cheapo" EPS foam, and it worked so well that i now want to make an old dream come into life: a super small flying wing, fit to cruise our livingroom ;-). I still have to get a little better at hotwire cutting and fine-adjust cuttingspeed, and temperature so thinner parts work out well, but well ... i need to work on two problems at once: designing the wing, and providing technique for actually manufacturing it
As this project would be a bit off the tracks i guess i can't just use standard airfoils and building plans. So what i wanted to do is dive a little into flying wing design, get to know the basics, and then try my luck . So far i've read many articles from http://www.aerodesign.de/ and on the original Horten-Gliders. Other good literature tips are still welcome .
Anyways, from what i have understood i should probably prefer more lift and less drag over self-stabilization for this project. A small crash or twitch in the livingroom ain't as bad as with 3m gliders out on the field. Also, you probably have to ride the sticks all the time anyways, so getting more lift and less drag combined with a smooth stall characteristics would be benificial as the selection if lightweight components would become a little less critical, right? So from what i have understood that means not-quite-as-much reflex, much much camber, and the camber moved far to the front, right? The stall characteristics would then be (over-simplified!) a tradeoff between drag and nice stall, by upsweeping the end of the airfoil a bit. Once again, i'm sorry to oversimply that badly here. I'm studying computer science, not aeronautical engineering, so i can only try my best to understand those vastly complex set of physical equations (that i'm not used to).
That is also why i seek your help. I'd really like to try and make my start into designing micro wings, but i'm a little lost at my current point of learning: Most resources are too simple, aerodesign was just right, and actual scientific papers or airfoil design tools such as xflr5 are too advanced for me. So i can either go the "trial and error" route now, or hopefully get some input from you what else to do, where to go, what to try, what to read, ... -- or just ideas on how to get started with actual designing...
Well, so far. Thanks in advance
- ShellFish
ShellFish31 is offline Find More Posts by ShellFish31
Old Feb 22, 2013, 07:12 AM
HerkS is online now
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
I suggest that you take a look at this ---
http://www.instructables.com/id/Foam-Walkalong-Glider/
HerkS is online now Find More Posts by HerkS
Old Feb 22, 2013, 08:18 AM
nmasters is online now
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
A German computer science major... There's a program called "Nurflügel" that you may find easier to use than XFLR5. There are also several spreadsheets that do the balancing of pitching moments needed for tailless flight. There are several links in this article. The walk along gliders are a good place to start for indoor flight but I suspect that you want RC. You may find some useful information about elevon shape and size in this thread.
walkalong glider pylon racing (0 min 56 sec)
--Norm
nmasters is online now Find More Posts by nmasters
Old Feb 22, 2013, 09:16 AM
Wolfking44 is offline
Find More Posts by Wolfking44
wolfking
Wolfking44's Avatar
Canada, AB, Spruce Grove
Joined Feb 2012
This site has great info on walk along gliding http://www.sciencetoymaker.org/airsurf/index.htm
Wolfking44 is offline Find More Posts by Wolfking44
Old Feb 23, 2013, 07:29 AM
Joined May 2012
Hey,
thanks for the tips. I've already built a few walkalong gliders just for toying around, but what i want to build here would be a electrified small livingroom nurflügler. I have measured around a bit yesterday and found that i probably could use a old servos motor together with its controlboard as a main motor for such a small plane. I've replaced the potentiometer from the servo with a smd resistor, so this becomes a ultimately light(?probably not ultimately?) brushed esc + motor. While i don't have a proper propeller for this here i've tested with 5040 nylon props (oh wow, way to large/heavy ;P) and my genius cp tail props. The 5040 gave what felt like okay~ish thrust and reasonable RPM without warming the motor tooo much. At least i would've guessed (without measuring yet) that it should be plenty for such a small project.
Sadly on the airfoil front there isn't much news. I've read alot, i've understood little, and am still reading and trying to grasp the basics of aeronautical engeneering topics .
Old Feb 24, 2013, 12:10 PM
KenSt is offline
Find More Posts by KenSt
Scratch builder
USA, PA, Telford
Joined Apr 2004
Take a look at this thread and click the link at post #6. Perhaps you can scale this to what you want. A living room flyer is quite the challenge! I would guess that full thickness airfoil construction may be too eleborate and heavy. You may just need a bent sheet of foam with some trial and error.
Maybe the indoor sub forum here would have some insight as to power systems and nano radio set ups.
http://www.rcgroups.com/forums/showthread.php?t=1819579
KenSt is offline Find More Posts by KenSt
Old Feb 28, 2013, 08:42 PM
derk is online now
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
Depending on the size of your living room, your going to need lighter radio gear than converted servo boards. Deltang makes some very good Dsm2 receivers that use actuators which will give you the lowest weight. Small motors and small batteries are another must, typically 30mah or less is a good match to 4mm pager motors. If you need some inexpensive micro parts, bidproduct.com has a good selection from motors, props, actuators and other stuff you'll need.
Just keep in mind LIGHT WEIGHT and low wing loading.
My latest room flier has a 16 inch span, 5 inch chord and weighs about 5 grams rtf
derk is online now Find More Posts by derk
Old Feb 28, 2013, 11:09 PM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
If you're building strictly indoor then nothing beats the low weight of IR receivers. I used to scrounge some of the Silverlit/Airhogs ones but I can't find them anymore locally. Derk has a post about some fairly inexpensive IR systems from Korea: http://www.rcgroups.com/forums/showthread.php?t=1800107
As for airfoil and planform, I've seen everything from fly if it's light enough and has enough thrust. At micro sizes I rarely see people bothering with things like proper twist and accurate airfoil - just trim in a bit of reflex and it should fly.
Here's a nice video of a micro indoor "fake" Horten:
All wing take off 2 (3 min 1 sec)
I say "fake" because unlike what people in this forum consider "real" Hortens this had flat plate airfoil. Look carefully and you'll notice that he bent the center "tail" upwards for a bit of built in reflex. So it's possibly a reverse Horten with wash-in instead of wash-out.
slebetman is offline Find More Posts by slebetman
Discussion My Indoor Small Space Fly Anywhere 2-Plane Kit Robster Scratchbuilt Indoor and Micro Models 6 Jan 15, 2013 02:57 AM
Fully symetrical airfoil selections for a 300MPH 90" Turbine??? Admiral_Red Modeling Science 16 Jan 08, 2004 08:08 AM
Airfoil Selection for 1/4 Scale Sailplane Phat2Wheel Thermal 10 Nov 27, 2003 08:17 AM
Designing a 50" Pitts S-1S - Reading airfoil polars and airfoil selection Meneer Modeling Science 3 Feb 06, 2003 09:50 PM
airfoil selection for fast sloper? opualuan Electric Sailplanes 10 Apr 25, 2002 08:29 PM
