Old Mar 10, 2013, 04:27 PM
Jeff2010 is offline
Find More Posts by Jeff2010
Joined Jan 2013
Applied Filler
Applied !filler
Jeff2010 is offline Find More Posts by Jeff2010
Old Mar 10, 2013, 08:45 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
Lookin good !
And so, what type filler did you end up using ?
Tim B. is offline Find More Posts by Tim B.
Old Mar 10, 2013, 10:54 PM
Jeff2010 is offline
Joined Jan 2013
I used Hobbico HobbyLite. I could not find Famowood. I'll let you know it turns out
Old Mar 11, 2013, 06:16 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
Famowood can be had here:
http://www.amazon.com/Famowood-Water...words=famowood
Old Mar 16, 2013, 03:57 PM
Jeff2010 is offline
Joined Jan 2013
Sealing the hull - Aero Gloss after each application of filler?
Hi All,
Just wanted to ask. I have sanded the hull after the first application of filler. Should I apply more filler next or should I apply Aero Gloss, then my next application of filler?
Old Mar 29, 2013, 01:57 PM
Jeff2010 is offline
Joined Jan 2013
Sanded hull
The Hobbico filler I first used did not work well at all. It sanded off in clumps. So after removing most of the Hobbico filler I got some Famowood filler and it worked awesome.
Old Mar 29, 2013, 02:11 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
That looks Great !
Good to hear you are happy with the Famowood, its been a real time saver for me.
With a well shaped application tool, its a one shot deal.
Old Mar 29, 2013, 02:21 PM
Geoffqf is offline
Find More Posts by Geoffqf
777Geoff, Vancouver, Canada.
Geoffqf's Avatar
Canada, BC, Surrey
Joined Jan 2013
That's great news, I picked up a couple of tubs also. Looks excellent!
Geoff
Geoffqf is offline Find More Posts by Geoffqf
Old Apr 03, 2013, 02:09 PM
Jeff2010 is offline
Joined Jan 2013
Hull ready for Primer
I have applied about six coats of 50/50 Aero Gloss / Thinner sanding between coats. My next step is to apply primer. I plan to wet sand between coats of primer. Any comments would be appreciated
Old Apr 03, 2013, 02:14 PM
Jeff2010 is offline
Joined Jan 2013
Hull ready for primer
Old Apr 03, 2013, 02:25 PM
Jeff2010 is offline
Joined Jan 2013
Also should mention this is a shelf model. I don't have a motor so no plans to get it wet.
Old Apr 03, 2013, 02:26 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
I will make a fine ( LARGE ) shelf model.
Old Apr 03, 2013, 07:42 PM
ruzam is offline
Find More Posts by ruzam
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
Made home to my parents for Easter weekend. Here are some pictures of my Dad's boat. Took quite bit of dusting off (thirty year's worth?). Near as we could figure it was completed sometime between '68 and '70. Dad couldn't explain the reason for the jet drive conversion. It was just something he picked up when he got the boat. It was probably something too cool to pass up. This boat was built with dad's first proportional radio gear. Everything previous to this was push button, so it was a major advancement in the day. The radio alone cost $500 at the time (about $2700 in today's dollar).
The diesel was started with a belt looped on the flywheel pulley. I remember it was hard to start. A feed off the jet drive fed a water cooling jacket and out a hose off the back of the boat near the water line. The exhaust was connected to a slightly larger pipe, also out the stern near the water line. You'd think that twin diesel jet drive would go like stink, but Dad said it barely moved the boat. Judging from the water line, I suspect the jet drive never did fill completely and mostly just frothed up air and water. The diesel is completely seized now, there's no way it'll turn without a complete tear down and rebuild.
The outer hull was fibre glassed (something not called for in the instructions).
You can see the search light mounting arm, and the glue repair (oops). I see that's not the only part of the boat that's been broken and glued, so I guess I can't take all the blame anymore.
After a good cleaning it went back on the shelf, where it will probably spend another thirty years accumulating dust. Enjoy.
ruzam is offline Find More Posts by ruzam
Old Apr 03, 2013, 09:52 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
wow !
Old Apr 03, 2013, 10:01 PM
RussellTate is offline
Find More Posts by RussellTate
RussellTate's Avatar
Sydney Australia
Joined May 2009
..would love to see a video of that one in action!
RussellTate is offline Find More Posts by RussellTate
Sold For sale: Plans for dumas 28" chris craft semi enclosed cruiser Tim B. Boats (FS/W) 2 Apr 05, 2013 11:11 PM
Discussion Painting a Sterling Balsa Wood model Chris Craft boat Jeff2010 Scale Boats 11 Feb 10, 2013 09:01 PM
Sold Sterling chris craft 50 catalina flying bridge cruiser $355.00 w/shipping in USA ! Tim B. Boats (FS/W) 1 Dec 25, 2012 11:13 AM
Discussion Sterling Chris craft 50' Catalina B-7M PLANS? riggerman Scale Boats 14 Feb 28, 2012 08:02 AM
Discussion 63' Chris-Craft Cruiser by Sterling USA 236 Scale Boats 66 Jul 06, 2009 09:04 AM
