Old Mar 04, 2013, 11:43 PM
Jeff2010 is offline
Find More Posts by Jeff2010
Joined Jan 2013
Bow nose
Got the tip of the bow whittled down pretty close
Jeff2010 is offline Find More Posts by Jeff2010
Old Mar 05, 2013, 12:30 AM
SenorNeekers is offline
Find More Posts by SenorNeekers
Steamy laser dude.
SenorNeekers's Avatar
Canada, BC, Victoria
Joined Oct 2011
Looking good so far!
I've also noticed that some balsa is harder than others, even when selecting sheets at the hobby store. I tend to select the soft ones due to the greater ease of working.
Not sure what the cause it. My suspicion is just subtle difference in the trees.
SenorNeekers is offline Find More Posts by SenorNeekers
Old Mar 05, 2013, 08:43 AM
oldbilgewater is offline
Find More Posts by oldbilgewater
United States, PA, Quakertown
Joined Jan 2012
Originally Posted by Jeff2010 View Post
Hi oldbidgewater
What kind of balsa filler do you recommend ?
Looks like what you are using is just fine. What I have been using is shown in pics. Minwax (for large craters) Bondo ( for fine work) {not the two part Bondo} Aero Gloss (thinned 50% ,several aplications) to strengthen "soft balsa" Epoxy (thinned 50% w/alcohol ,as a final step on inside)
I know,that was more than you asked for.
OBW
oldbilgewater is offline Find More Posts by oldbilgewater
Old Mar 05, 2013, 08:46 AM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
That Minwax filler looks interesting, havent seen that at the local Ace ..
I will see if they can get some.
I have had good luck with Famowood ~
Tim B. is offline Find More Posts by Tim B.
Old Mar 05, 2013, 09:07 AM
Joined Jan 2012
Tim,is it stainable? I can't seem to be able to read that .
Of course if painting it makes no dif.
OBW
Old Mar 05, 2013, 09:35 AM
charlie eaton is offline
Find More Posts by charlie eaton
charlie eaton's Avatar
N.E.Mass.
Joined Apr 2007
Sig dope is a far better product to use on boats then Aero Gloss. It fills grain much better. Clear works well over stained wood like the mahogany. Balsa filler will turn milky when dry, don't use on stained wood.Filler is ok anywhere else. Put on several coats then sand, put on several more coats and sand lightly between coats.Dope will shrink as it dries and will show the grain hence the need for a filler first.Some use a tissue doped to the hull (preferably silkspan used for model aircraft) and put on wet. Aero Gloss is no good for this type of work.
charlie eaton is offline Find More Posts by charlie eaton
Old Mar 05, 2013, 12:27 PM
Jeff2010 is offline
Joined Jan 2013
Hi Charlie. Where do you get Sig Dope? Is Sig the brand name?
Old Mar 05, 2013, 12:28 PM
Jeff2010 is offline
Joined Jan 2013
Hi oldbildgewater
What do you thin the Aero Gloss with if I decide to go that route?
Old Mar 05, 2013, 01:50 PM
N.E.Mass.
Joined Apr 2007
Sig is the brand name, they also make aircraft kits and have other hardware mostly for aircraft. Around here the R/C Buyers warehouse in Nashua NH carries it but I have no idea where you'd get it. It is thicker than Aero Gloss and has better pigmentation. I've used it for years and Testers dope before that.( Testers hasn't made it in years though) You can thin dope with acetone. use woodfiller for the seams and balsa filler to seal the grain of the wood.
Old Mar 05, 2013, 05:51 PM
Joined Jan 2012
Hi oldbildgewater
Aero Gloss 43-4 Thinner It soaks in well ,give it time to dry,it shrinks and now your (weak balsa ) is "locked" there for your fill/ finish .
Immagine a dry kitchen sponge.... You want a nice finish .....Fill the top surface ..Sand....Paint ....Lovely!!!!! Now,wet the sponge.
Moisture gets every where. So,several aplications of 50/50 will give your sponge(pithy balsa) the internal strength that it lacks.
OBW
PS There are perhaps more than a dozen products that will work .Make sure all products from start (glue/cement/CA) to finish (Color/clear coat) are compattable. After that you argue Ford/GM/Chrysler etc etc.
Old Mar 05, 2013, 06:21 PM
Jeff2010 is offline
Joined Jan 2013
So the Aero Gloss goes on before the balsa filler? Do I use more Aero Gloss after the balsa filler as well?
Old Mar 05, 2013, 06:32 PM
Jeff2010 is offline
Joined Jan 2013
My motivation behind the build
On a side note. My motivation behind this build is that my Dad built this same model when I was two years old. Back in 1961. He would take me down to a dam in Willoughby Ohio and cruise the boat. The boat went over the dam on one occasion and my Dad claimed it was someone on a CB Radio who interfered with the RC signal. Luckily It wasn't too badly damaged. In the early Ninties my Mom sold it in a Garage Sale.
Old Mar 05, 2013, 06:38 PM
Jeff2010 is offline
Joined Jan 2013
My Dad's boat. 1961
Old Mar 05, 2013, 06:39 PM
Jeff2010 is offline
Joined Jan 2013
My motivation behind the build.
I hope I can do as good of a job as my Dad on my build
Old Mar 05, 2013, 06:43 PM
Jeff2010 is offline
Joined Jan 2013
My motivation behind my build
My Dad's boat at Daniels Park, Willoughby, Ohio. 1961
Sold For sale: Plans for dumas 28" chris craft semi enclosed cruiser Tim B. Boats (FS/W) 2 Apr 06, 2013 12:11 AM
Discussion Painting a Sterling Balsa Wood model Chris Craft boat Jeff2010 Scale Boats 11 Feb 10, 2013 10:01 PM
Sold Sterling chris craft 50 catalina flying bridge cruiser $355.00 w/shipping in USA ! Tim B. Boats (FS/W) 1 Dec 25, 2012 12:13 PM
Discussion Sterling Chris craft 50' Catalina B-7M PLANS? riggerman Scale Boats 14 Feb 28, 2012 09:02 AM
Discussion 63' Chris-Craft Cruiser by Sterling USA 236 Scale Boats 66 Jul 06, 2009 10:04 AM
