Old Feb 24, 2013, 03:28 PM
Jeff2010 is offline
Find More Posts by Jeff2010
Joined Jan 2013
Bottom Hull Skins
So I have to say that these bottom skins gave me fits. I have realized that some of the balsa that came in my kit is softer and other pieces are harder. The softer balsa pieces are very easy to work with. One half of the bottom skin was harder wood and difficult to chamfer. And then when I tried to cement the bottom skin to where it lines up with the side skin, the curve was off. The directions said to wet it so it would conform to the bulkheads. I thought this would then line up where the chamfered edge of the bottom skin would meet the bottom of the side skin. Well they did not line up.
Jeff2010 is offline Find More Posts by Jeff2010
Old Feb 24, 2013, 03:31 PM
Jeff2010 is offline
Joined Jan 2013
Front bow planking
Bow planking went well. I'm done as I'm out of glue. Rest of the Davy watching the Daytona 500 and peeling CA off my fingers
Old Feb 25, 2013, 08:03 AM
frankg is online now
Find More Posts by frankg
Joined Dec 2004
Welcome to the club of true modelers, biting, chewing, and pealing CA glue from the fingers they havenít glued together yet.
frankg is online now Find More Posts by frankg
Old Feb 25, 2013, 08:28 AM
Gravman is online now
Find More Posts by Gravman
United States, TX, La Porte
Joined Apr 2007
True that, you can strike a kitchen match on the fingers after a build session.
Gravman is online now Find More Posts by Gravman
Old Feb 28, 2013, 11:36 AM
Guard-Officer is offline
Find More Posts by Guard-Officer
Guard-Officer's Avatar
Canada, ON, Quinte West
Joined Feb 2009
Try using a touch screen after an afternoon in the shop with CA, its mildly amusing until it becomes infuriating!
Great start and welcome aboard!
Cheers
G-O
Guard-Officer is offline Find More Posts by Guard-Officer
Old Mar 02, 2013, 09:23 PM
Jeff2010 is offline
Joined Jan 2013
Bow Planking
I worked on the Bow Planking today. Went ok, had to use a lot of CA glue and had to hold the bowed planks for a long time before the CA glue dried. curious how the CA glue sands. Is there any way to make the CA glue dry faster?
TIP: I bought a small very fine tooth saw at the hobby shop. It was very helpful cutting off the overhanging planking.
Old Mar 02, 2013, 09:29 PM
Jeff2010 is offline
Joined Jan 2013
Bow planking
Description:
Old Mar 02, 2013, 09:31 PM
Jeff2010 is offline
Joined Jan 2013
Bow planking
Bow Planking
Old Mar 03, 2013, 08:20 PM
Jeff2010 is offline
Joined Jan 2013
Bottom
Time to learn how to whittle I guess.
Old Mar 03, 2013, 08:23 PM
Jeff2010 is offline
Joined Jan 2013
Bottom Planking
Bottom planking sure is ugly. Hoping it's something a little (or a lot) of sanding can't fix.
Old Mar 03, 2013, 09:58 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
You and me are in the same boat Matey ... ~
Tim B. is offline Find More Posts by Tim B.
Old Mar 03, 2013, 10:11 PM
Geoffqf is offline
Find More Posts by Geoffqf
777Geoff, Vancouver, Canada.
Geoffqf's Avatar
Canada, BC, Surrey
Joined Jan 2013
I am watching this intently as this is my next build once the 63' is refurbished. One at a time!
It looks great, but I understand the feeling one gets when something doesn't seem right. Believe me, I hope my skill level is the same as yours, because then, I know the project will look perfect.
Cheers, Geoff
Practicin' my whittln'!
Geoffqf is offline Find More Posts by Geoffqf
Old Mar 04, 2013, 05:54 AM
oldbilgewater is offline
Find More Posts by oldbilgewater
United States, PA, Quakertown
Joined Jan 2012
Welcome
Your planking is just fine . Sanding and filler will make it perfect if you take your time.
I would make one small suggestion; using scrap balsa ,put a filler between your lower horizontal transom former & the bottom sheeting .
The construction is the same as my Sterling 63 (post # 172 )
OBW
oldbilgewater is offline Find More Posts by oldbilgewater
Old Mar 04, 2013, 11:56 AM
Jeff2010 is offline
Joined Jan 2013
Soft balsa vs not so soft balsa
Here is one thing I noticed. My planking that came with the kit was not very soft. I'm not sure if its because it sat in the box all these years or its just some balsa is softer than others. Or is the planking suppose to be harder and less pliable because the hull needs strength. I actually ran out of planking and fabricated strips on my own and happened to use very soft balsa. It was a world do difference using the softer balsa. It was much much better I wished I would have just fabricated all new planking strips out of softer balsa. Any comments would be appreciated.
Old Mar 04, 2013, 11:59 AM
Jeff2010 is offline
Joined Jan 2013
Balsa filler
Hi oldbidgewater
What kind of balsa filler do you recommend ?
Sold For sale: Plans for dumas 28" chris craft semi enclosed cruiser Tim B. Boats (FS/W) 2 Apr 05, 2013 11:11 PM
Discussion Painting a Sterling Balsa Wood model Chris Craft boat Jeff2010 Scale Boats 11 Feb 10, 2013 09:01 PM
Sold Sterling chris craft 50í catalina flying bridge cruiser $355.00 w/shipping in USA ! Tim B. Boats (FS/W) 1 Dec 25, 2012 11:13 AM
Discussion Sterling Chris craft 50' Catalina B-7M PLANS? riggerman Scale Boats 14 Feb 28, 2012 08:02 AM
Discussion 63' Chris-Craft Cruiser by Sterling USA 236 Scale Boats 66 Jul 06, 2009 09:04 AM
