This thread is privately moderated by Gregor99, who may elect to delete unwanted replies.
Old Feb 22, 2013, 01:46 AM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
FAQ
FAQ - Powerlab Quick Start Guide - Wiring modes, Supply Limits and 1s charging
I put this short list together to answer some of the common questions new owners have.
Quick Start Guide
There a quick start guide called the "Quick Reference" to get you up and running quickly. This is in the manual page 7.
Increase the supply limit
The default supply limit for the Powerlab6 and Powerlab8 is set to 25 amps so you don't overload and burn up an under powered, power supply. Because the Powerlab will pull the full 40 amps(Powerlab6) or 60 amps (Powerlab8), there is a real potential to damage a power supply that is not capable and does not have built in protection. You can quickly change the default setting if you have the USB connection and the Powerlab software. You can also change it from the console. See the Smart Power Management section starting page 9. The default setting for the Dual Powerlab is 40 amps. It only needs to changed if the power supply cannot deliver 40 amps per channel, 80 amps total.
"Supply Low Voltage" should be set to 50% of the loaded supply voltage
The "Supply Low Voltage" limit is used protect the charger and supply when the supply is no longer able to regulate output voltage. The low supply voltage setting should be set to 50% of the loaded supply voltage. The loaded supply voltage may be lower than the value displayed on the charger's console. Using the CCS, the loaded supply voltage is displayed in the Supply Voltage vs Time graph. Here are some example settings for common supply voltages, rounded down to the next whole number.
Supply___Low Supply Voltage Setting
24v_____________12v
36v_____________18v
48v_____________24v
For a 12v supply use the minimum setting of 10v.
NOTE: DO NOT set the Low Supply Voltage value to the actual supply voltage. If the Low Supply Voltage setting is set to high, the charger will start limiting current inappropriately. Using a manually set charge current, if the charger does not sustain the set current this setting may be set to high.
Change Wiring Mode
The Powerlab arrives in the FMA wiring mode. This mode is compatible with all the FMA balance adapters for the Powerlab6 and Powerlab8. However, to use the Revolectrix MPA (Multi-port Adapter) or the SPA (Single Port Safe Parallel Adapter), or any other parallel board, the wiring mode will needs to changed to JST-XH/EH. Like the supply limit, using the Powerlab software is the easiest method to change this setting. But it can also be changed in on the console of the unit. Step by step instructions on page 60 in the manual. See image below for changing in the CCS.
Preset #3 for High Power Charging
Presets #1 and #2 are specifically tuned for charging under 10 amps. For charging over 10 amps use Preset #3 which will max the charger's output, given a sufficient power supply.
Preset #3 defaults to a termination of C/10 (same as generic faster charge present #2). This is setting is typically sufficient for most scenarios and is the default on many other chargers. If you want a more accurate charge, use Library Preset #3 Generic High P. Accurate. See "Copy a Library Preset" page 35.
Charging 1s Cells
Wiring requirements and current options for charging 1s cells varies by model and wiring mode. Details below.
  • Powerlab8 in FMA wiring mode - Up to 40 amps without a balance connector attached using a high power preset. Storage preset can be used to discharge or charge 1s.
  • Powerlab8 in JST-XH wiring mode and Powerlab6 (either wiring mode) - 1s cells can be charged using the new 1s presets in firmware 3.32 (PL8) and 1.11 (PL6). The new firmware includes two new 1s high power presets. One for up to 40 amps and one for storage up to 40 amps (charge). Once the new firmware is loaded, select file to preset. The new presets are found in the LiPo folder.
Powerlab manuals http://revolectrix.com/downloads.htm
Non FMA Parallel Boards
As described in the wiring mode section, all parallel board require the JST-XH wiring mode. This includes boards the MPA as well boards from other vendors. To connect the parallel board to the Powerlab, the parallel board vendor will need to provide a cable goes between the Powerlab and the board. The original FMA balance adapters cannot be used between the 3rd party parallel board and the charger. This is because the original FMA boards required the FMA wiring mode which is not compatible with the parallel board's wiring.
The cable that runs between the charger and the parallel board is referred to as the interconnect cable. There are currently two different wiring pinouts being used between different parallel board vendors. It is important that you get the correct interconnect cable that matches the parallel board you purchased. FMA does provide a plug and play parallel board solution in the form of the MPA.
Examples of interconnect cables.
http://epbuddy.com/index.php?main_pa...roducts_id=243
http://www.progressiverc.com/fma-pl8...rge-board.html
9/24/2013 Edit: Added Powerlab6 Storage preset for small 1s cells. Remove the .txt from the file name before importing into the CCS using "Open file to preset #"
Load LiHv Presets (if needed)
The HV presets are available from the preset library on the file system. To use them you have to import them using the CCS.
Select an open preset then,
File/FMA Default Presets/Open File to Preset.
Select LiHV folder and then select Blend435 or Blend427
Gregor99 is offline Find More Posts by Gregor99
Old Sep 11, 2013, 10:33 AM
Gariversy is offline
Find More Posts by Gariversy
Joined Oct 2011
Quick Start Guide
The default supply limit is set to 25 amps so you don't overload and burn up an under powered, power supply. Because the Powerlab will pull the full 40 amps(Powerlab6) or 60 amps (Powerlab8), there is a real potential to damage a power supply that is not capable and does not have built in protection. You can quickly change the default setting if you have the USB connection and the Powerlab software. You can also change it from the console. See the Smart Power Management section starting page 9.
The "Supply Low Voltage" limit used to throttle back the charge rate if the supply voltage drops below the set value. Many supplies already have this protection built-in. If this value is set to high, the charger will start limiting current inappropriately. For most supplies, changing the default is not necessary and may result in lower charge rates.
Change Wiring Mode
Charging 1s Cells
  • Powerlab8 in JST-XH wiring mode and Powerlab6 (either wiring mode) - 1s cells can be charged up to 2 amps using the small unbalanced preset. To exceed 2 amps of charge rate, a balance cable must be added in parallel with the charge cable. With a balance cable, up to 40 amps with a high power preset. Also the storage preset cannot be used unless a 1s balance cable is also used.
Wiring of the balance cable to the main leads is different for each wiring mode. Details are as follows:
  • JST-XH Wiring mode - Pin 1 (black) goes to pack negative. Pin 2 (white) goes to pack positive.
  • FMA wiring mode - Pin1 (black) goes to pack negative. Pin 9 (red) goes to pack positive.
See the attached image the wiring diagram from the manual.
Balance cable http://www.usastore.revolectrix.com/...-10-9-Position
Hi, I can do this or do I need to change something, the parallel card is another brand (HobbyKing)
Description:
Gariversy is offline Find More Posts by Gariversy
Old Sep 12, 2013, 12:47 AM
Gregor99 is offline
Seattle
Joined Sep 2007
Attachment 6095233
The MPA is a better option. The board in your post does not have fuses and does not connect directly to the charger. Parallel boards require JST-XH wiring mode. The FMA board requires FMA wiring mode. Though the configuration may work, there may be IR issues being reported incorrectly.
Old Oct 14, 2013, 11:36 PM
McKrackin is offline
Find More Posts by McKrackin
Incurable heli addict
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
Attachment 6095233
That is almost exactly what I have now.
It's working good but I have already ordered the PRC adapter cable in the OP.
McKrackin is offline Find More Posts by McKrackin
Old Oct 14, 2013, 11:59 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Just be sure to switch to JST-XH wiring mode when you get the cable from PRC. Also see the note above about some interconnect cables being wired backwards. If you get a bad cell count error with the PRC cable, check the wiring of the interconnect. It may need to be reversed.
Old Oct 15, 2013, 12:10 AM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
Will do...Thanks
Old Oct 25, 2013, 02:32 AM
unhinged is offline
Find More Posts by unhinged
Auckland
Joined Mar 2010
Help please.
I hase been using a powerlab 6 for about 18 mnths with no problems using a parellel board from EP buddy with the correct interconnect cable set to XH wiring. I have charged everything from 2-6s with no problems till 2 weeks ago. Whenever I connect a 4 s battery (which used to charge quite happily, it shows the warning 'bad cell count; XH wiring. What has gone wrong -- software , hardware fault, my fault? I did nothing different with no updates etc. It just strated doing this 'out of the blue'. I have tried a factory restore, but no change.
Thank you
Any comments TIm?
unhinged is offline Find More Posts by unhinged
Old Oct 25, 2013, 11:15 AM
gremlin is offline
Find More Posts by gremlin
What?!? I didn't do that!
gremlin's Avatar
United States, NY, Orchard Park
Joined Dec 2002
I had that happen recently. I was using one of the stackable cables and blew a fuse. Drove me crazy till I found it. I think that error happens when the main line voltage is different than the balance leads voltage. Check the connections on your main power leads and the balance leads to see if there is a break somewhere.
gremlin is offline Find More Posts by gremlin
Old Oct 25, 2013, 11:18 AM
Gregor99 is offline
Seattle
Joined Sep 2007
Originally Posted by unhinged View Post
Help please.
Thank you
Any comments TIm?
If the board does not have fuses on the balance leads, its possible the board has been damaged. This is VERY common. I would use a ohm meter and check for continuity (pin by pin) between the balance port you where using and the connector that goes onto the charger.
Old Oct 25, 2013, 11:37 AM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
Quick question...
Why does my charger keep stopping at 93% ?
Old Oct 25, 2013, 01:10 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Quick question...
If its stopping with cells at 4.1v then its likely that the ambient temps have dropped below 50f. This the cold weather charge mode. You can lower the temp threshold to 41f. But wouldn't go any lower. The setting is in the preset options via the console or on the in the CCS.
Old Oct 25, 2013, 01:13 PM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
That's it!
It is cold here now...Thanks.
Old Oct 25, 2013, 01:14 PM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
So is it bad to fully charge lipos in the cold?
Old Oct 25, 2013, 01:47 PM
Turner2 is offline
Find More Posts by Turner2
Tallahassee, FL
Joined Sep 2009
Not if you use them right away. If you fully charge them cold and then they are allowed to warm up they will then be over charged.
Turner2 is offline Find More Posts by Turner2
Old Oct 25, 2013, 02:29 PM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
They aren't allowed inside so that shouldn't be an issue.
Discussion PowerLab Charge Control Software Quick Tour Tim Marks FMA Direct 15 Mar 31, 2014 06:09 AM
Help! 1S charging lead Assassin-8 Batteries and Chargers 7 Jan 11, 2013 02:41 PM
Question PowerLab 8 parallel 1S "balanced" charging ibrandt FMA Direct 1 Apr 11, 2012 04:53 AM
Mini-HowTo TP-610C Quick Start Guide marc1 Batteries and Chargers 15 Dec 10, 2011 11:12 PM
Discussion FlyCamOne2 Quick Start Guide. Easy to follow. gdavis9999 Aerial Photography 2 Jan 06, 2009 01:04 AM
