Old Feb 21, 2013, 11:01 PM
v00d0o is offline
Find More Posts by v00d0o
v00d0o's Avatar
United States, VA, Fairfax
Joined Dec 2012
Carbon vs G10
After a builder has suggested that I use G10 for my quad,
I'd like to know the weight ratio between G10 to CF.
I know G10 is heavier but how much heavier? Would drilling designs into the g10 be a good idea of a hindrance to its strength?
Thanks!
v00d0o is offline Find More Posts by v00d0o
Old Feb 21, 2013, 11:10 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
What ratio are you referring to? Strength to weight? Stiffness to weight? Laminate thickness to weight?
wyowindworks is offline Find More Posts by wyowindworks
Old Feb 21, 2013, 11:12 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Weight of G10 in comparison to the weight of Carbon fiber.
For example:
if they were both 100mm x 100mm square plates (1.0mm thick)
Carbon fiber would weigh - 20 grams and g10 would weigh? (how much)
Thanks.
Old Feb 22, 2013, 05:27 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Roughly the same.
Back of a smoke packet math:
Density of glass (only the fibres) is around 2.6gcm^-3, carbon is ~1.9.
Resin uptake is similar, so I'll assume a Vf of 50%.
Difference in density for the laminate is therefore 0.35gcm^-3, so a 10cm3 plate would have a 3.5g difference.
Strength/stiffness though would be very different.
Odysis is offline Find More Posts by Odysis
Old Feb 22, 2013, 05:38 AM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Originally Posted by Odysis View Post
Roughly the same.
OK thank you.
What thickness would you advise? I used 1.0mm carbon for my previous quad...I want a similar strength. I read somewhere doubling the size of the thickness of g10 is equivalent to CF strength wise.
Old Feb 22, 2013, 06:02 AM
Odysis is offline
Joined May 2007
Outside my expertise, sorry. Never done multirotors.
I'm not sure if you're after equal strength, or equal stiffness...
Old Feb 22, 2013, 08:19 AM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
G10 is heavier then Carbon of the same thickness
G10 Isnt as stiff as Carbon of the same thickness
G10 Is Cheaper
G10 will flex more before it breaks
G10 doesnt conduct electricty (something to consider also)
The usual thing though, atleast for helicopters, is that carbon is superior to G10 for frames. I wouldnt go back to G10 frames in a million years. If you crash your quad, both are going to break anyhow.
SB7 is offline Find More Posts by SB7
Old Feb 22, 2013, 08:34 AM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
I'm flying fpv. G10 maybe a better solution for the video tx and have less interference.
Old Feb 24, 2013, 10:47 AM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
I need to get Carbon Fiber Square tubing, is it better to have a round hole or a square hole in the center? Or does it not really matter. (the square hole would have 1.5mm walls and the circle has 1.5mm diameter) ...square hole is cheaper.
Old Feb 24, 2013, 07:09 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
http://image.tradevv.com/2010/08/10/...quare-tube.jpg
square or circle?
Old Feb 26, 2013, 02:10 AM
Just fly it!
Cody, WY
Joined Nov 2007
The tube with the round hole will be stronger but heavier.
Help! Carbon vs kevlar sock Jets:) Composites Fabrication 4 Feb 22, 2013 03:12 PM
Question Century Swift NX vs Century Swift Carbon psguardian Large Electric Helis 8 Feb 04, 2013 04:58 PM
Question Glass Fiber vs Carbon Fiber Hajile Multirotor Talk 0 Feb 04, 2013 10:57 AM
Wanted carbon or g10 frame for trex adrian52492 Aircraft - Electric - Helis (FS/W) 0 Dec 24, 2006 10:13 PM
MIA G10/Carbon Frame Options for Micros Mario Electric Heli Talk 10 Aug 28, 2002 03:21 PM
