Old Feb 21, 2013, 10:36 PM
Phanixis is offline
Find More Posts by Phanixis
Joined May 2008
Need Help Designing an EPP Wing
I want to design a two meter wing for a scratch built RC airplane. I want to make it out of expanded polypropylene. So I calculated the weight of a 200 cm wingspan, 20 cm wing chord NACA 2412 airfoil made of solid EPP wing (not including any internal structure) with no wing taper and calculated a weight of 8.6 kg (18.9 lbs). I never realized EPP was this heavy.
Has anyone else designed and built wings out of EPP? Is there any way to get the weight down?
Thanks for the help.
Phanixis is offline Find More Posts by Phanixis
Old Feb 22, 2013, 12:19 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
I think you maybe looking at the wrong foam for a wing. I weighed a piece of Extruded Polystyrene (owens corning pink foam) 2.25" x2.0' x 21.5" = 97.88 cuin@ 1.385oz Figuring 1" thick airfoil, your 632cu/sq in, should weigh 6.55oz.
BTW, lots of people have/do use this for there wings.
You are correct on the weight, darn heavy!
wiki.answers.com
The density of polypropylene depends on whether it is crystalline or amorphous. I'll give both numbers:
Amorphous: 0.85 g/cm3
Crystalline: 0.95 g/cm3
1 cm3 = 3.53147 x 10-5 cubic feet
or
1 foot3 = 28316.847 cm3
So 1 ft3 of polypropylene weighs 24,069.32 g and 26,901.00 g for amorphous and crystalline respectively.
That's also equal to 24.069 kg or 26.901 kg
1 kg = 2.204622 pounds
So 1 ft3 of amorphous polypropylene weighs: 53.064 lbs
and 1 ft3 of crystalline polypropylene weighs: 59.307 lbs
From this site: http://www.builderswebsource.com/_discBT/00000d75.htm
Insulation ...
...Extruded Polystyrene 1.8 pcf
...Expanded Polystyrene (EPS) 1.0 - 4.0 pcf, depending on density (0.9 to 2.19 pcf typ range)
...Polyurethane 1.5 pcf
Weight per Unit
pcf = pounds per cubic foot
pcy = pounds per cubic yard
plf = pounds per lineal foot
psf = pounds per square foot
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Feb 22, 2013, 09:57 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Just had a quick look in the Foamies(Scratchbuilt) forum for any big EPP models, found a C-130, (long narrow 1968mm span wing) in EPP.
C-130 Hercules EPP
Never tried EPP, my preference is for balsa or Depron foam.
eflightray is online now Find More Posts by eflightray
Old Feb 22, 2013, 10:40 AM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
You can get different densities of EPP, but generally as the density goes down, the strength/stiffness goes down faster. It's good for smaller planes and the 3D profiles, but for a general use plane I'd go with Ray and Cooler and stay with a styrene based foam.
Are you intending to build a flying wing, or a wing for more conventional plane? If a wing, then there are a half dozen designs in the scratchbuilt foamies forum already designed, validated and built by dozens of folk. you can typically download the PDF files of the designs and build from that. Or, just browse the threads and get ideas for your own!
Which foam you can get will vary with where you are located. It's good to add that to your profile, as answers will vary, depending on where the answerer is located versus where you are. You will also get folk in your country who will give most appropriate answers about availability.
springer is offline Find More Posts by springer
Old Feb 22, 2013, 02:26 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
+1 to all of what above has been mentioned... I think you'll find more help in the Scratchbuilt Foamies subforum, it's the go-to place for foamy building.
acetech09 is offline Find More Posts by acetech09
Old Feb 22, 2013, 03:54 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
EPP only works with stiffening. But when it's done right, it's phenomenal. A 46" EPP foamie 3D plane -- airframe only -- is probably well under a pound.
Stiffening can come from CF rods or strips arranged in I-beam fashion from root to tip (of a wing.) Or you can build hollow structures using thin EPP as the skin, and some other material (or thick EPP) for the ribs and possibly spars. Putting a curve into the skin (as in a wing) contributes to the stiffening.
Solid EPP, without any internal or external support, isn't going to get you very far.
rafe_b is offline Find More Posts by rafe_b
Old Feb 22, 2013, 07:16 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
You're looking at the density of the polypropylene itself. Not the density of the foamed version. That's why its up over 50 pcf.
The EXPANDED PolyPropylene foam it a lot less depending on the density of the foaming process. One maker lists the product as ranging from 1.3 to 1.9 pcf.
Either that or you badly slipped a decimal point in your wing volume calculations.
BMatthews is online now Find More Posts by BMatthews
Old Feb 23, 2013, 08:29 PM
Phanixis is offline
Joined May 2008
A lot of good information here, but I think BMatthews has identified the problem. I was calculating the weight based on the amorphous Polypropelene density, which is nearly a gram per cubic cm, and because my wing was estimated to have a volume of 10,000 cubic centimeters (50 cm airfoil area x 200 cm wingspan), I was getting an enormous weight. Looks like a need to find good density numbers for EPP.
Old Feb 23, 2013, 08:38 PM
rafe_b is offline
Joined Jan 2009
Here's a thread on RCG discussing EPP density. Hobby stuff is anywhere from 0.9 to 1.9 lbs. per cubic foot.
http://www.rcgroups.com/forums/showthread.php?t=8080
And here's a page of stats for various types and thicknesses of foam sheets
http://www.rcfoam.com/stpg.php?page_...65a7d29b96d045
Old Feb 24, 2013, 10:03 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Take this design, scale it up a little:
http://www.extremflug.de/seite100.htm
2.5° wing twist works well.
Google PW106 Airfoil for maximum lift, works well with the rough surface.
If you cover the surface and want more speed, the PW75 is great.
Julez is offline Find More Posts by Julez
Help! 12 Volt Voltage Regulator Design and Build Help Needed Borneoben Multirotor Electronics 4 Feb 19, 2013 07:33 AM
Question Need Help Identifying an Engine Pierre_de’ Loop Engines 5 Feb 12, 2013 03:26 PM
Help! Need help with polyhedral EPP glider wing assembly Alard Slope 8 Jan 15, 2013 03:08 PM
Wanted Help needed - electronics design and mfg HoverThings Aircraft - Electric - Multirotor (FS/W) 3 Jan 12, 2013 07:42 PM
Help! Help Choosing an EPP Plane! Need your opinion nickname236 Foamies (Kits) 6 Sep 15, 2008 03:47 PM
