Old Feb 21, 2013, 05:22 PM
cessna20122013 is offline
Find More Posts by cessna20122013
cessna20122013's Avatar
United States, CO, Parker
Joined Feb 2013
Rant
Lipo Connectors!!
Why does every Lipo have to have a diff connector. I suck at soldering and is very aggrivating!! I'll spen a hour on just on Eflight EC3!!
cessna20122013 is offline Find More Posts by cessna20122013
Old Feb 21, 2013, 05:50 PM
CrashnBurn420 is online now
Find More Posts by CrashnBurn420
CrashnBurn420's Avatar
United States, RI, Coventry
Joined Dec 2012
Ec3s are about the easiest connector to solder. Shouldn't take more than a few minutes. Youtube has some videos showing how to solder them.
CrashnBurn420 is online now Find More Posts by CrashnBurn420
Old Feb 21, 2013, 06:13 PM
Joined Feb 2013
maybe my solder iron doesnt get hot enugh cause its not as easy as the videos. I cant tin the wire or connector. seems like it does not get hot very fast. Its a cheap radio shack iron.
Old Feb 21, 2013, 06:21 PM
neon the cat is offline
Find More Posts by neon the cat
Cats can fly!
neon the cat's Avatar
Joined Jun 2012
In that case, you're done before you start. I use a Weller 100/140 watt soldering gun. Lots of heat for even the thickest gauge wires. The smaller (<50W) soldering pencils used for electronics will not work. I also use EC3's and they are quick to install with the right tools.
neon the cat is offline Find More Posts by neon the cat
Old Feb 21, 2013, 06:37 PM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
I used one like this for years and had lots of trouble. Was always taught not to oveheat stuff and use a low wattage device. Then I learned that high wattage was better because you can heat and get out quick. I bought this and my soldering has been transformed. I look forward to soldering now.
http://hobbyking.com/hobbyking/store...arehouse_.html
Even with shipping this is dirt cheap for this station which is a clone of a t$100 soldering station.
shahram72 is offline Find More Posts by shahram72
Old Feb 21, 2013, 06:41 PM
RuralFPV is offline
Find More Posts by RuralFPV
Head full of foam
United States, NE, Omaha
Joined Jan 2013
Part of it is probably the iron. Part of it is usually the tip. You not only need the wattage to heat the tip, you need a tip big enough to hold all the heat you're about to transfer. Youtube, and don't look at any of the surface mount vids, they will steer you in the OPPOSITE direction.
Edit: And flux, google "kester flux pen". See if you can find a #186. Will really help with getting the solder to "wet out".
RuralFPV is offline Find More Posts by RuralFPV
Old Feb 21, 2013, 06:44 PM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
You must keep the tip clean for good heat transfer. Use a damp sponge between tinnings to keep it shiny. Also, make sure your solder is 60/40 (tin/lead) to promote easy flowing. Practice on some scrap wire until it becomes second nature. It is an indispensable skill for electric fliers.
whitecrest is offline Find More Posts by whitecrest
Old Feb 21, 2013, 06:48 PM
rhodesengr is offline
Find More Posts by rhodesengr
This is your brain on heli's
rhodesengr's Avatar
United States, CA, Livermore
Joined Jan 2012
Last year I found a video that made a huge difference in the ease of doing EC3 and EC5 connectors. I can't find it now but here is the idea. Don't hold the iron by hand. Tape it vertically to a block of wood with the hot end up. File the tip so you can put an EC connector on the tip with the solder pot facing up. let it sit there until its good and hot. Then put a little solder into the cup. Then insert the already tinned wire end. Make sure it remelts the tinned wire end and everything is molten. Then use pliers to lift the connector off the iron. Hold it still until the solder hardens. Then while its still warm press it into the plastic part with a 1.5mm hex driver.
You do need a decent size iron. 45 watts seems to be enough for even EC5's and should be plenty of EC3 but more would be better. I have never liked guns that much.
rhodesengr is offline Find More Posts by rhodesengr
Old Feb 21, 2013, 06:56 PM
rhodesengr's Avatar
Joined Jan 2012
I found the video. This is the best way to solder EC type connectors.
http://www.maydayrc.com/neat-way-to-solder-ec3-plugs/
Old Feb 21, 2013, 07:45 PM
MikeCr is offline
Find More Posts by MikeCr
United States, WI, Slinger
Joined Mar 2006
You do not need a 50W iron to solder these connectors. I use a Weller WLC-100 soldering station with a 40W iron and it's plenty for the EC3, EC5, Deans, whatever. I also have a Weller 200/260W gun but I rarely need it for soldering connectors unless I'm soldering 10 gauge wire. As mentioned you need a large tip but you definitely do not need more than about a 40W iron.
MikeCr is offline Find More Posts by MikeCr
Old Feb 21, 2013, 08:41 PM
Joined Dec 2012
I bought the weller 40watt pen type from home depot a few years ago and i has served me well for these connectors. The biggest thing is you need to keep the tip tinned and very clean. Once you let it get all gunked up with crap it's not going to transfer heat well.
Old Feb 22, 2013, 02:52 PM
Jimob23 is offline
Find More Posts by Jimob23
United Kingdom, England, Ware
Joined Aug 2012
One thing to avoid with EC3 is allowing any solder to run down the outside as there is a small groove that locates it into the insulator
If you paint some white typing correction fluid ( Tibbex ) on the outside the solder will not stick and is easy to remove
Be careful putting the insert into the insulator as if you are holding it with your fingers the screwdriver can slip and go into your finger
Yes I did it but only once
Just a bit of practise will see right
Cheers Jim
Jimob23 is offline Find More Posts by Jimob23
Old Feb 23, 2013, 08:20 AM
Boogie_ is online now
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Ditto.
I have a 40w iron and solder 10ga wire to 6mm bullets. I all happens very quick & easy with plenty of heat.
Usually the problem is the use of metal alligator clips or pliers. They'll suck up all the heat, which will require a higher wattage iron.
Holders made out of wood are the ticket. Wood blocks, clothes pins, etc.
Boogie_ is online now Find More Posts by Boogie_
Elios000 is offline
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
if you hate soldering check out Power Poles they crimp on youll need to get a crimping tool for them but its so much easier
Elios000 is offline Find More Posts by Elios000
Old Feb 23, 2013, 09:47 AM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
I was just about to say the same thing. APPs with a crimp tool allows you to install connectors in seconds.
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Sold Two ESC one lipo Connector with Deans - $6 shipped lower 48 bighead93 Aircraft - Electric - Power Systems (FS/W) 1 Feb 20, 2013 04:56 PM
Sold Hyperion 2S 320mAh 25C Lipo w/UMX connector JayY Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 28, 2013 08:01 PM
Discussion Lipo connectors iflircaircraft Electric Plane Talk 37 Jan 27, 2013 10:00 AM
Deans 2 & 3 pin connectors and Multiplex Connectors SOLD FieldofDreamsFlyer Non R/C Items (FS/W) 1 Jan 02, 2013 01:21 PM
Mechanical connectors for LiPo tabs? HankF Batteries and Chargers 1 Jun 05, 2003 03:12 PM
