Old Feb 21, 2013, 04:34 PM
jmupilot is offline
Find More Posts by jmupilot
USA, VA, Harrisonburg
Joined Jul 2005
Question
Turnigy 9x w/ OrangeDSM DSM2 module problems
I bought a 9X turnigy radio and the DSM/DSM2 module to go with it. I have several orange DSM2 6 channel and 4 channel micro Rx's that work just fine. The problem I have is when I bind and try to use this radio with a micro Cub or Blade CMX heli I dont have the right stick to servo response so I can not fly them. They work just fine with the little Eflite radios that came with them.but with the 9x it seems the elevator is on the rudder stick the throttle is on the aileron stick and no rudder at all. I know it sounds like mode1 but I have checked this. I have it in the correct Mode which is Mode 2 the other RX's are just fine. Just the EFlite aircraft with AR6400 bricks are wrong. I also have 2 other AR6400 bricks that I was planning on putting in 2 BSDMicro Titan seaplanes. The reason for buying the 9X Turnigy was it has 8 model memory and I can fly them all with one transmitter.
ANY help would be appreciated
Pete
jmupilot is offline Find More Posts by jmupilot
Old Feb 21, 2013, 05:01 PM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
If you are using Er9x firmware there are settings ( not changing modes) that respond to the channels such as aert, reat etc can't be exact cos I'm waiting for a new one.
scousethief is offline Find More Posts by scousethief
Old Feb 21, 2013, 08:35 PM
jmupilot is offline
Joined Jul 2005
not sure of that. It is the newest V2 software it just came yesterday. I ordered it about 3 weeks ago. The Orange DSM module does have 4 different settings I'm guessing its for enconding different Rx's.DSM2 1024/22ms, DSM2 2048/11ms, DSMX22ms, and DSMx11ms
I have tried all of these and the first 2 are the only ones the AR6400 brick sees.
It is my first radio like this, althought I have been in the hobby for 40 yrs. I have 2 Futaba 8UAP module radios that I am thinking of buying a Orange DSM module for them to try. I am familiar with the Futaba set ups.
The AR6400 responds its just not the right channel for stick movement. This radio has 4 different mode settings 1,2,3,4. They just change the channel the stick is changing not the actual channel the Rx sees. Tried all 4 of these also. Sorry if this should be in another thread but I am into micros and thought it would be a good place to start since alot of you use the AR6400 bricks.
Pete
Old Feb 21, 2013, 10:05 PM
Denile is offline
Find More Posts by Denile
M16 CIII/AR15/FN 2000 and PS90
Denile's Avatar
United States, AR, Waldron
Joined Jan 2005
Looking at HK site there are 5 globe unique identity codes you push some button three times rapidly then bind if it does not work correctly push the button three times again and then try to bind again, keep trying till right code is found. Do not know if this is the problem but may be worth a try.
Denile is offline Find More Posts by Denile
Old Feb 21, 2013, 10:41 PM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
You need to get this http://www.smartieparts.com/shop/ind...roducts_id=331 and flash your 9x with ER9x/Open9x.
gooby is offline Find More Posts by gooby
Old Jun 05, 2013, 09:06 AM
doodlewhale is offline
Find More Posts by doodlewhale
doodlewhale's Avatar
Joined May 2008
I have the exact same issue I posted over in the Radios section http://www.rcgroups.com/forums/showthread.php?t=1905195 If I get a definitive answer I will be sure to let you know too!
doodlewhale is offline Find More Posts by doodlewhale
Old Jun 05, 2013, 10:21 AM
Joined Jan 2006
Yeah , ok what you need to do (ER9X) is goto menu 10 right at the bottom and change channel order to TAER , next goto menu 5 and it should now read Throttle aileron elevator rudder going downwards.
You can flash your radio using an arduino pro mini if you have one.
Old Jun 06, 2013, 10:15 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
problem is probly the V2 software. (it sucks big time)
upgrade the firmware. ER9x i hear is great. i used open9x, every feature in the book. but its a geeks firmware.
get the spartie parts board, unless ur comfortable with SMD soldering by hand. (might get one used)
lots of tutorials on flashing turnigy 9x.
cant really comment on probblem solving in the stock firmware.
nemoskull is offline Find More Posts by nemoskull
Old Jun 28, 2013, 11:23 PM
Ian444 is online now
Find More Posts by Ian444
Brisbane, Australia
Joined Apr 2013
I think you will need the er9x firmware. With this firmware, you can assign any stick to any receiver channel (in the mixer section). Some bricks, like the Champ and J3 bricks, have the aileron stick controlling the rudder servo, other bricks with aileron servo outputs use the standard JR/Spektrum TAER for channels 1 to 4. The only possible gotcha with the Orange module that I can see, is that some bricks use DSM2 and others use DSM2/DSMX, and the Orange module chooses which mode to use during binding. If the brick is DSMX capable, the Orange module wants to choose DSMX and cannot be forced into DSM2 (in my experience). If you want to use a mix of models with DSM2 and DSMX bricks, I think you will have to rebind for each type. However, the Orange module seems to give a lot more range when flying, I have not experienced signal loss since using mine, but did have quite a few signal dropouts with the stock HZ/PZ transmitters when I got too high and too far away.
BTW I really like the er9x firmware, it is a joy to use and I wish I had gone this route sooner rather than later...
Edit: I tested the Orange module on DSM2 and DSMX bricks, there is no need to rebind for each brick, but you do have to push the button (3 times quickly) on the back of the Orange module to change between DSM2 and DSMX modes.
Ian444 is online now Find More Posts by Ian444
Discussion OrangeRX DSM2 Module, 9x and Blade BNF Micro Helis JimStanmore Micro Helis 6 Jan 07, 2014 01:09 PM
Sold PRICE DROP $SOLD Turnigy 9x new w/ Bling, Backlight, ER9x, modules optional The RevKev Aircraft - General - Radio Equipment (FS/W) 2 Feb 10, 2013 12:01 PM
Sold turnigy 9x updated firmware, 14ch dsm2 tx nemoskull Aircraft - General - Radio Equipment (FS/W) 3 Jan 05, 2013 07:25 PM
Discussion Ordered the Turnigy 9x with DSMX/DSM2 Module Rich in ILM Radios 0 Dec 03, 2012 02:50 PM
Wanted wanted turnigy 9x radio with original module and dm9 module(dsm2) ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 0 Jul 22, 2011 01:21 PM
