Old Feb 21, 2013, 05:17 PM
Fergusp51 is offline
Find More Posts by Fergusp51
Joined Jan 2007
Jetcat P20, distance between exhaust cone and bellmouth of tailpipe
Anyone any recommendations? - nothing on the Jetcat website
Bill Ferguson
Fergusp51 is offline Find More Posts by Fergusp51
Old Feb 22, 2013, 01:13 AM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Ln, Ljungby
Joined Jan 2001
The distance is very individual, you can even gain thrust if you fit a pipe in the right shape. Most can keep their thrust if the pipe is installed correctly and many will loose ~30% by installing it in a posision that looks right.
I strongly suggest you test rather then snag a number of a forum. The smaller the jet the more important it is. A P20 setup needs a good hand when installing it to get it working well. I have tested so I know! Others might guess ;-)
HAB Electronic test and tune bench (1 min 45 sec)
henke is offline Find More Posts by henke
Old Feb 22, 2013, 11:46 AM
lxfly is offline
Find More Posts by lxfly
lxfly's Avatar
Luxembourg
Joined Dec 2012
You find this information in the jetcat catalog on page 54
Ren
http://www.rcmarket.net
lxfly is offline Find More Posts by lxfly
Old Feb 22, 2013, 03:28 PM
henke is offline
henke's Avatar
Joined Jan 2001
Ren
Now thats guessing(!)
The Jetcat table is wrong. following it will snag 10-15oz of thrust with ease!
Old Feb 22, 2013, 03:31 PM
Joined Jan 2007
Thanks very much for your responses, they are very helpful.
Bill Ferguson
Old Mar 17, 2013, 01:30 PM
raptor30se is offline
Find More Posts by raptor30se
United States, WV, Huntington
Joined Nov 2005
Henke what do you recommend for the P20. I have mine 20mm inside bellmouth in my Habu32. I am getting 2154grams on a fish scale, so I am loosing some to wheel friction when measuring. I didn't think that was too bad.
raptor30se is offline Find More Posts by raptor30se
Old Mar 18, 2013, 09:43 AM
henke is offline
henke's Avatar
Joined Jan 2001
Hello,
I've not tested that much so I can predict every case but I know my engine ran very well on a 40 pipe(Kolibri ~3kg thrust). Also I would try with less overlap. 0-10mm or so...
A P20 running in the free does about 2.1kg in normal indoor temprature from what my tests show.
Old Jul 05, 2014, 01:19 PM
rapidrabbit is offline
Find More Posts by rapidrabbit
United Kingdom - Midlands
Joined Jul 2005
Just a quick question guys -
I have a 41mm dia thrust pipe for my kolibri T32 and it has a small bell mouth on one end. What would be recommended for spacing from end of turbine outlet cone to the bell mouth or pipe?
Any help really appreciated
Cheers!
rapidrabbit is offline Find More Posts by rapidrabbit
Help! Extend distance between muffler and OS .46 AX II Ruta Engines 4 Feb 12, 2013 09:19 AM
Build Log TamJets 1/12 Scale F-16 with JetCat P20 RC-Warbirds Jet Turbines 21 Jul 16, 2012 03:59 AM
Wanted WANTED: 2nd-hand (but fully working) Jetcat P20-SE or Lambert T25 Kolibri gas turbine Ian Davidson Aircraft - Fuel - Jets (FS/W) 0 Dec 06, 2011 02:20 PM
Discussion WANTED: 2nd-hand (but fully working) Jetcat P20-SE or Lambert T25 Kolibri gas turbine Ian Davidson Jet Turbines 0 Dec 06, 2011 02:18 PM
Discussion WANTED: 2nd-hand (but fully working) Jetcat P20-SE or Lambert T25 Kolibri gas turbine Ian Davidson Fuel Jet Talk 0 Dec 06, 2011 02:17 PM
